node-red-contrib-jira-api 0.1.1
Node-RED Jira API nodes
npm install node-red-contrib-jira-api
Atlassian Jira API v2 nodes for Node-RED.
In contrast to other packages, this one does not rely on the users actual password but an access token.
You need an Atlassian Jira access token to use these nodes.
  • Get a specific issue
  • Edit n issue
More nodes will be added over time. I don't expect a high demand for this package anyways, but if missing nodes get requested, I should be able to add them rather quickly.
You can either install this package from within Node-RED using the command palette and search for "node-red-contrib-jira-api", or you run the following command in your Node-RED user directory (typically ~/.node red on Linux, %APPDATA%\node-red on Windows):
Version: 0.1.1
Updated 2 years, 4 months ago
2 in the last week
  • jira-server
  • jira-get-issue
  • jira-edit-issue
  • jira
