node-red-contrib-jexl 1.0.3
a node to use the JEXL expression language
npm install node-red-contrib-jexl
node-red node to parse and evaluate an expression against a context using jexl
What does it do?
The jexl node expects a msg.payload that contains a valid jexl expression, e.g.
(data.someprop + 2) > 42 ? "cannot be" : "this is right"
It also expects some data in the msg.context property. The expression is parsed and evaluated against this data, e.g.
    "data": {
        "someprop": 40
This would result in this string: this is right in msg.payload.
Ideas to improve this node
  • set the input property name for payload / context
  • allow to add operators or transforms by passing in more message parts, that contain javascript code
  • allow to set xml / yaml transforms to run these formats with the node.
If you have a feature request, please contact me or open a pull request.
Version: 1.0.3
Updated 6 years, 1 month ago
5 in the last week
  • jexl
  • jexl
  • expression
  • el
  • language
  • parsing
  • parser
