node-red-contrib-jetson-mfrc522 1.0.1
Simple Node-RED node for the Jetson Nano to read NFC tags via a RC522 NFC reader. It can return the UID and optionaly a text from card.
npm install node-red-contrib-jetson-mfrc522
A [Node-Red][1] node that allows you to read NFC tags with an RC522 card reader. Tested the node on a Jetson Nano.
Requirements
  • [Python3][2]
  • [Jetson.GPIO][3]
  • [Jetson-MFRC522][4]
Enable SPI
  • Next, configure the Jetso for SPI, use the command
    sudo /opt/nvidia/jetson-io/jetson-io.py
  • Select Configure Jetson 40pin Header
  • Then, Select Configure Header pins manually
  • Select spi1 and then select exit
  • Select Save pin changes
  • Select Save and reboot to reconfigure pins
  • Last, use the following command to enable spidev
sudo modprobe spidev
WIRING
You need to connect to RC522 card reader to the following pins:
|      | PIN |
| SDA  | 24  |
| SCK  | 23  |
| MOSI | 19  |
| MISO | 21  |
| GND  | 6   |
| RST  | 22  |
| 3.3V | 1   |
NOTES
Currently this project only support reading tags on SPI bus 0.0. Also, the node only supports reading tags, not writing tags.
[1]: https://nodered.org [2]: https://www.python.org [3]: https://github.com/NVIDIA/jetson-gpio [4]: https://github.com/SantaCRC/Jetson-MFRC522
Version: 1.0.1
Updated 4 years, 2 months ago
8 in the last week
  • mfrc522-reader
  • node
  • nfc
  • rc522
  • mfrc522
  • jetson
  • nano
