node-red-contrib-jasper-node 0.1.4
This is a set of Node-Red nodes that allows you to connect to a Jasper Node server, write tags and subscribe to tags.
npm install node-red-contrib-jasper-node
Node-RED Jasper Node
A set of Node-RED nodes that allows you to connect to a Jasper Node, write tags and subscribe to tags.
  • Connect to Jasper Node with authentication
  • Write single or multiple tag values
  • Subscribe to single or multiple tags
  • Batch mode support for path-based operations
  • Automatic reconnection handling
  • WebSocket-based real-time updates
Jasper Node (Configuration)
Configuration node for setting up the connection to a Jasper Node.
Properties
  • Name: Name for this configuration
  • Server URL: URL of the Jasper Node
  • Token: Authentication token
Tags In
Write tag values to the Jasper Node.
Properties
  • Name: Name for this node
  • Server: Select the Jasper Node configuration
  • Batch Mode: Enable to write multiple tags at once
  • Tag Path: Base path for tags (used in both modes)
  • Tag Name: Specific tag name (single mode only)
Input
In single tag mode:
  payload: "value" // string, number, boolean, null; Object will be converted to JSON string
In batch mode (object format):
  payload: {
    "tag1": "value1",
    "tag2": "value2"
In batch mode (array format):
```js
  payload: [
    { tagId: "tag1", value: "value1" },
    { tagId: "tag2", value: "value2" }
Tags Out
Subscribe to tag values from the Jasper Node.
Properties
  • Batch Mode: Enable to subscribe to multiple tags
  • Tag Path: Path to subscribe to (batch mode)
  • Tag IDs: List of specific tags to subscribe to (single mode)
Output
In single tag mode:
  path: 'path/to/tag1',
  value: "value1",
  stats: {
    ts: 1716729600000,
    prevValue: "value0",
    prevTs: 1716729599000,
    setTs: 1716729600000,
    prevSetTs: 1716729599000,
    source: "source",
  payload: "same as value",
In batch mode:
  data: [
      value: "value1",
      stats: {
        ts: 1716729600000,
        source: "source",
      path: 'path/to/tag2',
      value: "value1",
      stats: {
        ts: 1716729600000,
        source: "source",
  payload: [same as data],
  collection: {
    [tagName: string]: "tag value"
  tagEvent: "valueChange"
Version: 0.1.4
Updated 1 year, 7 months ago
6 in the last week
  • jasper_node_in
  • jasper_node_out
  • jasper_node
  • jasper node
