node-red-contrib-jalali 0.1.1
Jalali calendar utilities for Node-RED
npm install node-red-contrib-jalali
# node-red-contrib-jalali
Table of Contents
Overview
A Node-RED node that converts the current time or a message timestamp into Jalali (Persian/Shamsi) calendar date and time.
Built with JavaScript's Intl.DateTimeFormat, with no external dependencies.
  • Current time, ISO date strings, and Unix timestamps.
  • Configurable time zone and output format.
  • Latin or Persian digits.
  • Formatted string or structured object output.
  • Configurable error handling.
Requirements
  • Node.js 22 or later, with Persian calendar support in Intl.
  • A working Node-RED installation.
Run the following command in your Node-RED user directory, usually ~/.node-red:
Restart Node-RED after installation.
For Docker installations using /data as the user directory:
docker exec -it <container_name> sh -c \
  'cd /data && npm install node-red-contrib-jalali'
docker restart <container_name>
Quick Start
  1. Add Inject, jalali, and Debug nodes.
  2. Connect them:
Inject → jalali → Debug
  1. Keep the Jalali node's default settings.
  2. Configure Debug to display msg.jalali or the complete message.
  3. Click Deploy, then trigger Inject.
The node writes the current Jalali date and time to msg.jalali, using the Asia/Tehran time zone.
In Current time mode, each incoming message triggers a conversion. Its timestamp fields are ignored.
Setting Description Default
Date source Current time or a message field Current time
Input field Message property containing the date payload.timestamp
Input type ISO 8601, Unix milliseconds, or Unix seconds ISO 8601
Time zone Display time zone Asia/Tehran
Custom format Custom date/time format YYYY/MM/DD HH:mm:ss
Digits Latin (latn) or Persian (arabext) Latin
Output mode Structured object or formatted string Structured object
Output field Message property to receive the result jalali
On error Stop and report, or pass through unchanged Stop
Enter message property paths without the msg. prefix, for example:
payload.timestamp
or:
jalali
Input field and Input type apply only when Date source is set to Message field.
Input and Output
Convert a Message Date
Set:
  • Date source: Message field
  • Input field: payload.timestamp
  • Input type: ISO 8601
Example Input
  "payload": {
    "timestamp": "2025-03-21T00:00:00Z"
With default formatting, time zone, digits, and output settings, msg.jalali contains:
  "date": "1404/01/01",
  "time": "03:30:00",
  "datetime": "1404/01/01 03:30:00",
  "formatted": "1404/01/01 03:30:00",
  "timezone": "Asia/Tehran",
  "calendar": "persian",
  "timestamp": 1742515200000
With Output mode set to Formatted string, msg.jalali contains:
1404/01/01 03:30:00
Supported Inputs
Input type Example
ISO 8601 "2025-03-21T00:00:00Z"
ISO 8601 with offset "2025-03-21T03:30:00+03:30"
Unix seconds 1742515200
Unix milliseconds 1742515200000
ISO input requires:
YYYY-MM-DDTHH:mm:ss
with optional fractional seconds of 1–3 digits, and either Z or an explicit ±HH:mm offset.
Unix input accepts numbers or decimal numeric strings. Select seconds or milliseconds explicitly; units are not auto-detected.
For nested MQTT payload fields, decode the payload into an object first using MQTT JSON output or a JSON node.
Output Behavior
  • The selected output field is overwritten if it already exists; other message properties are preserved.
  • Use a separate output field to keep the original input date.
  • The time zone affects the displayed date and time, not the underlying timestamp.
  • timestamp always remains a numeric Unix timestamp in milliseconds, even with Persian digits enabled.
  • The custom format controls string output and the object's formatted datetime.
Formatting
Token Meaning
YYYY Jalali year
MM Month
DD Day
HH Hour, 24-hour clock
mm Minute
ss Second
Examples
YYYY/MM/DD
YYYY-MM-DD HH:mm
[Date:] YYYY/MM/DD [Time:] HH:mm:ss
Wrap literal text in square brackets to prevent token replacement.
Selecting Persian digits converts generated date/time digits to:
۰۱۲۳۴۵۶۷۸۹
Literal text remains unchanged.
Error Handling
Stop
Does not forward the message and reports the error to Node-RED.
Use a Catch node to handle it.
Pass Through
Forwards the original message unchanged and logs a warning.
Missing input fields, invalid dates, unsupported time zones, and invalid configuration are handled using the selected error mode.
Apache-2.0 — Farzin Bidokhti.
Version: 0.1.1
Updated 1 month, 3 weeks ago
  • jalali
  • jalali
  • persian-calendar
  • shamsi
  • calendar
