node-red-contrib-jaeconnect 0.1.2
Node-RED nodes for jaeconnect: live events from your car (charging, locks, location, geo-fences), its status, and remote commands such as lock, climate and charging.
npm install node-red-contrib-jaeconnect
Node-RED nodes for jaeconnect: react to what your car does, read its status, and send it commands from your flows.
Node-RED with three jaeconnect flows: lock the car two minutes after it's unlocked, send a message when charging finishes, and warm the car on cold weekday mornings
Node What it does
car event A message for each event: charging started, stopped or completed, locked, unlocked, status changed, location changed, arrived at or left a geo-fence, a command finished.
car status When a message arrives, reads a car's status (battery, range, charging, locks, doors, windows, climate, seats, tyres), its location, its details or its schedules, or lists your cars.
car command When a message arrives, sends a command (lock, unlock, start climate, start charging, open windows, seat heating…) and waits for the car's answer.
Events come over one connection that Node-RED opens to jaeconnect, so nothing needs to reach your Node-RED from the internet: no port forwarding, tunnel or public address, unlike a webhook. If the connection drops, it reconnects and picks up the events it missed (jaeconnect keeps the last 15 minutes).
In Node-RED, open Manage palette → Install, search for node-red-contrib-jaeconnect and install it. Or, in your Node-RED folder (usually ~/.node-red):
It needs Node-RED 3.0 or later and Node.js 18 or later.
Set up
  1. On jaeconnect, open Apps and tokens and create a personal access token. Give it only what your flows need: read for events and status, location for positions and geo-fences, control for commands. You can limit it to one car.
  2. Drag a car event node onto a flow, open it, and add an account: paste the token and press Check the token. It lists the cars the token can see.
  3. Choose a car and the events you want, wire it to a debug node, and deploy.
Import → Examples → node-red-contrib-jaeconnect → Getting started has a flow showing all three nodes, including how to catch a failed command.
Messages
car event sends:
Property
msg.topic The event type, e.g. vehicle.charging_started. Route on it with a switch node.
msg.payload What the event carries: the car's status for status, charging and lock events; the position for vehicle.location_changed; the geo-fence for arrivals and departures; the command for command.completed.
msg.vehicle_id The car (null for billing.* events, which apply to the whole account).
msg.event The whole event: id, type, created_at, vehicle_id, data.
car status and car command take, when the node doesn't set them:
Property
msg.vehicle_id The car. With no car in the node or the message, a token that sees one car uses it.
msg.command (command) The command, e.g. lock or start_climate.
msg.payload (command) Options: temperature_c, duration_minutes, seat (driver, passenger, rear_left, rear_right) and level (0 to 3). Only the options the command takes are sent.
msg.refresh (status) true asks the car service now instead of using the last reading.
They send what jaeconnect returned in msg.payload.
When something goes wrong
A failed call or command goes to a catch node rather than the output. msg.problem.code says why, for example:
code
vehicle_unreachable The car didn't answer in time.
command_not_supported That car doesn't have that command.
close_sunroof_first This car's sunroof must close between vented and fully open.
location_sharing_off Location sharing is off for the car in jaeconnect.
scope_missing The token doesn't have the access the node needs.
subscription_required The account has no active subscription.
The developer docs list every command, event and error: sign in to jaeconnect, then open Developers.
Issues
Report a problem or ask for a feature in Issues, or email [email protected].
Licence
MIT
Version: 0.1.2
Updated 3 days ago
  • jaeconnect-account
  • jaeconnect-event
  • jaeconnect-status
  • jaeconnect-command
  • jaeconnect
  • car
  • ev
  • electric vehicle
  • charging
  • home automation
