node-red-contrib-jacdac 1.2.14
Microsoft Jacdac for Node-Red
npm install node-red-contrib-jacdac
Node-RED Jacdac Node
Node-RED nodes to talk to Jacdac.
Jacdac is a bus-based plug-and-play hardware and software stack for microcontrollers and their peripherals. Jacdac is primarily designed for “modular electronics” scenarios that support rapid prototyping, creative exploration, making and learning through physical computing. Jacdac is designed to be cheap, flexible and extensible.
The nodes connect to a Jacdac bus via a USB and allow to listen for events or sensor readings.
A rendering of a bus of Jacdac devices
Use Palette manager in node-red or run the following command in your Node-RED user directory - typically ~/.node-red
Jacdac hardware
In order to connect to Jacdac modules, you will need to connect to a USB module or a SPI bridge.
jacdac-event
This node listens for Jacdac events and send them in the payload. You can browse the services specification catalog to discover which events are available.
jacdac-report
This node reads Jacdac registers and send them in the payload. You can browse the services specification catalog to discover which registers are avilable are available.
By default, the node looks for sensor reading, value and intensity registers. But you can override this behavior by customizing the register filters by name or code.
jacdac-command
This node sends Jacdac commands to services. The results of command can be inferred from the content of the registers.
You can browse the services specification catalog to discover which commands are available and how their payload should be formatted. The payload can either be a number, string or boolean for simple t ypes. Or an array or JSON object for complex requests.
Acknoledgments
This repo was built using the node-red TypeScript starter.
Contributing
This project welcomes contributions and suggestions. Most contributions require you to agree to a Contributor License Agreement (CLA) declaring that you have the right to, and actually do, grant us the rights to use your contribution. For details, visit https://cla.opensource.microsoft.com.
When you submit a pull request, a CLA bot will automatically determine whether you need to provide a CLA and decorate the PR appropriately (e.g., status check, comment). Simply follow the instructions provided by the bot. You will only need to do this once across all repos using our CLA.
This project has adopted the Microsoft Open Source Code of Conduct. For more information see the Code of Conduct FAQ or contact [email protected] with any additional questions or comments.
Trademarks
This project may contain trademarks or logos for projects, products, or services. Authorized use of Microsoft trademarks or logos is subject to and must follow Microsoft's Trademark & Brand Guidelines. Use of Microsoft trademarks or logos in modified versions of this project must not cause confusion or imply Microsoft sponsorship. Any use of third-party trademarks or logos are subject to those third-party's policies.
Version: 1.2.14
Updated 5 years, 1 month ago
Rating: 5.0 2
67 in the last week
  • jacdac-report
  • jacdac-event
  • jacdac-command
  • jacdac
