node-red-contrib-issurmelacha 1.1.1
A Filter for Node-Red to divide the flow when an Issur melacha is in effect
npm install node-red-contrib-issurmelacha
Overview
Issur Melacha is a simple filter which will output an incoming msg to one of two different outputs depending if an Issur Melacha (on Jewish Holidays and Shabbet) is in effect.
Options
Lat (required)
The Latitude to calculate the Zmanim.
Lon (required)
The Longitude to calculate the Zmanim.
Diaspora
Whether to apply Zmanim for the Diaspora (2 days on Holidays).
Start Offset
You can add a custom offset (in minutes) calculated on Sunset when the Zman for Issur Melacha starts (can be either positive or negative), the default is at Sunset.
End Offset
You can add a custom offset (in minutes) calculated on Sunset when the Zman for Issur Melacha ends (can be either positive or negative), the default is 72 min after Sunset.
Repeat msg
While an Issur Melacha is in effect the msg can be repated by a preset interval.
Version: 1.1.1
Updated 2 years, 8 months ago
Rating: 3.0 2
1 in the last week
  • issur-melacha
  • Shabbat
  • Shabbos
  • Issur melacha
