node-red-contrib-ipgeolocation 1.0.0
Node-RED nodes for the IPGeolocation.io v3 API: IP geolocation, security and threat intelligence (VPN, proxy, and TOR detection), abuse contacts, ASN lookup, bulk IP processing, timezone, astronomy, and user-agent parsing.
npm install node-red-contrib-ipgeolocation
Node-RED nodes for the IPGeolocation.io v3 API: IP geolocation, security and threat intelligence, VPN and proxy detection, abuse contacts, ASN lookup, bulk IP processing, timezone, astronomy, and user-agent parsing.
npm version npm downloads Node-RED Node.js License: MIT
A complete, production-ready set of Node-RED IP geolocation nodes. Look up the country, city, latitude, and longitude of any IP address or domain, score IPs for proxy, VPN, TOR, and bot risk, resolve ASN and abuse-contact data, parse user-agent strings, and fetch timezone and astronomy data, all from low-code Node-RED flows.
Table of contents
  • Single IP geolocation: resolve country, region, city, latitude, longitude, currency, and timezone for any IPv4, IPv6, or domain.
  • Bulk IP geolocation: process up to 50,000 IP addresses in one request.
  • IP security and threat intelligence: detect proxy, VPN, TOR, bot, and threat scores for fraud prevention and access control.
  • Bulk security lookup: score large IP lists in a single call.
  • Abuse contact lookup: retrieve the abuse email, phone, and owning organization for an IP.
  • ASN lookup: resolve Autonomous System details by IP or AS number.
  • Timezone API: get timezone data by name, IP, coordinates, city, IATA code, ICAO code, or UN/LOCODE.
  • Astronomy API: sunrise, sunset, moonrise, moonset, twilight phases, moon phase, and solar and lunar positions by coordinates, address, or IP.
  • User-agent parser: identify browser, device, OS, and engine from a user-agent string.
  • Developer friendly: dynamic msg, flow, and global inputs, an optional dedicated error output, automatic retries with exponential backoff, secure credential storage, and per-request credit reporting.
Quick start
# In your Node-RED user directory (usually ~/.node-red)
  1. Restart Node-RED.
  2. Drag the ipgeo lookup node onto the canvas (find it under the IPGeolocation palette category).
  3. Open the node, click the pencil next to API Config, and paste your free IPGeolocation.io API key.
  4. Wire an inject node in and a debug node out, then deploy.
  5. Inject any IP string as msg.payload, for example 8.8.8.8, and read the geolocation result from the debug panel.
That is the whole loop: inject an IP, get structured location data back.
Requirements
Requirement Version
Node-RED >= 2.0
Node.js >= 14.0
IPGeolocation.io API key Free tier works (sign up)
Palette Manager (recommended)
  1. Open Node-RED.
  2. Go to Menu > Manage palette > Install.
  3. Search for node-red-contrib-ipgeolocation.
  4. Click Install.
npm
Restart Node-RED. All ten nodes appear under the IPGeolocation category in the palette.
Configuration: API key
Every functional node references a shared ipgeo config node that holds your API key. The key is stored as an encrypted Node-RED credential and is never written into exported flow JSON.
  1. Drag any IPGeolocation node onto the canvas.
  2. Double-click it, then click the pencil icon beside API Config.
  3. Enter a Name and paste your API Key.
  4. Click Add, then Done.
Reuse the same config node across every IPGeolocation node so you manage one key in one place.
How the nodes work
These conventions apply to all nine functional nodes.
Dynamic input. Any IP, coordinate, or value can be a static string or read at runtime from a msg, flow, or global property. One configured node can serve many different inputs.
Two outputs by default. Each node ships with two outputs:
  • Output 1 (success): the API result, written to the configured property (default msg.payload).
  • Output 2 (error): the original msg with a structured msg.error attached.
Uncheck Use second output to collapse to a single output and handle failures flow-wide with a standard Catch node.
Response shaping. Most nodes expose Fields (return only the listed dot-notation paths) and Excludes (drop listed paths) so you can trim large responses, for example location.city,location.country_name or security.threat_score.
Credit reporting. Every successful response sets msg.ipgeo_credits to the number of API credits the request consumed.
Node reference
Node Endpoint Purpose
ipgeo-config n/a Shared API key credential
ipgeo-lookup GET /v3/ipgeo Single IP or domain geolocation
ipgeo-bulk POST /v3/ipgeo-bulk Bulk geolocation, up to 50,000 IPs
ipgeo-security GET /v3/security Single-IP security and threat data
ipgeo-bulk-security POST /v3/security-bulk Bulk security, up to 50,000 IPs
ipgeo-abuse GET /v3/abuse Abuse contact details
ipgeo-asn GET /v3/asn ASN details by IP or AS number
ipgeo-timezone GET /v3/timezone Timezone by name, IP, coords, city, IATA, ICAO, UN/LOCODE
ipgeo-astronomy GET /v3/astronomy Sun and moon data
ipgeo-useragent GET /v3/user-agent User-agent parsing
ipgeo-lookup: single IP geolocation
Resolves a single IPv4, IPv6, or domain. Leave the IP blank to look up the caller's own IP.
Option Description Default
IP / Domain Static value or msg / flow / global property empty (caller IP)
Include Optional data modules to add none
Fields / Excludes Restrict or trim the response all
Language Response language en
User-Agent header Forward a UA string as a request header off
Output to Destination property msg.payload
Include modules:
Module Extra credits Adds
security +2 Proxy, VPN, TOR, bot, threat score
abuse +1 Abuse contact (email, phone, org)
user_agent 0 Parsed user-agent
geo_accuracy 0 Accuracy radius and confidence
dma_code 0 US Designated Market Area code
hostname 0 PTR from local database
liveHostname 0 Live DNS PTR lookup
hostnameFallbackLive 0 Database first, then live DNS
Set msg.ipgeo_include upstream to override the include list per message.
ipgeo-bulk: bulk IP geolocation
Sends up to 50,000 IPs or domains in one POST.
  • Input: msg.payload as a string array (["1.2.3.4", "example.com"]) or a comma-separated string, which is split automatically.
  • Output: an array of result objects in input order. Invalid or private entries come back as { "message": "..." }.
// Keep only successfully resolved results
const resolved = msg.payload.filter(r => r.ip);
ipgeo-security: IP security and threat intelligence
Single-IP risk lookup: proxy, VPN, TOR, and bot detection plus a threat score, useful for fraud checks, login protection, and access control. Supports Fields and Excludes.
ipgeo-bulk-security: bulk IP security
Bulk version of the security lookup, up to 50,000 IPs. Input handling matches ipgeo-bulk. When some entries cannot be scored, the node summarizes them:
Property Set when Meaning
msg.ipgeo_invalid_count an entry has no security object count of invalid entries
msg.ipgeo_invalid_messages as above the invalid entries' messages
Both are removed from msg when every entry is valid.
ipgeo-abuse: abuse contact lookup
Returns the abuse-contact record for an IP, such as abuse.emails, abuse.phone_numbers, and the owning organization. Supports Fields and Excludes.
ipgeo-asn: ASN lookup
Looks up Autonomous System details. The Query type selects what gets sent:
Query type Sends Notes
auto neither ip nor asn API infers from context
ip ip=<value> resolve the ASN behind an IP
asn asn=<number> an AS prefix is stripped automatically (AS15169 becomes 15169)
Supports an Include list (peers, downstreams, upstreams, and more), overridable per message via msg.ipgeo_include, plus Fields and Excludes.
ipgeo-timezone: timezone API
Seven lookup modes:
Mode Parameter sent Example
Timezone name tz America/New_York
IP address ip 8.8.8.8
Address / city location Paris, France
Coordinates lat + long 48.8566, 2.3522
IATA airport iata CDG
ICAO airport icao LFPG
UN/LOCODE location FRPAR
Returns INVALID_INPUT when the value required for the chosen mode is missing.
ipgeo-astronomy: sun and moon data
Returns sunrise, sunset, moonrise, moonset, twilight phases (civil, nautical, astronomical, plus blue hour and golden hour), solar noon, day length, moon phase, illumination, and live solar and lunar positions.
The location can be derived four ways, selected by the Look up by mode:
Mode Sends Notes
coords lat + long decimal degrees; both required
location location address, preferably a city, for example New York, USA
ip ip any IPv4 or IPv6 address; adds an ip field to the response
auto nothing the API uses the caller's IP
When more than one is supplied, the API prefers coordinates, then location, then IP. Coordinates and location modes return INVALID_INPUT when their value is missing.
Optional parameters (all modes):
Option Parameter Description
Date date YYYY-MM-DD; defaults to today at the location
Time zone time_zone IANA name; converts all event times into this zone
Elevation elevation meters above sea level, 0 to 10000; defaults to 0
Language lang language for the location object (paid plans)
The response nests results under an astronomy object alongside a location object, so read values such as payload.astronomy.sunrise and payload.location.city.
ipgeo-useragent: user-agent parser
Parses a user-agent string into browser, device, OS, and engine. The UA is sent to the API as a request header rather than a query parameter.
Ideal in HTTP-in flows: point the UA source at msg.req.headers.user-agent (the default) to parse each visitor's browser automatically. An empty UA returns INVALID_INPUT.
Message properties
Property Direction Type Description
ipgeo_credits output number Credits consumed by the request
ipgeo_include input string Per-message override of the include list, where supported
ipgeo_invalid_count output number Bulk-security: entries with no security result
ipgeo_invalid_messages output array Bulk-security: messages for invalid entries
error output object On the error output: { code, message, status, body }
Error handling and retries
On failure, the node sets msg.error with a typed code, a readable message, the HTTP status where applicable, and the raw response body.
Code Cause
NO_API_KEY Config node missing or key empty
BAD_REQUEST Invalid parameters (HTTP 400)
AUTH_FAILED Invalid or missing API key (HTTP 401)
FORBIDDEN Plan restriction or origin not whitelisted (HTTP 403)
NOT_FOUND Endpoint or resource not found (HTTP 404)
VALIDATION Validation error (HTTP 422)
LOCKED Key locked, quota exceeded, or account suspended (HTTP 423)
RATE_LIMITED Too many requests (HTTP 429)
SERVER_ERROR API internal error (HTTP 500)
HTTP_ERROR Any other non-2xx status
TIMEOUT Request timed out
NETWORK_ERROR DNS or connectivity failure
NO_RESPONSE Request sent but no response received
INVALID_INPUT / INVALID_MODE Missing or malformed node input
TOO_MANY_IPS Bulk request over the 50,000-IP limit
Automatic retries. Transient failures (HTTP 429, 500, 502, 503, 504, timeouts, and network errors) are retried up to 3 times with exponential backoff (500 ms, 1 s, 2 s). For HTTP 429, the Retry-After header is honored when present. The default request timeout is 10 seconds, and 30 seconds for the bulk endpoints.
Example flows
The package bundles ready-to-import examples, one per functional node:
Example Demonstrates
01 - Single IP Lookup ipgeo-lookup
02 - Bulk IP Lookup ipgeo-bulk
03 - IP Security Lookup ipgeo-security
04 - Bulk IP Security ipgeo-bulk-security
05 - Abuse Contact Lookup ipgeo-abuse
06 - ASN Lookup ipgeo-asn
07 - Timezone Lookup ipgeo-timezone
08 - Astronomy (Sun & Moon) ipgeo-astronomy
09 - User-Agent Parser ipgeo-useragent
To import: Menu > Import > Examples, then choose node-red-contrib-ipgeolocation and pick a flow. Each example has an inject trigger, the node wired to result and error debug nodes, and a placeholder config node. Point that config node at your own API key before deploying.
Recipes
Override the include list per message
// In a Function node upstream of ipgeo-lookup or ipgeo-asn
msg.ipgeo_include = "security,abuse";
Geolocate the visitor in an HTTP flow
Configure ipgeo-lookup with IP / Domain as a msg property pointing at req.headers['x-forwarded-for'] (behind a proxy) or req.connection.remoteAddress (direct).
Block proxies and VPNs at the edge
Run incoming IPs through ipgeo-security, then use a Switch node on payload.security.is_proxy or the threat score to drop or flag risky traffic before it reaches your application.
Return compact bulk responses
On ipgeo-bulk, set Fields to location.city,location.country_name,asn.organization, optionally add Include security, and Excludes security.threat_score to return only the data you need per IP.
API credits
Endpoint or module Credits
Single IP lookup (base) 1
+ security module +2
+ abuse module +1
Bulk lookup 1-4 per valid IP
Security / bulk-security 2 per valid IP
ASN, Abuse, Timezone, User-Agent, Astronomy 1
Each node reports the real charge in msg.ipgeo_credits. See the Credits Usage Guide for current pricing.
Development and testing
npm install      # install dependencies
npm test         # run the mocha test suite
npm run coverage # run tests with an HTML and text coverage report
Tests use mocha, node-red-node-test-helper, should, and nock, with all HTTP fully mocked so the suite runs offline with no live API calls. Specs live in test/**/*_spec.js and cover the shared API client, the helpers, every node, and the bundled example flows.
Frequently Asked Questions
How do I get an IPGeolocation.io API key? Sign up for a free account at app.ipgeolocation.io/signup. The free tier provides enough usage to evaluate every node included in this package.
Is the API key safe in exported flows? Yes. The API key is stored as an encrypted Node-RED credential on the ipgeo-config node and is never included in exported flow JSON.
Can I look up many IP addresses at once? Yes. Use the ipgeo-bulk node for geolocation lookups or the ipgeo-bulk-security node for security and threat analysis. Both support processing up to 50,000 IP addresses in a single request.
How do I detect VPNs, proxies, or TOR exit nodes? Use the ipgeo-security node, or enable the security include module when using ipgeo-lookup. The response includes fields indicating proxy usage, VPN detection, TOR exit node status, and other threat-related information.
Does it work behind a reverse proxy? Yes. Read the client IP address from req.headers['x-forwarded-for'] and pass it to ipgeo-lookup as a dynamic msg input to geolocate the original client.
What happens when I hit a rate limit? The nodes automatically retry requests using exponential backoff and honor the Retry-After response header when provided. If the rate limit persists, the operation fails with a RATE_LIMITED error on the error output.
MIT (c) IPGeolocation.io
Links
Version: 1.0.0
Updated 5 months ago
  • ipgeo-config
  • ipgeo-lookup
  • ipgeo-bulk
  • ipgeo-security
  • ipgeo-bulk-security
  • ipgeo-abuse
  • ipgeo-asn
  • ipgeo-timezone
  • ipgeo-astronomy
  • ipgeo-useragent
  • ipgeolocation
  • geolocation
  • ip-lookup
  • timezone
  • astronomy
  • user-agent
  • security
  • ip-intelligence
