node-red-contrib-iotextra 1.2.0
A set of Node-RED nodes to control and monitor IoTextra hardware modules.
npm install node-red-contrib-iotextra
⚡ node-red-contrib-iotextra
Connect Node-RED to IoTextra mezzanine modules—stackable I/O boards for digital relays, GPIO inputs, and analog measurements. This package adds three custom nodes that speak MQTT to your IoTextra hardware, so you can build dashboards, automations, and integrations without writing firmware.
IoTextra modules run on the IoTflow framework (MicroPython firmware on an IoTsmart or IoTbase with compatible SoM). Once your device is on the network and publishing to an MQTT broker, these nodes let you read inputs, drive outputs, and stream analog values directly in your flows.
Included nodes
All three nodes appear in the network category in the Node-RED editor. Each node is configured with an MQTT broker, a base topic (matching your device's MQTT_BASE_TOPIC), and a channel number.
iotextra-input — digital input
Subscribes to digital input changes on a selected channel (pins AP0–AP7 on the module). When the firmware detects a state change on the physical input, it publishes 1 (ON) or 0 (OFF). This node forwards that value as msg.payload ('1' or '0').
iotextra-output — digital output
Sends ON/OFF commands to a digital output channel. Accepts msg.payload as true/false or 1/0, publishes the command over MQTT, and emits a confirmation when the device acknowledges the new state ('1' or '0' on the state topic).
iotextra-analog — analog input
Subscribes to analog readings from single-ended to differential ADC channels (e.g. A0–A1, A2–A3 on Analog and Combo modules). The firmware publishes converted voltage or current as a numeric string (e.g. "3.124"). Each message becomes msg.payload for use in gauges, charts, or logic nodes.
Tip: For full wiring, firmware, and broker setup, see the setup guide in the IoTflow repository.
Compatible hardware
These nodes work with IoTextra mezzanine modules connected via the IoTbase or IoTsmart HOST connector and running IoTflow:
Family Description
Digital IoTextra Digital inputs and outputs
Analog IoTextra Differential or Single-ended ADC channels (voltage/current)
Combo IoTextra Digital and analog I/O on one module
You will also need an IoTbase with compatible SoM or IoTsmart module, and MQTT broker access on your network.
Via Node-RED Manage Palette
  1. Open Node-RED (http://127.0.0.1:1880 or your instance URL).
  2. Menu → Manage palette → Install tab.
  3. Search for node-red-contrib-iotextra and install.
  4. Restart Node-RED if prompted.
Via npm
From your Node-RED user directory (often ~/.node-red):
Restart Node-RED after installation.
MQTT topics reference
Topics use <MQTT_BASE_TOPIC> as the root (configured on your device, e.g. home/iotextra).
Category MQTT topic Description Values
Device status <MQTT_BASE_TOPIC>/status Device online/offline online / offline
Digital input <MQTT_BASE_TOPIC>/input/<channel> Input channel state 1 (ON) / 0 (OFF)
Digital output (command) <MQTT_BASE_TOPIC>/output/<channel>/set Set output state 1 (ON) / 0 (OFF)
Digital output (confirm) <MQTT_BASE_TOPIC>/output/<channel>/state Confirmed output state 1 (ON) / 0 (OFF)
Analog channel <MQTT_BASE_TOPIC>/analog/<channel> ADC reading Numeric string (e.g. "3.142") — unit is V or mA per channel config
Ensure the base topic in each node matches your device configuration.
Links
Full compatibility table
The following table shows all IoTextra modules and their Node-RED flow availability:
IoTextra Node-RED Compatibility
IoTextra Module Node-RED Blynk
Input Example Example
Relay2 Example Example
SSR Small Example Example
MOSFET2 Example Example
Quadro 🔲 🔲
Octal Example Example
Octal2 Example Example
Octal3 🔲 🔲
Analog Example Example
Analog2 🔲 🔲
Analog3 Example Example
Combo 🔶 Example
Combo2 🔲 🔲
Legend:
  • Example — available, click to open
  • 🔶 — Coming Soon
  • 🔲 — Planned
MIT — see LICENSE.
Version: 1.2.0
Updated 5 months, 3 weeks ago
110 in the last week
  • iotextra-input
  • iotextra-output
  • iotextra-analog
  • iot
  • iotextra
  • mqtt
  • relay
  • gpio
  • adc
  • analog
  • MTH LLC
