node-red-contrib-iota-mam 4.1.2
Updated on 18/04/2019
npm install node-red-contrib-iota-mam
Node-red IOTA MAM module
Requirements
Install node-red globally and install ui packages and the sensortag package
sudo npm install -g --unsafe-perm node-red
in your ~/.node-red installation directory type:
npm install node-red-dashboard node-red-contrib-sensortag node-red-contrib-simple-gate
IOTA-MAM module installation
Run the following command in your NODE-RED install
Two different function nodes are now available for
MAM publish (=upload data to tangle) and MAM fetch (=download data from tangle)
Drag MAM function node into a flow and wire it accordingly
CONFIG - At first use the Node-red sample file included !!!
Find included in the root directory a flow sample file called flows_Air.json It provides you with an initial config for ROOT (mamFetch) and a devnet IOTA node.
Also you can switch to the newly added node-red dashboard to publish/fetch data and see a live visualization.
If you have any issues regarding this module, please test with this file and give a clear issue description. Thank you!
MAM fetch
Start deploying a single 'mamFetch function node'. Set its root property (root = "your MAM_ROOT")
wire this node's output to -> any output ( e.g. a chart displaying your msg.payload)
try with NHNRYMKA9RLTPLQNWFRHKJGVUXAAPBVYBG9LOXFPKDWVKOUIDILEVCBNGLOPYZEGZMEFSCOOVCKNOPSNB)
This should hold a non-encrypted (public) data packet sequence. (as of 18 april 2019)
MAM publish
Deploy a sensorTag as input data source. (Please report an issue https://gitlab.com/ouya/node-red-contrib-iota-mam/issues if you encounter problems with other sensors. We are looking to support all general sensors in the near future)
wire its output to -> mamPublish node
and wire this node's output to an -> (optional) output for logging
The MAM publish now operates in a loop:
  1. collects input data from sensorTag (can be a mix of temperature, lux etc)
  2. and immediately uploads the 1st data packet to the tangle
loop: ... now waiting for the bundle and its transactions to be confirmed on the tangle, it aggregates all incoming sensor tag data into a data array ... upon MAM confirmation of the previous bundle, it sends this aggregated data array to the tangle ... now waiting again for bundle confirmation
Rate limits
on many public nodes you might have rate limits, so better use your own custom node, or make sure the node you connect to has the capacity to handle your sensor data traffic.
Version: 4.1.2
Updated 8 years, 2 months ago
216 in the last week
  • mamFetch
  • mamPublish
  • mam
  • iota
  • sensortag
  • sensornode
