node-red-contrib-iota-lib 0.2.6
Node Red integration whith IOTA
npm install node-red-contrib-iota-lib
Node-Red IOTA library module ( in progress )
Requirements
Install node-red globally and install ui packages
sudo npm install -g --unsafe-perm node-red
IOTA-lib module installation, in your ~/.node-red installation directory type:
Run the following command in your NODE-RED install npm install node-red-contrib-iota-lib
There are functions node available to do IOTA transactions and MAM Transactions.
iotasearch : to find addresses, tags or bundles in The tangle; iotatransactions: to find hashes in The tangle; iotanewaddress: generate new address from your seed; iotasendtransfer: send iota tokens from your seed to an address; iotagetinputs: to know your balance iota tokens; iotaConverter: to manager trytes and trits conversions;
mamPublish: attach a message in the tangle; mamFetch: sears a mmesage from the tangle;
You can try a test flow from https://flows.nodered.org/flow/a9cc5f065684b3365a7a7a6087d96bfe
Version: 0.2.6
Updated 7 years, 2 months ago
59 in the last week
  • iotatransactions
  • iotasendtransfer
  • iotagetinputs
  • iotanewaddress
  • iota-server
  • mamPublish
  • mamFetch
  • iotaConverter
  • iotasearch
  • iota
  • thetangle
  • tangle
  • mam
