node-red-contrib-iot4h 1.2.3
Node Red nodes for programming education in IoT4H workshops.
npm install node-red-contrib-iot4h
IoT4H GrovePI Nodes
This project was developed and tested on Raspberry Pi 4 with GrovePi+ on Debian Bookworm (Rasperry Pi OS 12), Node 18.19.1 and npm 10.2.4.
  1. npm install node-red-contrib-iot4h (in /home/pi/.node-red/node_modules/)
  2. node-red-restart
msg Properties
See https://nodered.org/docs/user-guide/messages
Usually, the "value" of a message is stored in its payload field. To make integration with other nodes easy, the payload of a sensor message only contains its values, all additional information is stored in other properties.
If a sensor returns multiple values (e.g. temperature and humidity), msg.payload is an array of these values.
In addition to that, msg.valueTypes is an array of value type specifications {unit: ..., name: ..., type: ...}.
This additional information is used for displaying sensor values on the LCD and when sending datapoints to the OpenDash platform.
Nodes List
  1. Save Variable
  2. Load Variable
  3. Timestamp
  4. Comparison Filter
  5. Moving Average
  6. Array Index
  7. Gate
  8. Gate Switch
  9. Transmission TB telemetry
  10. Transmission TB attributes
  11. Retrieval TB telemetry
  12. Retrieval TB attributes
Version: 1.2.3
Updated 1 year, 1 month ago
6 in the last week
  • saveVariable
  • loadVariable
  • timestamp
  • comparisonFilter
  • movingAverage
  • arrayIndex
  • gate
  • gate-switch
  • thingsboard-transmission-telemetry
  • thingsboard-transmission-attributes
  • thingsboard-retrieval-telemetry
  • thingsboard-retrieval-attributes
  • server-config
  • iot
  • IoT4H
