node-red-contrib-iobroker 1.5.2
Node-RED nodes for ioBroker integration via WebSocket. Provides input, output, get, object management, historical data access, and live log monitoring capabilities.
npm install node-red-contrib-iobroker
Node-RED Nodes for ioBroker Integration
npm version Pre-Release License Node-RED Downloads Known Vulnerabilities Donate
🌍 Languages: πŸ‡ΊπŸ‡Έ English | πŸ‡©πŸ‡ͺ Deutsch
External Node-RED integration nodes for ioBroker communication. NOT an ioBroker adapter - standalone package for external Node-RED instances to connect with ioBroker via WebSocket.
πŸ€” Which Solution is Right for You?
πŸ“Š Decision Guide: ioBroker Node-RED Adapter vs. These Nodes
Scenario Use ioBroker Node-RED Adapter Use These External Nodes
🏠 Simple Home Setup βœ… Recommended ❌ Overkill
🏭 Installation on Appliances/PLCs ❌ Not possible βœ… Recommended
⚑ High Performance Needs ❓ Shared resources ⚠️ May be beneficial
πŸ”„ Node-RED Updates/Maintenance ❓ Tied to ioBroker βœ… Recommended
πŸ“Š Advanced Features ❓ Limited βœ… Recommended
🎯 Use ioBroker Node-RED Adapter for:
  • Simple home automation with basic requirements
  • One-click installation is priority
  • Minimal configuration effort desired
  • Shared hosting is acceptable
πŸš€ Use These External Nodes for:
  • Appliances and PLCs (Wago, Beckhoff, etc.) with Node-RED
  • High-performance applications (may benefit from dedicated resources)
  • Specialized features like history data, logs
  • Latest Node-RED versions immediately (no adapter dependency)
  • Full Node-RED configuration access (all settings & modules)
  • Dedicated resources and potential for better error isolation
πŸš€ Quick Start
Install the nodes through the Node-RED Palette Manager:
  1. Open Node-RED interface
  2. Click on hamburger menu (three lines) β†’ Manage palette
  3. Go to "Install" tab
  4. Search for "node-red-contrib-iobroker"
  5. Click "Install" button
Basic Setup
  1. Create dedicated Admin adapter instance (recommended):
    • Install second Admin adapter instance in ioBroker
    • Configure on different port (e.g., 8091)
    • Use exclusively for Node-RED connections
  2. Configure iob-config node with your dedicated instance:
    • Host: hostname or IP address
    • Port: 8091 (your dedicated Admin instance)
    • Authentication: Optional username/password
  3. Use the nodes in your flows
πŸ—οΈ Architecture Overview
Node-RED to ioBroker Architecture
The diagram shows the recommended architecture with a dedicated Admin adapter instance for Node-RED connections, separate from the main Admin interface used by regular users.
πŸ“¦ Available Nodes
Node Purpose Example Use Documentation
WS ioB in Subscribe to state changes Monitor temperature sensors πŸ“– Details
WS ioB out Send values to states with auto-creation Control lights, switches πŸ“– Details
WS ioB get Read current state values Get sensor readings on demand πŸ“– Details
WS ioB getObj Retrieve object definitions with enum assignments Access device metadata with room/function info πŸ“– Details
WS ioB setObj Write/modify object definitions Update instance settings, change object properties πŸ“– Details
WS ioB delObj Delete object definitions (optional recursive) Remove obsolete devices, channels, or states πŸ“– Details
WS ioB inObj Monitor object changes Track adapter installations πŸ“– Details
WS ioB history Access historical data Energy consumption analysis πŸ“– Details
WS ioB log Live log monitoring System health monitoring πŸ“– Details
WS ioB sendTo Send commands to ioBroker adapters Telegram notifications, database queries πŸ“– Details
πŸ”§ Configuration
Recommended Setup: Dedicated Admin Instance
Why use a dedicated Admin instance?
  • Isolates Node-RED traffic from main admin interface
  • Prevents conflicts with regular admin usage
  • Avoids duplicate events when the Admin interface is open in browser
  • Allows custom security settings
Setup Steps:
  1. Install second Admin adapter instance in ioBroker:
    • Go to Adapters β†’ Admin β†’ Add Instance
    • Configure custom port (e.g., 8091)
    • Enable/disable features as needed
  2. Configure security for Node-RED access:
    • Create dedicated user for Node-RED
    • Set appropriate permissions
Server Configuration (iob-config)
Connection Settings:
  • Name: Descriptive name for your ioBroker instance
  • Host: IP address (e.g., 192.168.1.100) or hostname (e.g., iobroker.local)
  • Port: Your dedicated Admin instance port (e.g., 8091)
  • Use SSL: Enable for HTTPS/WSS connections
  • Allow self-signed certificates: Enabled by default for compatibility; disables certificate and hostname verification. Disable it when the server uses a certificate issued by a trusted CA.
  • Default profile: If multiple iob-config profiles exist, mark one as default for automatic selection in the editor
Authentication Settings:
  • No Authentication (default): Leave username/password empty
  • OAuth2: Enter valid ioBroker username/password
If only one iob-config profile exists, it is selected automatically. If multiple profiles exist, only the profile marked as default is selected automatically.
Alternative Adapter Options
If you prefer not to use a Admin instance:
  • WebSocket adapter (port 8084) - WebSocket adapter for external connections
  • Web adapter (port 8082) - Requires "Use pure web-sockets" option enabled
⚠️ Important Limitations with Alternative Adapters:
  • WS ioB log node does not work with WebSocket or Web adapter (requires Admin adapter)
πŸ“š Additional Resources
πŸ“„ License
MIT
Version: 1.5.2
Updated 2 weeks, 3 days ago
Rating: 5.0 5
41 in the last week
  • iobin
  • iobout
  • iobinobject
  • iobget
  • iobgetobject
  • iobsetobject
  • iobdelobject
  • iobhistory
  • ioblog
  • iobsendto
  • iob-config
  • iobroker
  • smart-home
  • automation
  • websocket
  • home-automation
  • iot
  • smarthome
