node-red-contrib-intersystems-iris 0.0.2
node-red-contrib-intersystems-iris ========================
Node-RED node for InterSystems IRIS
Either use the Node-RED Menu - Manage Palette - Install, or run the following command in your Node-RED user directory - typically ~/.node-red
npm i node-red-contrib-intersystems-iris
Allows basic access to a InterSystems IRIS database.
This node uses the sql operation against the configured database.
By its very nature it allows SQL injection... so be careful out there...
The msg.topic must hold the query for the database, and the result is returned in msg.payload.
Typically the returned payload will be an array of the result rows.
It does not support paramaterized queries, yet.
msg.topic="INSERT INTO \"users\" (\"userid\", \"username\") VALUES ('36', 'some-user')"
msg.topic="SELECT \"userid\", \"username\" FROM \"users\""
Demo
To run own version of demo, it is possible to use docker compose. Just do
docker compose up --build -d
And after build and start, open link to Node-RED portal http://localhost:1880/
Demo flow file for manual installation is available here
Production flow
And dynamically updated Dashboard, which is avialable by link http://localhost:1880/ui/
