node-red-contrib-interactive-inject 1.2.2
A Node-RED node with an interactive slider or preset buttons rendered directly on the canvas for one-click value injection — no dashboard required
npm install node-red-contrib-interactive-inject
A Node-RED node that renders an interactive widget directly on the editor canvas — no dashboard required. Choose between a numeric slider or a set of preset buttons; either way, clicking or dragging injects a value straight into your flow.
interactive-inject node on the Node-RED canvas
  • Two modes selectable per node: Slider and Preset buttons
  • Slider mode — inline <input type="range"> embedded in the node body; drag the thumb or click the number and type directly; press Enter to commit or Escape to cancel
  • Preset buttons mode — configurable buttons rendered on the canvas; each button has a label and an arbitrary typed value (string, number, boolean, JSON, JSONata, …); hovering a button previews its value before you click
  • Configurable output property — write the injected value to any message property (default: msg.payload), including nested paths such as msg.data.value
  • Full message output (preset buttons) — optionally send the evaluated result as the entire msg object instead of a single property
  • Node status indicator — last injected value shown below the node after each injection
  • Auto-label presets — if a preset label is left blank, the value string is used as the label automatically
  • Configurable send behaviour (slider mode) — choose between injecting on release, while dragging (fires on every value change during drag), or never (button only)
  • JSONata output (slider mode) — optionally shape the injected message with a JSONata expression; the slider's live value is available as $value
  • Auto-collapse — optional: widget collapses to normal node height after 3 s of inactivity, expands on hover
  • Left-side inject button for manual triggering, like the built-in Inject node
  • Last value/selection persisted to flows.json — survives deploy and restart
  • Configurable label and topic for both modes
  • Works with Node-RED 3.x and above; no dependency on node-red-dashboard
Install from your Node-RED user directory (typically ~/.node-red):
Or via the Node-RED palette manager: search for interactive-inject.
  1. Drag the interactive inject node from the common category onto the canvas.
  2. Open the edit panel and choose a Mode: Slider or Preset buttons.
Slider mode
  • Drag the slider thumb to your desired value, or click the number display and type a value directly.
  • The Send option controls when injection happens: on release (default) injects once when you let go or press Enter; while dragging injects continuously as the value changes during a drag (and on Enter); never disables automatic injection so only the left-side button triggers it.
  • The Output option controls what gets written to the Property field: raw value (default) sends the plain number; JSONata expression evaluates an expression with the slider value bound to $value, letting you shape the payload — e.g. { "/Soc": $value }.
  • Click the button on the left side of the node to inject the current value manually at any time.
Preset buttons mode
  • Add one or more presets in the edit panel — give each a label and a value (any supported type). If you leave the label blank it defaults to the value string.
  • The buttons appear directly on the canvas; hover a button to preview its value, click to inject.
  • The last clicked preset is highlighted and re-injected when the left-side button is pressed.
  • Tick full msg on a preset to send the evaluated result as the entire message object (useful with JSON/JSONata presets that define the full message structure).
Output
Property Type Description
(configured property) any The injected value, written to the property set in the Property field (default: msg.payload)
msg.topic string The topic configured in the edit panel (empty string if not set)
msg.label string (Preset buttons mode only) The label of the clicked button
Common
Property Default Description
Topic (empty) Sets msg.topic on every injected message
Property payload The message property to write the injected value to (any path, e.g. data.value)
Mode Slider Choose between Slider and Preset buttons
Slider mode
Min 0 Minimum slider value
Max 100 Maximum slider value
Step 1 Increment between positions (decimals supported, e.g. 0.1)
Default 50 Value on first load
Send on release When to inject: on release — once when the thumb is released or Enter pressed; while dragging — on every value change during drag (and on Enter); never — button only
Output raw value raw value sends the plain number to the Property field; JSONata expression evaluates the expression below with the slider value bound to $value and writes the result to Property instead
Expr $value (Output: JSONata expression only) The JSONata expression to evaluate, e.g. { "/Soc": $value }
Preset buttons mode
Property Description
Presets Ordered list of buttons. Each entry has a Label (shown on the button; auto-filled from the value if left blank), a Value with a type selector (string, number, boolean, JSON, JSONata, …), and an optional full msg toggle
Widget behaviour
Auto-collapse false When enabled, the widget collapses to normal node height 3 s after the cursor leaves the node, and re-expands immediately on hover
Using the label in a JSONata preset value
When the value type is set to J: expression (JSONata), the button's label is available as the variable label. This lets you encode a parameter directly in the button name and reference it in the expression without duplication.
Example — button label 2000, value type JSONata:
{ "offset": $number(label) }
Produces msg.payload = { "offset": 2000 } and msg.label = "2000".
A more complete example — label now +2m: 5k, value type JSONata:
  "lowerLimit": -5000,
  "upperLimit": 5000,
  "duration": 900000,
  "executionTime": $millis() + 2 * 60 * 1000
Here the execution time is computed at the moment the button is pressed, so it always reflects the actual current time plus the offset.
Wrapping the value in a JSON object
To output { "/Temperature": 25 } instead of a plain number, set the slider's Output option to JSONata expression and enter:
{ "/Temperature": $value }
$value is bound to the slider's current value at the moment of injection — no downstream Change node required. See Import → Examples → node-red-contrib-interactive-inject → slider-jsonata-output in the Node-RED editor for a ready-made example.
If you're on an older version without the built-in Output option, the same result can be achieved with a separate Change node after this one (Action: Set, Target: msg.payload, Type: J: expression, Value: {"/Temperature": payload}) — see the basic-usage example below.
Additional examples are available under the same import path:
Example Description
slider-jsonata-output Slider using the built-in Output: JSONata expression option to wrap the value in a JSON key
basic-usage Slider with a separate Change node that wraps the value in a JSON key (pre-1.2.1 approach)
preset-buttons Preset buttons mode with string, number, boolean, and JSON value types
preset-jsonata-label Preset buttons with JSONata expressions that reference the button label via label
Development
# Install dependencies
npm install
# Compile TypeScript and copy HTML to dist/
npm run build
# Watch mode
npm run watch
# Run tests
npm test
The runtime node is in src/interactive-inject.ts; the editor template and canvas rendering are in src/interactive-inject.html.
MIT © Dirk-Jan Faber
Version: 1.2.2
Updated 5 months ago
Rating: 5.0 6
34 in the last week
  • interactive-inject
  • inject
  • slider
  • preset
  • buttons
  • interactive
  • canvas
  • jsonata
  • victron
