node-red-contrib-inspector 1.0.1
A Node-RED node to (de)activate a NodeJs code inspector session
npm install node-red-contrib-inspector
Buy my wife a coffee
Introduction to introspection
Inspector basics
Node-RED runs on top of NodeJs, which is a Javascript runtime that in turn runs on top of the Google Chrome V8 Javascript engine. The V8 engine contains a.o. an inspector which offers lots of technical features (code debugger, cpu profiler, memory profiler...). By starting NodeJs in debug mode, the V8 inspector can be accessed (by default on port 9229) from the outside via the Chrome Devtools protocol. This way third party tools (e.g. Google Chrome dev tools, Microsoft Visual Studio Code, ...) can debug and profile NodeJs applications. The V8 engine is written in C++, but fortunately NodeJs contains an Inspector module which is a Javascript wrapper around the V8 inspector.
architecture
Debug mode
To activate the inspector (and make it public accessible via the port), some extra startup parameters need to be passed to start in debug mode:
node  --inspect=127.0.0.1 --inspect-brk  /usr/bin/node-red
Note that the --inspect-brk is optional, to pauze the debugger automatically at the first statement of Node-RED. Which is only required when you want to debug the Node-RED startup code.
Disadvantages
Having to add startup command line parameters has some disadvantages. Indeed it is not always easy to change the Node-RED startup command:
  • When running Node-RED on Raspberry, the installation script prepares everything to run Node-RED as a Systemd background service. Works very well out of the box, so you don't want to start messing with that...
  • When you need to troubleshoot a Node-RED system that is live and not started previously in debug mode. And perhaps you don't want to restart it for some reason (e.g. high available, ...).
  • When running Node-RED inside a Docker container. The Node-RED Docker image starts Node-RED with a fixed startup command. Some time ago I have been investigating to fix that, but it was quite complex to get it done.
The solution
This node allows to activate the NodeJs inspector from within a Node-RED flow, without having to alter the Node-RED startup command. Which solves all the disadvantages that have been listed above:
new architecture
Node usage
The following example flow shows how to open and close the inspector:
flow
[{"id":"3add02d7.7df60e","type":"node-inspector","z":"f6f2187d.f17ca8","inputField":"payload","host":"0.0.0.0","portNumber":9229,"autoStart":false,"name":"","x":580,"y":380,"wires":[[]]},{"id":"8cf9f9cd.1a6a88","type":"inject","z":"f6f2187d.f17ca8","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"open_inspector","payloadType":"str","x":340,"y":380,"wires":[["3add02d7.7df60e"]]},{"id":"4b2a8ca1.de70e4","type":"inject","z":"f6f2187d.f17ca8","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"close_inspector","payloadType":"str","x":340,"y":440,"wires":[["3add02d7.7df60e"]]}]
Once the inspector is open, the host and port number will be displayed in the node status.
Now you can start debugging your Node-RED server flow. See this wiki for a tutorial, containing all the steps to start using the Chrome debugger.
Usage in a Docker container
When Node-RED is running in a Docker container, you will need to do only a few extra steps:
  1. An extra port mapping -p 9229:9229 need to be added to the standard Node-RED Docker command:
    docker run -it -p 1880:1880 -p 9229:9229 -v node_red_data:/data --name mynodered nodered/node-red
  2. Enter 0.0.0.0 in the "host" settings on this node's config screen. Indeed because the NodeJs inspector listens on the loopback interface, host localhost or 127.0.0.1 will not work (see here for more information).
Limitations
  • The code inspector can only be started this way, as soon as this node has been started by Node-RED. Which means it is not possible to debug the Node-RED startup code this way, which you need to achieve via the optional --inspect-brk startup command parameter flag.
  • I have only tested a single instance of this node in a flow. So not sure how it will behave if multiple nodes are added to a flow, and used simultaneously...
Node properties
Cmd field
Specify in which input message field the commands will be injected. The available commands are:
  • open_inspector: to open the inspector, and make it accessible via the specified port.
  • close_inspector: to close the inspector, and stop listening to the port.
Host
Specify on which host the NodeJs inspector has to listen for connections. The default port is localhost. But for example for a Docker container, the host needs to be 0.0.0.0.
Port
Specify on which port the NodeJs inspector has to listen for connections. The default port is 9229.
Autostart
When activated, the inspector will be activated automatically at flow startup. This can be useful e.g. for a development Node-RED system, which needs to be accessible for inspection all the time.
Of course the same effect can be achieved by a Trigger node, which injects automatically at startup an "open_inspector" message.
Troubleshooting
Via http://localhost:9229/json you can test whether the inspector is available on port 9229, because you should get a json result like this:
  "description": "node.js instance",
  "devtoolsFrontendUrl": "chrome-devtools://devtools/bundled/js_app.html?experiments=true&v8only=true&ws=localhost:9229/0c766b46-ad58-4f05-97f9-54d84cdcc9cb",
  "devtoolsFrontendUrlCompat": "chrome-devtools://devtools/bundled/inspector.html?experiments=true&v8only=true&ws=localhost:9229/0c766b46-ad58-4f05-97f9-54d84cdcc9cb",
  "faviconUrl": "https://nodejs.org/static/favicon.ico",
  "id": "0c766b46-ad58-4f05-97f9-54d84cdcc9cb",
  "title": "node_modules/node-red/red.js",
  "type": "node",
  "url": "file:///usr/src/node-red/node_modules/node-red/red.js",
  "webSocketDebuggerUrl": "ws://localhost:9229/0c766b46-ad58-4f05-97f9-54d84cdcc9cb"
Version: 1.0.1
Updated 5 years, 4 months ago
18 in the last week
  • node-inspector
  • nodejs
  • inspector
  • debug
  • v8
  • profile
  • profiling
  • chrome
