node-red-contrib-influxdb3-read 1.0.2
A Node-RED node for executing SQL queries against InfluxDB 3 using the HTTP API.
npm install node-red-contrib-influxdb3-read
A Node-RED node that allows querying InfluxDB 3 using SQL over the HTTP API.
This node complements write-only packages such as node-red-contrib-influxdb3, enabling complete read/write workflows.
⭐ Features
  • Execute SQL queries against InfluxDB 3
  • HTTP-based implementation
  • Custom host, database and authentication token
  • Node-RED–friendly output format
  • Fully open source and extensible
πŸš€ Requirements
Component Version
Node.js β‰₯ 16
npm β‰₯ 8
Node-RED β‰₯ 3.0.0
InfluxDB 3 Any HTTP-compatible edition
πŸ“¦ Installation
Node-RED Palette Manager
Search for:
Or install manually:
cd ~/.node-red npm install node-red-contrib-influxdb3-read
Restart Node-RED afterwards.
βš™οΈ Configuration
The node requires:
  • Host β†’ http://host.docker.internal:8181 or http://localhost:8181 or host in the cloud
  • Database β†’ the InfluxDB 3 database name
  • Token β†’ an InfluxDB 3 API token
πŸ“₯ Input Format
Send a message with a SQL query in:
  "q": "SELECT * FROM tanque LIMIT 10"
Node-RED example:
msg.payload = { q: "SELECT * FROM tanque WHERE sensor = 'ultrasonico'" }; return msg;
πŸ“€ Output Format
The result is returned inside:
{ "payload": { "results": [...] } }
πŸ“š Example Flows
  1. Read last 5 minutes of data msg.payload = { q: "SELECT * FROM tanque WHERE time >= now() - interval '5 minutes'" }; return msg;
  2. Filter by tag msg.payload = { q: "SELECT * FROM tanque WHERE sensor IN ('ultrasonico')" }; return msg;
  3. Select specific fields msg.payload = { q: "SELECT time, value FROM tanque ORDER BY time DESC LIMIT 20" }; return msg;
πŸ›  Development
Clone this repo:
git clone https://github.com/DanielVickG87/node-red-contrib-influxdb3-read.git
Install dependencies:
npm install
Link into Node-RED:
npm link cd ~/.node-red npm link node-red-contrib-influxdb3-read
Restart Node-RED.
πŸ› Issues
Report bugs at:
https://github.com/DanielVickG87/node-red-contrib-influxdb3-read/issues
πŸ“œ License
MIT License
Β© 2025 Daniel Vick
Version: 1.0.2
Updated 1 year ago
  • influxdb3-read
  • influxdb
  • influxdb3
  • query
  • sql
  • timeseries
  • database
