node-red-contrib-iiot-rpi-mcp342x 1.0.21
A Node-Red node for mcp342x analog to digital converter
npm install node-red-contrib-iiot-rpi-mcp342x
platform platform NPM version NPM Donate
image info
Example MCP3424 hat from AB Electronics UK
image info
Example MCP3421 module
Supported Devices
  • mcp3421 1-channel, 12bit-18bit, one I2C address
  • mcp3422 2-channel, 12bit-18bit, one I2C address
  • mcp3423 2-channel, 12bit-18bit, eight I2C addresses
  • mcp3424 4-channel, 12bit-18bit, eight I2C addresses
  • mcp3425 1-channel, 12bit-16bit, one I2C address
  • mcp3426 2-channel, 12bit-16bit, one I2C address
  • mcp3427 2-channel, 12bit-16bit, eight I2C addresses
  • mcp3428 4-channel, 12bit-16bit, eight I2C addresses
Resolution and conversion time
  • 12bit conversion time 5ms/channel
  • 14bit conversion time 25ms/channel
  • 16bit conversion time 100ms/channel
  • 18bit conversion time 300ms/channel (mcp3421-mcp324)
Install with Node-Red Palette Manager or npm command:
  • This node works on Raspberry Pi with 32bit or 64bit OS.
  • The output value is mV or adc raw data.
  • For multi node, all values send as array.
  • Set correct parameter depends on used device.
  • Enable I2C with raspi-config.
Array Index on Multi Node
Input Array-Index
CH1 0
CH2 1
CH3 2
CH4 3
CHANGELOG
Version: 1.0.21
Updated 3 months ago
10 in the last week
  • mcp342x
  • mcp342x-m
  • raspberry pi
  • rpi
  • mcp342x
  • mcp3421
  • mcp3422
  • mcp3423
  • mcp3424
  • mcp3425
  • mcp3426
  • mcp3427
  • mcp3428
  • iot
  • iiot
  • analog
  • adc
