node-red-contrib-ignoble 0.0.12
ignoble is a noble node-red node allowing you to interact with your Bluetooth Low Energy devices
npm install node-red-contrib-ignoble
ignoble
A Node-Red BLE (Bluetooth Low Energy) central module.
Prerequisites
Will work anywhere that noble works.
Tested with Raspberry Pi Zero W (CYW43438), Nano Pi NEO AIR (AP6212A), and Red Bear BLE Nano V2 (nRF52x).
sudo npm install node-red-contrib-ignoble
Create a scanner node. This does not run by itself - hook up a trigger to it!
Connect a peripheral node to the scanner node and configure it to your liking, or don't.
Connect a service node to the peripheral node. This node just transforms data. You need it.
Connect a characteristic node to the service node. This node will let you fish out characteristic data.
After the characteric node has run, msg.payload will contain its data - this can be shunted to other nodes like MQTT, Twitter or a debug node.
Example
An example flow of two temperature sensors being polled every 30 minutes and characteristics exposed over Homebridge/MQTT. A third SHT21 sensor will push its temperature (2a6e) when the characteristic changes.
alt text
An example flow of subscribing to a peripheral's ccc5 characteristic. Set the peripheral's timeout to 0 and turn on the characteristic's subscribe flag to maintain notifications forever or until the device is disconnected.
alt text
Version: 0.0.12
Updated 9 years, 9 months ago
30 in the last week
  • scanner
  • peripheral
  • service
  • characteristic
  • characteristic out
  • bluetooth
  • ble
  • bluetoothle
  • low energy
  • le
  • iot
  • internetofthings
  • noble
  • nodered
