node-red-contrib-ignition-nodes 2.0.1
Adds support for reading, writing, and browsing tags in Ignition
npm install node-red-contrib-ignition-nodes
Node-RED Nodes for Ignition
Overview
Node-RED nodes for interfacing to Ignition by Inductive Automation. Allows for the reading, writing, and browsing tags configured in Ignition.
Requires Node-RED Ignition Module and Ignition 8.1+.
  • For Ignition 8.1.0 - 8.1.47, use version 1.5.17 or previous
  • For Ignition 8.1.48, use version 1.5.18
  • For Ignition 8.3.0+, use version 2.0.0
Run the following command in your Node-RED user directory:
The Tag Read node can read the value of any tag in Ignition. This includes all Gateway tags (OPC, memory, expression, SQL, derived, UDTs) and System tags.
The Tag Read Web Socket node utilizes web sockets so tag value changes get pushed to Node-RED without polling.
The Tag Write node can write to tags in Ignition. This will only work with tags that are configured with write privileges.
The Tag Browse node can browse for tags in Ignition. This allows you to discover tags configured in Ignition.
Copyright and License
Copyright 2021 Ignition Module Development Community
Licensed under the Apache 2.0 license.
Version: 2.0.1
Updated 1 year ago
Rating: 1.0 1
29 in the last week
  • ignition-tag-read
  • ignition-tag-write
  • ignition-tag-read-ws
  • ignition-tag-browse
  • ignition-server
  • tag
  • tags
  • tag read
  • tag write
  • tag browse
  • hmi
  • scada
  • Ignition
  • Inductive Automation
  • ws
  • websocket
