node-red-contrib-idi-fly 1.0.0
Node-RED nodes for IDI-FLY drone telemetry integration with automatic authentication and WebSocket publishing
npm install node-red-contrib-idi-fly
@idi-fly/node-red-idi-fly
Node-RED nodes for publishing drone telemetry data to IDI-FLY subscribers via WebSocket.
  • Automatic Authentication: OAuth 2.0 M2M token fetching with automatic refresh
  • WebSocket Management: Auto-reconnect with exponential backoff
  • Offline Handling: Messages queued when disconnected, sent on reconnect
  • Keep-Alive: Automatic ping to maintain connection
  • Easy Integration: Simple drag-and-drop nodes for Node-RED
From npm
npm install @idi-fly/node-red-idi-fly
Then restart Node-RED.
From Source
npm install /path/to/node-red-idi-fly
Or use npm link for development:
cd /path/to/node-red-idi-fly
npm link
npm link @idi-fly/node-red-idi-fly
Prerequisites
  1. IDI-FLY Integration API deployed
  2. Cognito App Client with:
    • client_credentials grant type enabled
    • stream:publish scope assigned
  3. API Key from API Gateway
idi-fly-publish
Publishes data to IDI-FLY WebSocket subscribers.
Input
Property Type Description
msg.payload object Data to publish (required)
msg.resourceId string Override resource ID (optional)
msg.dataType string Override data type (optional)
Output
msg.payload object Original payload (pass-through)
msg._idifly object Publish metadata
msg._idifly.published boolean True if sent immediately
msg._idifly.queued boolean True if queued for later
msg._idifly.resourceId string Resource ID used
msg._idifly.timestamp string ISO timestamp
idi-fly-config
Configuration node (singleton) that manages authentication and WebSocket connection.
Settings
Setting Description Default
REST API URL Token endpoint base URL Required
WebSocket URL WebSocket API URL Required
API Key x-api-key header value Required
Client ID Cognito App Client ID Required
Client Secret Cognito App Client Secret Required
Resource ID Default resource identifier Required
Auto Connect Connect on deploy true
Reconnect Interval Base reconnect delay (ms) 5000
Ping Interval Keep-alive interval (ms) 30000
Quick Start
  1. Drag an idi-fly publish node onto your flow
  2. Double-click to configure
  3. Click the pencil icon to create a new IDI-FLY connection
  4. Enter your credentials:
    • REST API URL: https://xxx.execute-api.eu-west-2.amazonaws.com/dev
    • WebSocket URL: wss://xxx.execute-api.eu-west-2.amazonaws.com/dev
    • API Key: Your API Gateway key
    • Client ID: Cognito App Client ID
    • Client Secret: Cognito App Client Secret
    • Resource ID: e.g., device-001
  5. Connect an inject or function node to provide data
  6. Deploy
Example Flow
Import the example from Menu > Import > Examples > @idi-fly/node-red-idi-fly.
Or use this simple flow:
[Inject] -> [Function: Format Data] -> [idi-fly-publish] -> [Debug]
Function Node Example
// Format telemetry data for IDI-FLY
msg.payload = {
    type: 'telemetry',
    latitude: 51.5074,
    longitude: -0.1278,
    altitude: 120,
    battery: 85,
    speed: 15.5,
    heading: 270
Integration Examples
From MQTT
[MQTT In] -> [Function: Parse] -> [idi-fly-publish]
From Serial/MAVLink
[Serial In] -> [Function: Parse MAVLink] -> [idi-fly-publish]
From HTTP
[HTTP In] -> [idi-fly-publish] -> [HTTP Response]
Message Format
The node sends messages in this format:
    "action": "publish",
    "resourceId": "device-001",
    "data": {
        "type": "telemetry",
        "latitude": 51.5074,
        "longitude": -0.1278,
        "altitude": 120,
        "battery": 85
Status Indicators
Status Meaning
🟢 Green dot Connected and ready
🟡 Yellow ring Connecting or message queued
🔴 Red ring Disconnected
🔴 Red dot Error
Token Management
  • Tokens are fetched automatically on first connection
  • Tokens are refreshed 5 minutes before expiry
  • If token fetch fails, retries with exponential backoff (1s, 2s, 4s)
  • WebSocket reconnects automatically after token refresh
Error Handling
"Permission denied: stream:publish scope required"
Your Cognito App Client needs the stream:publish scope:
  1. Go to AWS Console > Cognito > User Pools
  2. Select your user pool > App Integration
  3. Edit your Resource Server to add the stream:publish scope
  4. Edit your App Client to include the scope
"Token expired"
Tokens expire after 1 hour. The node handles this automatically, but if you see persistent errors:
  1. Check your Cognito configuration
  2. Verify Client ID and Secret are correct
  3. Check the Node-RED log for detailed errors
"Max reconnect attempts reached"
The WebSocket has failed to connect after 10 attempts:
  1. Check your WebSocket URL
  2. Verify the API is deployed and accessible
  3. Check network connectivity
  4. Restart the flow
Development
Testing Locally
# Install dependencies
npm install
# Link for local development
npm link
# In your Node-RED directory
Running Tests
npm test
MIT
Support
Version: 1.0.0
Updated 11 months, 2 weeks ago
  • idi-fly-config
  • idi-fly-publish
  • idi-fly
  • drone
  • telemetry
  • websocket
  • iot
