node-red-contrib-icreate-upnp 2.2.1
Node-RED contribution that adds nodes control of an iRobot iCreate2 that is been setup as a upnp device
npm install node-red-contrib-icreate-upnp
Node-RED-Contrib-iCreate-UPNP
This is a collection of nodes to control an iRobot iCreate2 that is connected to a Raspberry PI and is running a service that advertises it on the network as as UPNP device.
To Setup the PI for control of the robot as a UPNP device, see PI, iCreate and UPNP repository.
Once you have the PI running, you can npm install node-red-contrib-icreate-upnp in your node-red installation that will add a number of nodes to your palette. Start with a robot-discover node, once the robot is dicovered you can use nodes like move-robot to move it a certain distance or turn-robot to turn it a specific angle.
In your Node-RED settings file, you can create a upnp object with the following properties (all optional), to set the default for the robots you want to discover.
upnp:{
    port: 8090; //port for peer to listen
    prefix: "/upnp" //path on the localhost:<port> for upnp peer
    domain: "schemas-<yourorganization>-com",
    serviceType:"iCreateRobot",
    serviceVersion:"1"
See included settings.js file for an example.
Note this contribution library adds a delay to process.exit() so that the UPNP peer can cleanly advertise its close to all peers and unregister from their services. as a result, if you restart node-red in an IDE like Intellij Idea, you may get an "address in use" error. Simply wait a couple of seconds and restart your installation again.
Version: 2.2.1
Updated 11 years, 4 months ago
18 in the last week
  • find-robot
  • robot-status
  • move-robot
  • turn-robot
  • upnp-instance
  • STEM
  • iCreate2
  • iRobot
  • Roomba
  • UPNP
  • Node-RED
