node-red-contrib-ibm-db2 0.3.1
Node-RED nodes to access Db2 cloud services and Db2 LUW
npm install node-red-contrib-ibm-db2
Node-RED nodes to work with a Db2 database (LUW) including DB2 on Cloud and Db2 Warehouse on Cloud services on IBM Cloud.
Install from npm
This package contains 2 nodes Db2 in (query node) and Db2 out (output node). The query node let you issue a query against Db2 and pass along the result set in the msg object. The output node stores elements from the msg object into your Db2 service database.
Query node usage:
You will need to fill in the following fields:
-- Service should point to your IBM Db2 on Cloud or Db2 Warehouse on Cloud service, or choose the External Service option to connect to a Db2 database that exists outside of the IBM cloud.
-- Query is the SQL select query you wish to execute on your database. If the field is empty, it will get the query from the msg.payload.
These fields are optional:
-- Parameter Markers is a comma delimited set of json paths. These will replace any question marks that you place in your SQL query, in the order that they appear.
-- Name: Optionally give your node a name
The results of your query will be returned as a JSON array in msg.payload. If there are any errors during execution of the query, the payload will be null and the error will be returned in msg.error.
Output node usage:
The output node will get the values to insert from msg.payload.
So for example, you might create a function node that flows into your sqldb output node with code like this:
msg.payload =
  TS : 'TIMESTAMP',
  SCREENNAME : msg.tweet.user.screen_name,
  TWEET : msg.payload,
  SENTIMENT : msg.sentiment.score,
This would assume that you have a table already created with columns (TS, SCREENNAME, TWEET, SENTIMENT, LOCATION). 'TIMESTAMP' string is a special keyword that the node will replace with a real Db2 timestamp before insertion. If you are missing a required column, an error will be displayed in the debug view.
For output node configuration, you will need to fill in the following fields:
-- Table should point to the table you wish to insert the values into. This table needs to exist already in the database and needs to contain the same number of columns that you are inserting through this node. The data types of the columns have to match. The data coming into the node through the msg.payload needs to be in the format accepted by DB2 and within the appropriate ranges/parameters for that datatype.
The following fields are optional:
-- Name: Optionally give your node a name, otherwise the default will be the table name.
Authors
Version: 0.3.1
Updated 6 years, 2 months ago
License: Apache
Rating: 0.0
15 in the last week
  • Db2
  • Db2 out
  • Db2 in
  • IBM Cloud
  • Db2
  • bluemix
  • Db2 on Cloud
  • Nicholas Vargas
