node-red-contrib-iata-bcbp 1.0.0
Node Red nodes to decode and encode IATA Resolution 792 Compliant Boarding Pass Barcodes
npm install node-red-contrib-iata-bcbp
GitHub version GitHub issues GitHub license Twitter
A set of Node-Red nodes to decode and encode IATA Resolution 792 Compliant Boarding Pass Barcode Data.
This is a Node-Red wrapper for the work by georgesmith46's bcbp NPM node https://github.com/georgesmith46/bcbp.
Installing and Setting up
Add the IATA BCBP node to node-red through the manage palette tab or command line.
Here's an example of basic usage:
example
Example Flow
User guide
Encode Node
Converts a JSON object to a BCBP string. Any of the following parameters can be skipped (except legs).
Object Structure
Name Description Example values
passengerName Passenger Name
  • DESMARAIS/LUC
  • DOE/JOHN
passengerDescription Passenger Description
  • 0 - Adult
  • 1 - Male
  • 2 - Female
  • 3 - Child
  • 4 - Infant
  • 5 - No passenger (cabin baggage)
  • 6 - Adult travelling with infant
  • 7 - Unaccompanied minor
checkInSource Source of check-in
  • W - Web
  • K - Airport Kiosk
  • R - Remote or Off Site Kiosk
  • M - Mobile Device
  • O - Airport Agent
  • T - Town Agent
  • V - Third Party Vendor
boardingPassIssuanceSource Source of Boarding Pass Issuance
  • W - Web
  • K - Airport Kiosk
  • X - Transfer Kiosk
  • M - Mobile Device
  • O - Airport Agent
  • T - Town Agent
issuanceDate Date of Issue of Boarding Pass
  • 6225
  • ISO 8601 formatted string
  • Moment.js object
  • JavaScript date object
documentType Document Type
  • B - Boarding Pass
  • I - Itinery Receipt
boardingPassIssuerDesignator Airline Designator of boarding pass issuer
  • AC
baggageTagNumber Baggage Tag Licence Plate Number(s)
  • 0014123456003
firstBaggageTagNumber 1st Non-Consecutive Baggage Tag Licence Plate Number
  • 0014123456003
secondBaggageTagNumber 2nd Non-Consecutive Baggage Tag Licence Plate Number
  • 0014123456003
securityDataType Type of Security Data
  • 1
securityData Security Data
  • GIWVC5EH7JNT...
legs Repeatable legs data
  • Array - See table below
Legs Structure
Any of the following parameters can be skipped.
operatingCarrierPNR Operating carrier PNR Code
  • ABC123
departureAirport From City Airport Code
  • YUL
arrivalAirport To City Airport Code
  • FRA
operatingCarrierDesignator Operating carrier Designator
  • AC
flightNumber Flight Number
  • 0834
flightDate Date of Flight
  • 226
  • Moment.js object
compartmentCode Compartment Code
  • F
seatNumber Seat Number
  • 001A
checkInSequenceNumber Check-in Sequence Number
  • 0025
passengerStatus Passenger Status
  • 0 - Ticket issuance/passenger not checked in
  • 1 - Ticket issuance/passenger checked in
  • 2 - Bag checked/passenger not checked in
  • 3 - Bag checked/passenger checked in
  • 4 - Passenger passed security check
  • 5 - Passenger passed security gate exit (coupon used)
  • 6 - Transit
  • 7 - Standby
  • 8 - Boarding data revalidation done
  • 9 - Original boarding line used at time of ticket issuance
  • A - Up- or down-grading required at close out
airlineNumericCode Airline Numeric Code
  • 014
serialNumber Document Form/Serial Number
  • 1234567890
selecteeIndicator Selectee indicator
  • 0
internationalDocumentationVerification International Documentation Verification
  • 0 - Travel document verification not required
  • 1 - Travel document verification required
  • 2 - Travel document verification performed
marketingCarrierDesignator Marketing carrier designator
  • AC
frequentFlyerAirlineDesignator Frequent Flyer Airline Designator
  • AC
frequentFlyerNumber Frequent Flyer Number
  • 1234567890123
idIndicator ID/AD Indicator
  • 0
freeBaggageAllowance Free Baggage Allowance
  • 20K
fastTrack Fast Track
  • Y
  • N
  • true
  • false
airlineInfo For individual airline use
  • LX58Z
Example JSON Object
    "legs": [
            "operatingCarrierPNR": "ABC123",
            "departureAirport": "YUL",
            "arrivalAirport": "FRA",
            "operatingCarrierDesignator": "AC",
            "flightNumber": "0834",
            "flightDate": "2018-08-14T00:00:00.000Z",
            "compartmentCode": "F",
            "seatNumber": "001A",
            "checkInSequenceNumber": "0025",
            "passengerStatus": "1"
    "passengerName": "DESMARAIS/LUC"
Outputs:
M1DESMARAIS/LUC       EABC123 YULFRAAC 0834 226F001A0025 106>60000
Decode Node
Converts a BCBP string to a JSON object. The returned object uses the same data structure as the Encode node above.
Example String
Outputs:
    "legs": [
To Do
  1. Add further error handling / data checks
  2. Add data capture / export
  3. Add boarding pass validation node against airline DCS host using IATA BCBP XML format
  4. Add basic validation rules engine
  5. Add Barcode Image Decode
  6. Add Boarding Pass template generation
Authors & Contributors
Contributions welcome! Feel free to fork this and provide updates and new features. Don't forget to submit a pull request!
This project is licensed under the GPL3.0 License - see the LICENSE file for details
Acknowledgments
This Node-RED module is based on the great work of georgesmith46 - georgesmith46, using his bcbp libraries.
Changelog
v1.0.0 (latest)
  • Initial Release
  • IATA BCBP Decode Function
  • IATA BCBP Encode Function
Version: 1.0.0
Updated 7 years, 2 months ago
License: GPL-3.0-only
1 in the last week
  • Decode BCBP
  • Encode BCBP
  • bcbp
  • iata
  • boarding pass
  • 792
  • PDF417
  • Mark Funston
