node-red-contrib-iammeter 0.2.5
A module for Node-RED that you can use to get data from wifi power meter of IAMMETER.
npm install node-red-contrib-iammeter
This is a node introduction for the IAMMETER
IAMMETER provides both a single-phase and three-phase energy meter. They are all bi-directional, din rail, base on WiFi. You can use them to meter the energy consumption, especially in the application of solar PV systems.
WEM3080: single-phase WiFi energy meter
WEM3080T: three-phase WiFi energy meter
Install in Node-RED via the Manage Palette menu.
May also be installed via npm:
Local Output: Single-phase electric energy meter (WEM3080)
   [234.7,9.99,1068,21.063,20.667,49.99,1]
[voltage, current, power,import energy, export energy]
unit: voltage [V], current [A], power [W],import energy [kWh], export energy [kWh]
Local Output: three-phase electric energy meter(WEM3080T)
   [234.7,9.99,1068,21.063,20.667,49.99,1],
   [220,9.99,1100,21.063,20.667,49.99,0.5],
   [220,9.99,1213,21.063,20.667,49.99,0.55],
   [224.9,0,3381,26.329,25.834,49.99,0.55]
[ voltageA, currentA, powerA,import energyA, export energyA], [ voltageB, currentB, powerB,import energyB, export energyB], [ voltageC, currentC, powerC,import energyC, export energyC]
Monitor your solar PV system in Node-Red
You can use the Energy monitor node of IAMMETER to monitor your solar PV system in Node-Red.
Effect && Demo
Node-RED UI: http://ha.iammeter.com:11880/ui
Node-RED flow: http://ha.iammeter.com:11880/#flow/5fb9966c8a33b771
Node-RED in Homeassistant: http://ha.iammeter.com:18123/nodered
user/password: iammeter/iammeter
iammeter_node-red-solar-pv-system_daily
Tutorial
How to monitor your solar PV system in NodeRed
About IAMMETER
Monitor your energy consumption in IAMMETER-Cloud
Integrate IAMMETER energy meter to third-party platforms
Version: 0.2.5
Updated 5 years, 5 months ago
Rating: 3.7 3
2 in the last week
  • local-realtime
  • cloud-realtime
  • IAMMETER
  • meter
  • energy
  • power
  • monitor
  • smart
