node-red-contrib-i3x 0.0.8
Node-RED nodes for the i3X (Industrial Information Interoperability eXchange) API by CESMII
npm install node-red-contrib-i3x
npm version CI License: MIT Node.js i3X API
Node-RED nodes for the i3X (Industrial Information Interoperability eXchange) API by CESMII.
i3X is an open, vendor-agnostic REST API specification for standardised access to contextualised manufacturing information platforms (Historians, MES, MOM, etc.).
This package is an i3X client: it lets your Node-RED flows browse, read, write, query history, and subscribe against any compliant i3X server. (If you instead need to expose an OPC UA address space as an i3X server, see projects like node-opcua/node-i3x — the two are complementary.)
Note: This package targets the i3X API 1.0 Release (finalized 2026-06-09). The specification is stable; the next revision is not expected before the vNext working group convenes in late 2026.
Architecture
Where i3X sits
i3X is a standardised REST facade in front of heterogeneous manufacturing information platforms. This package lets Node-RED act as an i3X client, talking to any compliant i3X server over HTTPS.
flowchart LR
    subgraph SHOP["Shop floor / OT"]
        PLC["PLCs · Sensors"]
        OPC["OPC UA"]
    end
    subgraph PLATFORM["Information platforms"]
        HIST["Historian"]
        MES["MES / MOM"]
    end
    subgraph I3X["i3X Server (REST API 1.0)"]
        MODEL["Information Model\n(namespaces · types · objects · relationships)"]
        API["REST endpoints\n/objects · /history · /subscriptions"]
    end
    subgraph NR["Node-RED + node-red-contrib-i3x"]
        NODES["i3x nodes"]
        FLOWS["Your flows / dashboards"]
    end
    PLC --> OPC --> PLATFORM
    PLATFORM --> I3X
    MODEL --- API
    API -- "HTTPS / SSE" --> NODES --> FLOWS
Package internals
Every node delegates HTTP work to a single shared I3XClient, configured once through the i3x-server config node. The client centralises all resilience features (retry, caching, rate limiting, TLS, SSE reconnection).
flowchart TB
    subgraph EDITOR["Node-RED flow"]
        BROWSE["i3x-browse\nexplore model"]
        READ["i3x-read\nlast values"]
        WRITE["i3x-write\nvalue / history"]
        HISTORY["i3x-history\ntime series"]
        SUB["i3x-subscribe\nSSE / polling"]
    end
    CONFIG["i3x-server (config node)\nBase URL · Auth · TLS · Timeout · clientId"]
    subgraph CLIENT["lib/i3x-client.js — shared HTTP client"]
        RETRY["Retry + backoff\n(429/502/503/504)"]
        CACHE["TTL cache\n(namespaces, types)"]
        RATE["Rate limiter\n(100 / 60s)"]
        SSE["SSE stream\n+ polling fallback"]
    end
    SERVER[("i3X REST API")]
    BROWSE --> CONFIG
    READ --> CONFIG
    WRITE --> CONFIG
    HISTORY --> CONFIG
    SUB --> CONFIG
    CONFIG --> CLIENT
    CLIENT -- "axios · HTTPS" --> SERVER
Request flow (example: read a value)
sequenceDiagram
    participant F as Flow (msg)
    participant N as i3x-read
    participant C as I3XClient
    participant S as i3X Server
    F->>N: msg.elementIds
    N->>C: getValues(ids, maxDepth)
    C->>C: rate-limit check / cache lookup
    C->>S: POST /objects/value
    alt 429 / 5xx
        S-->>C: error + Retry-After
        C->>C: exponential backoff
        C->>S: retry (max 3)
    end
    S-->>C: VQT values
    C-->>N: result
    N-->>F: msg.payload
Install from within Node-RED via Manage palette → Install, or from the command line:
For development / local testing:
npm install /path/to/node-red-contrib-i3x
All nodes share the category i3x and use the same green colour scheme (#5DB87C).
i3x-server (Config Node)
Shared connection configuration used by all other nodes.
Property Description
Base URL Root URL of the i3X API server (e.g. https://i3x.cesmii.net)
API Version Optional path prefix (e.g. v0)
Auth Type none, basic, bearer, or apikey
TLS Optional TLS configuration (Node-RED TLS Config Node)
Timeout HTTP timeout in milliseconds (default 10 000)
i3x-browse
Explore the i3X information model – namespaces, object types, relationship types, objects, and related objects.
Browse targets:
Target API Endpoint Description
namespaces GET /namespaces All available namespaces
objecttypes GET /objecttypes or POST /objecttypes/query Type schemas
relationshiptypes GET /relationshiptypes or POST /relationshiptypes/query Relationship type definitions
objects GET /objects or POST /objects/list Object instances
related POST /objects/related Graph traversal – related objects
i3x-read
Read the last known values for one or more objects.
  • Input: msg.elementIds (string, comma-separated, or array)
  • Output: msg.payload – value data from POST /objects/value
  • Option: maxDepth – controls recursion into child components (0 = infinite, 1 = no recursion)
i3x-write
Write a current value or historical data to an i3X object.
  • Input: msg.payload (value to write), msg.elementId (target)
  • Target: value (default) or history – selectable via dropdown or msg.writeTarget
  • Output: msg.payload – write confirmation from the API
Target API Endpoint Payload format
value PUT /objects/value A value or VQT object {value, quality?, timestamp?}
history PUT /objects/history A VQT or array of VQT records [{value, quality, timestamp}, …]
Both use the i3X 1.0 bulk update format ({updates: [{elementId, value}]}); the node builds it for you. For history writes a missing quality defaults to "Good" and a missing timestamp to the current UTC time.
i3x-history
Query historical time-series data.
  • Input: msg.elementIds, msg.startTime, msg.endTime
  • Output: msg.payload – historical data from POST /objects/history
  • Time formats: ISO 8601 (2025-01-01T00:00:00Z) or relative (-1h, -7d, -30m, -2w)
i3x-subscribe
Subscribe to value changes via SSE streaming or polling.
  • SSE mode: Opens a persistent Server-Sent Events stream (POST /subscriptions/stream)
  • Polling mode: Periodically calls POST /subscriptions/sync, acknowledging received batches by sequence number
  • Fallback: If SSE fails — or the server returns HTTP 501 (streaming not supported) — the node automatically falls back to polling
  • Lifecycle: Subscriptions are created on deploy and deleted on stop/re-deploy; all calls are scoped by a clientId derived from the server config node (required by i3X 1.0)
Built-in Resilience & Best Practices
The shared HTTP client (lib/i3x-client.js) implements all i3X Client Developer Best Practices:
Feature Description
Retry with Exponential Backoff Automatic retries on 429, 502, 503, 504 with exponential delay
Retry-After Header Respects server-provided Retry-After headers (seconds and HTTP-date formats)
TTL Caching Namespaces and object types are cached for 60 seconds to reduce API load
Rate Limiting Client-side sliding-window throttle (100 requests per 60-second window)
Input Sanitization Allowlist validation on write payloads to prevent injection of unexpected fields
TLS Certificate Validation rejectUnauthorized: true by default; overridable via TLS config node
SSE Reconnection Automatic reconnection with exponential backoff (up to 5 attempts, max 30s delay)
SSE → Polling Fallback Automatic fallback to polling if SSE stream setup fails
Subscription Cleanup Subscriptions are deleted server-side on node stop/re-deploy
API Endpoints Used
This package targets the i3X API 1.0 Release:
Category Method Endpoint
Info GET /info
Explore GET /namespaces
Explore GET /objecttypes
Explore POST /objecttypes/query
Explore GET /relationshiptypes
Explore POST /relationshiptypes/query
Explore GET /objects
Explore POST /objects/list
Explore POST /objects/related
Query POST /objects/value
Query POST /objects/history
Update PUT /objects/value
Update PUT /objects/history
Subscribe POST /subscriptions
Subscribe POST /subscriptions/list
Subscribe POST /subscriptions/delete
Subscribe POST /subscriptions/register
Subscribe POST /subscriptions/unregister
Subscribe POST /subscriptions/stream
Subscribe POST /subscriptions/sync
All subscription requests carry the spec-required clientId (derived from the server config node), which scopes subscriptions per client.
Example Flows
Read values from the demo server
        "id": "flow1",
        "type": "tab",
        "label": "i3X Demo"
        "id": "server1",
        "type": "i3x-server",
        "name": "CESMII Demo",
        "baseUrl": "https://i3x.cesmii.net",
        "apiVersion": "",
        "authType": "none",
        "timeout": "10000"
        "id": "inject1",
        "type": "inject",
        "name": "Trigger",
        "props": [],
        "repeat": "",
        "once": false,
        "wires": [["browse1"]]
        "id": "browse1",
        "type": "i3x-browse",
        "name": "List Namespaces",
        "server": "server1",
        "browseTarget": "namespaces",
        "wires": [["debug1"]]
        "id": "debug1",
        "type": "debug",
        "name": "Output",
        "active": true
Testing
# Run all tests (unit + integration)
npm test
# Unit tests only (offline, uses HTTP mocks)
npm run test:unit
# Integration tests only (requires network access to demo server)
npm run test:integration
# Unit tests with coverage report
npm run test:coverage
# Lint (ESLint over lib/, nodes/, test/)
npm run lint
# Run all tests in Docker
npm run test:docker
See CONTRIBUTING.md for the full development workflow.
Docker
# Start Node-RED with the i3x nodes pre-installed and the demo flow loaded
docker compose up node-red
# Open http://localhost:18880 in your browser
# Run tests in a container
docker compose run --rm test
Local development environment (mock server + GUIs)
For a turnkey local setup that needs no external i3X server, the repo bundles a reference mock server plus two front-ends wired to it:
docker compose up -d i3x-mock node-red-mock i3x-explorer
Service URL What it is
i3x-mock http://localhost:18810/info Dependency-free, in-memory i3X 1.0 reference server (ISA-95 sample model, live values, history, subscriptions over SSE and sync polling). See mock-server/.
node-red-mock http://localhost:18881 Node-RED with these nodes + a demo flow (examples/i3x-mock-demo.json) pointed at the mock.
i3x-explorer http://localhost:18820 The official i3X Explorer GUI, served standalone via nginx and pointed at the mock.
Third-party notice: i3x-explorer is not part of this package. It builds and serves the official i3X Explorer from ace-technologies-inc/i3X-Explorer (by ACE Technologies / CESMII, MIT-licensed). This repo only provides the Docker packaging — the application source is cloned from upstream at build time, not vendored here. See i3x-explorer/README.md.
The mock server and the Explorer packaging are development tooling only and are excluded from the published npm package.
Development
git clone <repo-url>
cd node-red-contrib-i3x
npm install
# Link into Node-RED for development
# Restart Node-RED
node-red
References
MIT – see LICENSE.
Version: 0.0.8
Updated 5 months ago
Rating: 5.0 2
23 in the last week
  • i3x-server
  • i3x-browse
  • i3x-read
  • i3x-write
  • i3x-history
  • i3x-subscribe
  • i3x
  • cesmii
  • industrial
  • manufacturing
  • iiot
  • historian
  • mes
  • mom
  • opc-ua
  • smart-manufacturing
