node-red-contrib-html-to-pdf 1.1.1
Node-RED node for converting HTML files to PDF, using the Puppeteer library.
npm install node-red-contrib-html-to-pdf
A Node-RED node that converts HTML to PDF, using the Puppeteer library.
Either use the Node-RED Menu - Manage Palette - Install, or run the following command in your Node-RED user directory - typically ~/.node-red
npm install node-red-html-to-pdf
You pass the HTML source code in the msg.payload.
Various options can be set in the node configuration dialog or set as properties of msg:
  • Format (letter, legal, tabloid, ledger, A0, A1, A2, A3, A4, A5, A6, custom)
  • Orientation (portrait, landscape); msg.orientation
  • Zoom (10% to 200%); msg.zoom (number)
  • Margins; msg.marginTop, msg.marginTopUnits, msg.marginLeft etc.
  • Transparent background; msg.omitBackground (true or false)
  • Show or hide background graphics; msg.printGraphics (true or false)
Version: 1.1.1
Updated 2 years, 11 months ago
16 in the last week
  • html-to-pdf
  • pdf
  • html
  • puppeteer
