node-red-contrib-html-pdf-converter 0.1.2
A Node-RED node to convert HTML to PDF without using a browser.
npm install node-red-contrib-html-pdf-converter
Description
The node-red-contrib-html-pdf-converter node allows you to convert HTML content into a PDF file. This node is useful for generating PDF reports or documents from HTML content within your Node-RED flows.
To install this node, use the Node-RED Palette Manager or install it directly via npm:
The node-red-contrib-html-pdf-converter node converts HTML content received on its input into a PDF file and saves it to a specified directory.
PDF Name
Specify the base name for the generated PDF file. The node will automatically append a counter to ensure that each file name is unique.
  • Example: report This will generate files like report_1.pdf, report_2.pdf, etc.
Save Path
The path where the PDF files will be saved. This path is fixed to node-red/PDFs/ and is displayed as read-only in the configuration.
Example Flow
Here is an example flow to use the node-red-contrib-html-pdf-converter node:
        "id": "html-to-pdf-node",
        "type": "html-to-pdf",
        "name": "Generate PDF",
        "pdfName": "report",
        "x": 300,
        "y": 200,
                "debug-node"
        "id": "inject-node",
        "type": "inject",
        "name": "Inject HTML",
        "payload": "<h1>Hello World</h1>",
        "payloadType": "str",
        "topic": "",
        "x": 100,
        "y": 200,
                "html-to-pdf-node"
        "id": "debug-node",
        "type": "debug",
        "name": "Debug Output",
        "active": true,
        "x": 500,
        "y": 200,
Details
node-red-contrib-html-pdf-converter Node Configuration
  • PDF Name: The base name for the PDF file. The node appends a counter to ensure uniqueness.
  • Save Path: The fixed path where the PDFs are saved. Displayed as read-only.
Notes
  • Ensure that Node-RED has the necessary permissions to write to the node-red/PDFs/ directory.
  • The node automatically increments the counter to avoid overwriting existing files with the same name.
Contributing
If you have suggestions or improvements, feel free to contribute to the repository or open an issue.
This node is licensed under the MIT License.
Version: 0.1.2
Updated 2 years, 5 months ago
Rating: 0.0
15 in the last week
  • html-to-pdf-converter
  • html
  • pdf
  • converter
  • html to pdf
  • node
  • node-red-contrib
  • html to pdf converter
  • pdf generation
  • html pdf converter
