node-red-contrib-html-entities 0.1.0
Tiny node-red wrapper node around the html entities library called 'he'.
npm install node-red-contrib-html-entities
A node that wraps the he html entities encoder/decoder utility. Initially created for a specific project where 3rd party HTML was parsed and function nodes filled with regex replacements were starting to get hard to maintain.
This library contains a single html-entities node. It can be used to both encode or decode HTML entities.
You can install this node from the Node-RED palette (preferred) by searching for node-red-contrib-html-entities or directly from npm: npm install node-red-contrib-html-entities. For the last option, make sure you are executing the command from the Node-RED user directory.
Version: 0.1.0
Updated 7 years, 8 months ago
Rating: 1.0 1
18 in the last week
  • html-entities
