node-red-contrib-homeseer 1.0.6
HomeSeer nodes to control HomeSeer devices and events from Node-RED
npm install node-red-contrib-homeseer
HomeSeer Nodes for Node-RED
This software provides Node-RED nodes to control and monitor your HomeSeer devices and events. It is compatible with HomeSeer version 4.1.3.0 or later and Node-Red version 1.0 or later.
From Node-RED (preferred)
Go to Menu > Manage Palette > Install tab, search for node-red-contrib-homeseer then click the install button.
From the command line
Use the following command from within your user data directory (by default, $HOME/.node-red):
Then restart Node-RED
If the installation is successful, the new HomeSeer nodes will appear in the palette:
HomeSeer Nodes
In order for Node-RED to receive device status updates from HomeSeer you need to setup a webhook URL. From the HomeSeer web interface go to Setup > Custom and add your Node-RED URL followed by /homeseer/webhook. For example if Node-RED is running on the same machine as HomeSeer, it should be something like http://127.0.0.1:1880/homeseer/webhook
Webhook Configuration
Every HomeSeer node will have a HS Server property which must be configured. You only have to create this configuration once when you create your first node.
HS Server Configuration
Username and Password are optional fields, but if in HomeSeer, Setup > Network > Web Server Settings > No Password Required for local Login is uncheked then you must provide a valid HomeSeer username and password.
Available Nodes
HS Device
Node representing a HomeSeer Device or Feature.
Controlling a Device
To control a device the node needs to receive on its input, a message with msg.topic set to control and either msg.payload.value property set to the control value to use, or the msg.payload.status property set to the control text status to use.
Control Device Flow
Control Inject Node
Updating a Device's value and/or status
To update a device's value and/or status, the node needs to receive on its input, a message with msg.topic set to update and either msg.payload.value property set to the new value, or the msg.payload.status property set to the new status, or both.
Control Device Flow
Control Inject Node
Receiving Device updates
Every time the device value or status changes in HomeSeer the node will send to its output a message containing the new state of the device in msg.payload
    payload: {
    	ref: 1234,
        value: 1,
        status: 'On'
Forcing a Device update
If the node receives a message with msg.topic set to sync it will get the current state of the device from HomeSeer and send it to its output in msg.payload even if no changes has occured since the last update.
Reporting Device current state
If the node receives a message with msg.topic set to report it will send to its output the last known state of the device without querying HomeSeer.
HS Event
Node representing a HomeSeer Event. To run the event actions, this node needs to receive on its input, a message with the msg.topic property set to run
Event Flow Event Inject Node
Version: 1.0.6
Updated 6 years ago
License: AGPL-3.0-only
Rating: 4.0 3
22 in the last week
  • hs-server
  • hs-device
  • hs-event
  • homeseer
  • hs4
