node-red-contrib-homematic-hcu 1.1.5
Node-RED nodes for access to Homematic IP HCU (Home Control Unit)
npm install node-red-contrib-homematic-hcu
Node-RED nodes for connecting to a Homematic IP Home Control Unit (HCU) through the Homematic IP Connect API. No cloud is required.
The package provides a shared WebSocket connection, device and feature lookup, feature change events, HCU system requests, user-message requests, and Connect API authentication.
Development status: This README describes the current implementation. The package should be tested against the target HCU firmware and Node-RED environment before production use.
Note on Code Creation
This is a private Node-RED project that I created in my spare time for non-commercial purposes. Parts of this repository were created using AI-powered development tools and were subsequently reviewed, adapted, and further developed by the repository owner.
  • Shared WebSocket connection to the HCU.
  • HCU Connect API authentication-token creation and confirmation.
  • Support for the Homematic IP HCU WebSocket endpoint on port 9001.
  • Optional support for self-signed TLS certificates.
  • Automatic reconnect after unexpected connection loss.
  • Automatic answer to PLUGIN_STATE_REQUEST, CONFIG_TEMPLATE_REQUEST and CONFIG_UPDATE_REQUEST messages from the HCU.
  • Initial retrieval and caching of the HCU system state.
  • Device lookup through the Node-RED editor.
  • Reading feature values from the cached system state.
  • Event-driven handling of DEVICE_CHANGED events.
  • Sending generic HCU messages.
  • Controlling devices with request/response correlation.
  • Creating and deleting HCU user messages.
Requirements
  • Node-RED 4.1.10 or newer (lower versions not tested).
  • Node.js 18.0.0 or newer (lower versions not tested).
  • A Homematic IP HCU with firmware 1.4.7 or newer, developer mode enabled and the Connect API WebSocket exposed in the local network (both settings are on the developer mode page of HCUweb).
  • Network access from the Node-RED host to the HCU (ports 9001 and, for creating a token, 6969).
  • A valid HCU authentication token and the matching plugin ID. Both can be created with the New HCU connection node of this package.
The package currently declares the following runtime dependency:
ws ^8.18.0
Palette Manager
  1. Open the Node-RED menu.
  2. Select Manage palette.
  3. Open the Install tab.
  4. Search for node-red-contrib-homematic-hcu.
  5. Install the package.
  6. Restart Node-RED if requested.
npm
From the Node-RED user directory:
For local development:
npm install --no-save /path/to/node-red-contrib-homematic-hcu
After installation, restart Node-RED and deploy the flow again.
Package nodes
Node Purpose Inputs Outputs
hcu-config Shared HCU WebSocket configuration and connection (configuration node) — —
New HCU connection Creates and confirms a Connect API authentication token 1 1
hcu in Receives HCU connection events and WebSocket messages 0 1
hcu out Sends a generic message through the shared WebSocket 1 1
feature event Emits a message when a configured device feature is reported 0 1
get feature value Reads a feature from the cached system state 1 1
set feature value Sends a device control request and waits for its response 1 1
create user message Creates a user message on the HCU 1 1
delete user message Deletes a user message on the HCU 1 1
Add one hcu-config configuration node and use it from the other HCU nodes. In the editor it is shown with its name, its server address or, if both are empty, as homematic-hcu-config.
Server address
Enter only the HCU host name or IP address, for example:
192.168.1.20
hcu1-1234.local
hcu1-XXXX.local is the default host name of the HCU, where XXXX are the last four digits of the SGTIN on the underside of the device.
The WebSocket URL is constructed as:
wss://<serverAddress>:9001
Do not enter the protocol or port in the Server address field.
Plugin ID
Enter the plugin identifier used by the HCU Connect API. It must be the same identifier that was used to create the authentication token. It is sent as the plugin-id WebSocket header and is included in outgoing HCU messages.
Auth token
Enter the HCU authentication token. It is stored as a Node-RED credential rather than as a normal flow property.
The connection uses these WebSocket headers:
authtoken: <authToken>
plugin-id: <pluginId>
hmip-system-events: true
Self-signed certificates
The HCU uses a self-signed certificate. Enable Allow self-signed certificates to connect without a trusted certificate. This disables TLS certificate verification for the WebSocket connection, so use it only in a controlled local network.
Connection lifecycle
The configuration node connects automatically when it is created.
After the WebSocket opens, it:
  1. Sends a PLUGIN_STATE_RESPONSE with pluginReadinessStatus: READY.
  2. Requests the current system state using /hmip/home/getSystemState.
  3. Stores the returned system state in a local cache.
  4. Broadcasts connection and message events to dependent nodes.
While connected, the node:
  • answers every PLUGIN_STATE_REQUEST from the HCU with READY.
  • answers every CONFIG_TEMPLATE_REQUEST (sent when the plugin settings are opened in HCUweb) with an empty configuration template, as recommended by the Connect API documentation. All settings are made in Node-RED, so HCUweb shows no configuration parameters for the plugin. Sending your own CONFIG_TEMPLATE_RESPONSE with hcu out is not supported, because the HCU would receive two answers.
  • answers every CONFIG_UPDATE_REQUEST (sent when Save is clicked in the plugin settings in HCUweb) with a CONFIG_UPDATE_RESPONSE with status APPLIED. There is nothing to apply, but without this answer HCUweb keeps waiting. Sending your own CONFIG_UPDATE_RESPONSE with hcu out is not supported.
  • reports every ERROR_RESPONSE from the HCU (sent when the HCU cannot process a message) as an error in the debug sidebar and the Node-RED log, including the error code, the error text and the original message (shortened to 1000 characters). The error is not assigned to a specific request.
  • replaces a device in the cache when a DEVICE_CHANGED event arrives. Other events (for example DEVICE_ADDED, DEVICE_REMOVED or GROUP_CHANGED) do not update the cache; new or removed devices are reflected after the next reconnect or redeploy.
  • mirrors the cache to the global context key homematicHcu.systemState ({ timestamp, data }), so it can be read in Function nodes.
If the connection closes unexpectedly or cannot be established (including a rejected handshake such as HTTP 401), the node retries automatically. The delay starts at 5 seconds and doubles after every failed attempt (5 s, 10 s, 20 s, …) up to 5 minutes. After a successful connection it is reset to 5 seconds. The node status shows the cause and the next attempt, for example HTTP 401, retry in 20 s.
The connection is closed without reconnecting when Node-RED deploys or shuts down the node.
New HCU connection
The New HCU connection node generates all data needed for a WebSocket connection to the HCU. This eliminates the need for additional tools or flows. The result can then be entered in the hcu-config node.
Any incoming message starts the process. The node sends two HTTPS requests to port 6969 of the HCU (/hmip/auth/requestConnectApiAuthToken and /hmip/auth/confirmConnectApiAuthToken).
  • Plugin identifier: Your plugin identifier. Reverse domain notation is recommended, for example de.doe.jane.plugin.example.
  • Plugin Name: JSON language map containing at least a non-empty de value. It is shown in HCUweb and in the Homematic IP app.
  • Activation key: One-time key generated on the developer mode page of HCUweb. It expires after a certain period.
  • Server address: IPv4 address or host name of the HCU (for example 192.168.1.20 or hcu1-1234.local), without protocol or port.
  • Allow self-signed certificate: Disables TLS certificate verification for these HTTPS requests.
Example plugin name:
  "de": "Beispiel-Plugin",
  "en": "Example Plugin"
Note: After the first Connect API client has been created, the developer mode of the HCU can no longer be deactivated. The client appears in the user overview of the Homematic IP app, where it can be deleted.
Successful output
The incoming message is forwarded and msg.payload is replaced with:
  "authToken": "auth-token",
  "clientId": "client-id",
  "serverAddress": "192.168.1.20",
  "pluginIdentifier": "de.example.plugin",
  "requestResponse": {},
  "confirmResponse": {}
To help troubleshoot an error, the HCU's responses are also output in requestResponse and confirmResponse.
Error output
If a request fails, the node reports the error and additionally forwards the message with:
  "payload": {
    "error": "error text"
Security
The returned authToken is sensitive. Do not expose it through Debug nodes, logs, exported flows, or persistent context without appropriate protection.
The activation key is stored as a normal node property and is therefore part of exported flows. Remove it from the node after the token has been created.
HCU In
hcu in receives events from the shared configuration node. It has no input port and one output.
  • Connection: Required shared HCU configuration.
  • Event filter: all or a specific HCU message type (for example HMIP_SYSTEM_EVENT, HMIP_SYSTEM_RESPONSE, ERROR_RESPONSE, USER_MESSAGE_ACK_EVENT).
  • Name: Optional display name.
With all, connection events and all WebSocket messages are forwarded. With a specific event type, only messages whose payload.type exactly matches that value are forwarded; connection events are not forwarded.
Connection events
When the filter is all, connection events are emitted as:
  "topic": "connection/open",
  "payload": {
    "type": "open"
  "topic": "connection/close",
  "payload": {
    "type": "close",
    "code": 1006,
    "reason": ""
  "topic": "connection/error",
  "payload": {
    "type": "error",
WebSocket messages
Incoming HCU messages are forwarded as:
  "topic": "HMIP_SYSTEM_EVENT",
  "payload": {
    "type": "HMIP_SYSTEM_EVENT"
  "meta": {
    "isBinary": false,
    "parsedAsJson": true,
    "raw": "{...}"
  "rawEvent": {
    "type": "message"
For binary WebSocket data, payload is represented as a hexadecimal string. Invalid JSON text is forwarded as a string.
HCU Out
hcu out sends msg.payload as the body of an HCU message.
  • Message type: Message type used in the outgoing message, for example HMIP_SYSTEM_REQUEST (default), LIST_USER_MESSAGES_REQUEST or SYSTEM_INFO_REQUEST.
Generated message
For this input:
  "payload": {
    "path": "/hmip/home/getSystemState",
    "body": {}
The node creates:
  "pluginId": "plugin-id-from-config",
  "id": "generated-uuid",
  "type": "HMIP_SYSTEM_REQUEST",
  "body": {
    "body": {}
The fields are set as follows:
  • pluginId: Value from the selected configuration node.
  • id: A newly generated UUID for every message.
  • type: Configured Message type.
  • body: msg.payload.
Output
After successful sending, the input message is forwarded and msg.payload is replaced with the generated message. All other message properties are kept.
The node does not wait for a response. Use hcu in with the matching filter (for example HMIP_SYSTEM_RESPONSE) and compare the id to receive it.
Get Feature Value
get feature value reads a feature from the cached HCU system state. It does not listen for new WebSocket events.
  • Device: Device selected from the current cached device list.
  • Feature: Feature name to read, exactly as it appears in the device data (for example actualTemperature, on, dimLevel).
An incoming message triggers the lookup. The input payload is not used to select the device or feature.
Device selection
The selected value is always device.id, including for devices with:
type: PLUGIN_EXTERNAL
For PLUGIN_EXTERNAL devices, pluginDeviceId is used only as part of the visible editor label.
Feature lookup
The node searches the entries of functionalChannels in order and returns the first match:
  1. Direct property on the channel.
  2. Property inside supportedOptionalFeatures of the channel.
Output
The input message is forwarded; msg.payload and msg.meta are replaced:
  "payload": {
    "lastStatusUpdate": 1710000000000,
    "label": "Living room",
    "feature": "actualTemperature",
    "value": 21.5
  "meta": {
    "featureSource": "functionalChannels",
    "cacheTimestamp": 1710000000000
meta.featureSource is functionalChannels or supportedOptionalFeatures, depending on where the feature was found.
No output message is emitted when the cache, the device or the feature is unavailable. The node shows the reason in its status. A missing cache or an empty device list is additionally reported as an error (catchable with a Catch node); a missing device or feature is not.
Feature Event
feature event listens for HCU system events and emits a message whenever a DEVICE_CHANGED event for the selected device contains the configured feature.
  • Feature: Feature name to read, exactly as it appears in the device data (for example actualTemperature).
The feature lookup works as described for get feature value.
Output
  "payload": {
    "value": 21.5
  "meta": {
A message is emitted for every matching DEVICE_CHANGED event, even if the value of the feature itself did not change. Use a Filter (RBE) node to pass only changed values.
No message is emitted when the device or feature does not match.
Set Feature Value
set feature value creates an HMIP_SYSTEM_REQUEST for the selected device, sends it through the shared WebSocket, and waits for the matching HMIP_SYSTEM_RESPONSE.
  • HMIP system request: Request path selected from the list. All paths of chapter 6.8.1 (/hmip/device/control/...) of the Homematic IP Connect API documentation are available.
Input payload
msg.payload contains the request body for the selected path, as described in chapter 6.8.1 of the Homematic IP Connect API documentation. The node adds deviceId automatically. Every device control request also requires channelIndex, which must be included in the payload.
Example for the request path /hmip/device/control/setSwitchState (switch channel 1 on):
  "payload": {
    "on": true,
    "channelIndex": 1
The channel index can be looked up in functionalChannels of the device (for example with get feature value or in the global context homematicHcu.systemState).
If msg.payload is not an object, it is sent as { "value": <payload>, "deviceId": "..." }. An empty payload results in { "deviceId": "..." }.
Generated request
The following request is generated by the node and sent to the HCU:
  "pluginId": "plugin-id",
  "id": "request-id",
  "body": {
    "path": "/hmip/device/control/setSwitchState",
    "body": {
      "on": true,
      "channelIndex": 1,
      "deviceId": "device-id"
Output
The node correlates the response using the generated request ID. When the matching HMIP_SYSTEM_RESPONSE arrives, the input message is forwarded with msg.payload set to the generated request and the response attached as:
msg.payload.response
Example of a successful response:
  "type": "HMIP_SYSTEM_RESPONSE",
  "id": "request-id",
  "body": {
    "code": 200
The output is also emitted when the HCU rejects the request. In that case msg.payload.response.body.code is not 200 and msg.payload.response.body.body.errorCode contains the reason (for example INVALID_REQUEST, UNKNOWN_DEVICE or FEATURE_NOT_SUPPORTED). The node additionally shows a red status with code and error code (for example 400: INVALID_REQUEST) and reports an error that can be handled with a Catch node.
The timeout is 15 seconds. If no matching response arrives, the node reports an error and emits no output.
The resulting state change is reported separately by the HCU as a DEVICE_CHANGED event (see feature event).
Create User Message
create user message sends a CREATE_USER_MESSAGE_REQUEST to the HCU. The message is then displayed on the home screen of the Homematic IP app.
  • Message category: INFO, ERROR, or WARN.
  • Title: Message title.
  • Message: Message text.
The behavior type is always DISMISSIBLE: users can dismiss the message in the app, and the plugin is not notified about it. Every message gets a new userMessageId.
The title and message are sent as language maps using the same text for German and English:
  "de": "Message text",
  "en": "Message text"
Runtime overrides
The configured values can be overridden by:
msg.messageCategory
msg.title          (string)
msg.message        (string)
msg.timestamp      (milliseconds since epoch, default: now)
Output
The input message is forwarded and msg.payload is replaced with the message sent to the HCU. It contains the userMessageId, which is needed to delete the message later.
  "id": "generated-id",
  "type": "CREATE_USER_MESSAGE_REQUEST",
  "body": {
    "userMessageId": "generated-uuid",
    "behaviorType": "DISMISSIBLE",
    "messageCategory": "INFO",
    "timestamp": 1710000000000,
    "title": {
      "de": "Title text",
      "en": "Title text"
    "message": {
This node does not wait for a response. Use hcu in with the CREATE_USER_MESSAGE_RESPONSE filter if confirmation is required.
Delete User Message
delete user message sends a DELETE_USER_MESSAGE_REQUEST.
Input
The user message ID must be provided in msg.payload:
  "payload": "user-message-id"
You can take the user message ID from the output of the create user message node (msg.payload.body.userMessageId).
Generated request
  "id": "msg.id-or-generated-id",
  "type": "DELETE_USER_MESSAGE_REQUEST",
  "body": {
    "userMessageId": "user-message-id"
The id is taken from msg.id if present, otherwise it is generated.
The output forwards the input message and replaces msg.payload with the generated request object.
This node does not wait for or correlate a delete response. Use hcu in with the DELETE_USER_MESSAGE_RESPONSE filter if confirmation is required.
HCU message types
The package sends or receives the following Connect API message types:
HMIP_SYSTEM_REQUEST
HMIP_SYSTEM_EVENT
ERROR_RESPONSE
All other message types can be sent with hcu out and received with hcu in.
The exact body schema depends on the selected HCU operation. Consult the official Homematic IP Connect API documentation for the supported API paths and schemas.
Status and errors
The nodes use Node-RED status indicators to show connection and processing state. Common statuses include:
connecting...
connected
disconnected (<code>)
HTTP <status code>
<cause>, retry in <n> s
not connected
waiting for events
listening
event received
feature matched
value loaded
waiting for response
response received
message sent
request sent
send failed
feature missing
device missing
no cache
connection failed
timeout
Common errors include:
WebSocket is not connected
HCU config node not found
No cached HCU system state available
No devices found in cached HCU system state
Timed out waiting for HMIP_SYSTEM_RESPONSE
WebSocket handshake rejected: HTTP <status code>
HCU ERROR_RESPONSE (<code>): <message> - original message: <message>
Security
  • Protect the Node-RED editor and runtime with a login (adminAuth in the Node-RED settings.js).
  • The device list for the editor is provided by the admin endpoint /homematic-hcu/<connectionId>/devices. If adminAuth is enabled, it is only available to logged-in users with read permission (hcu-config.read, included in read and *). Without adminAuth, it is accessible like the rest of the editor.
  • Treat HCU authentication tokens and activation keys as secrets.
  • Do not place real tokens in README files, screenshots, examples, issue reports, or exported flows.
  • Avoid connecting authentication output directly to Debug nodes in production.
  • The cached system state is also stored in the global context (homematicHcu.systemState). If you use a persistent context store, it is written to disk.
  • Enable self-signed certificate support only in a controlled environment.
  • Restrict network access to the HCU WebSocket and HTTPS ports.
Troubleshooting
The node reports not connected
Check:
  • HCU IP address or host name.
  • Network connectivity from the Node-RED host.
  • HCU WebSocket port 9001 and whether the WebSocket is exposed in the developer mode settings.
  • authToken.
  • pluginId (must match the plugin identifier used to create the token).
  • TLS certificate trust.
  • Whether self-signed certificate support is required.
The node shows HTTP 401 or HTTP 403
The HCU rejected the token or the plugin ID. The node keeps retrying with an increasing delay (up to 5 minutes), but the connection will not succeed until the values are corrected. Check both values and redeploy; the delay starts again at 5 seconds.
The device list is empty
The editor loads devices from:
Check that:
  • the configuration node exists and has been deployed.
  • the WebSocket connection is open.
  • the initial system state has been received.
  • the system state contains a devices array or object map.
  • the Node-RED editor can access the admin endpoint. If adminAuth is enabled, the logged-in user needs read permission.
get feature value produces no message
Check:
  • the device still exists in the cached state.
  • the configured value is exactly device.id.
  • the feature name matches the HCU data exactly (case-sensitive).
  • the feature is located in functionalChannels or supportedOptionalFeatures.
set feature value times out
Check:
  • the WebSocket connection.
  • the selected request path.
  • whether the HCU returned an ERROR_RESPONSE (shown as HCU ERROR_RESPONSE … in the debug sidebar, also available with hcu in and the filter ERROR_RESPONSE).
  • whether the HCU returned an HMIP_SYSTEM_RESPONSE with the same request ID.
set feature value returns a code other than 200
Check msg.payload.response.body.body.errorCode:
  • INVALID_REQUEST: a required field is missing, usually channelIndex.
  • UNKNOWN_DEVICE / UNKNOWN_CHANNEL: wrong device or channel index.
  • FEATURE_NOT_SUPPORTED: the selected request path does not fit the device.
Development
Install dependencies:
npm install
Install the package locally in Node-RED:
Examples
The package currently does not provide importable example flows. Screenshots in the examples directory support understanding of node functionality.
MIT License. See the LICENSE file for the complete license text.
Support
I cannot guarantee prompt support, as this is a hobby project. Please use the GitHub issue tracker for bug reports and feature requests.
Version: 1.1.5
Updated 6 days ago
16 in the last week
  • hcu-config
  • hcu-out
  • hcu-in
  • set-feature-value
  • get-feature-value
  • feature-event
  • create-user-message
  • delete-user-message
  • New HCU connection
  • homematic
  • homematic IP
  • Home Control Unit
  • hcu
  • HCU
  • connect-api
  • websocket
  • eq-3
