node-red-contrib-homeconnect 0.6.8
Node-RED-nodes for Home Connect
npm install node-red-contrib-homeconnect
This nodes for Node-RED allow to control devices which are connected to the Home Connect system.
To use the HomeConnect nodes a Client ID and Client Secret are required. Those can be received from the home connect developer page:
https://developer.home-connect.com/
  • After setting up an account, register a new application and select Authorization Code Grant Flow as the OAuth Flow.
  • Use the callback URL that is configured in the auth node as Redirect URI of your application.
Available Nodes
home-connect-auth
The node handles the authentication for the HomeConnect Developer API.
Start the authorization from the properties dialog, finish the authorization at Home Connect and then save and deploy your changes.
Node Properties
Property Information
Name Name of the node (optional)
Client Id Enter the Client ID available on the HomeConnect Developer Portal
Client Secret Enter the Client Secret available on the HomeConnect Developer Portal
Use Simulation Wheter or not simulation or real appliances shall be used
home-connect-request
The Request node requires an home-connect-auth node as an config node to recevice an access token.
An input triggers the request to the HomeConnect API.
Node Properties
Tag Category you want to control
Action Action you want to perform
HAID HAID of the home appliance
Option Key Option Key in case you want to control a specific option
Body JSON data in case you want to set e.g. a program or option
home-connect-event
It outputs event messages for the selected home appliance.
Node Properties
Version: 0.6.8
Updated 4 months, 3 weeks ago
Rating: 3.0 4
246 in the last week
  • home-connect-auth
  • home-connect-request
  • home-connect-event
  • Alexander Knöbel
  • Patrick Hieber
