node-red-contrib-homebridge-automation 0.3.5
NodeRED Automation for HomeBridge
npm install node-red-contrib-homebridge-automation
Homebridge Automation powered by Node-RED
The above Node-RED Flow, turns on my 'Outside Office' light when the powder room is turned on, and turns them both off after 10 seconds. Not practical but a good sample of the power behind Node-RED. Link to exported flow for above.
Table of Contents
Introduction
This is a release of the ability to integrate Homebridge Accessories into Node-RED so that you can start flows from Homebridge accessory events and control your existing homebridge accessories. ( To create accessories in HomeKit, please use node-red-contrib-homekit-bridged. )
Homebridge Nodes
Four different node types are available, the first node hb event listens for changes to an accessory (ie on/off) and sends a message into Node-Red containing the updated accessory status. The second node hb resume holds the state of an accessory and supports creating a state resume function. The third node hb status allows you to poll an accessory for status. The forth node hb control allows you to control a homebridge accessory. Each node is tied to an individual Home App Tile/Service of an accessory (ie on/off and brightness).
Payload from a dimmable lightbulb.
{ "On":true, "Brightness":100 }
Homebridge Nodes
Caveats
  • Please keep in mind that this integration only works with devices supported/exposed with HomeBridge Plugins. This does not have visibility to Native HomeKit devices. ( Similar to my homebridge-alexa plugin. )
  • For the hb event node, the ability of a Accessory to generate events in Real Time is dependent on how the plugin was architected and the actual device. Some are very good at generating events in real time, and others only generate events when the Home App is opened to the accessory. YMMV.
With a plugin, you can see if it supports Real Time events, by opening the Home App, and looking at an accessory. Then trigger a local event outside of homebridge/homekit. If the accessory updates in real time, then it support Real Events. ( An example of a local event can be turning on a Smart Light Switch, by the local switch. Another example would be using the vendor app to control an accessory.)
Changes
Mar 18, 2019 - Version 0.0.39
  • Changed hb state to hb resume to make the use case for the node more self-explanatory. If you had used the hb state node in your existing flow, nodeRed will not start unless you manually change the node type in the flow file. To fix the issue, manually edit the flow file in your .node-red directory, and change the type reference hb-state to hb resume
  • Changed individual nodes from being characteristic based to device/service based. When updating from previous versions, you will need to select your devices again.
  • With the change in nodes to be device/service based, the payload message structure changed from being individual characteristic based to a JSON object containing all the characteristics you want to update on the device. ie in the previous version a device control message payload of true going to the On characteristic would turn on a light, with this version it would be be represented with a message payload of { "On":true, "Brightness":100 }. This particular payload would turn on a light and set the brightness to 100. I made this change to enable easier intergradation with node-red-contrib-homekit-bridged.
  • If you send an incorrect message payload to the hb resume or hb control nodes it would output a debug message containing the valid/supported characteristics for use in the payload object.
  • Updated the Homebridge accessory parser, so more diverse devices will now be exposed.
Mar 19, 2019 - Version 0.0.42
  • Fix for events being missed after homebridge restarts
Mar 31, 2019 - Version 0.0.
  • Fix for a crash when events are received by an accessory with multiple services.
May 9, 2019 - Version 0.0.43
  • Added retries for registering of events during startup. ( 1000 retries, retry delay of 30 seconds )
May 15, 2019 - Version 0.0.44
  • Added reqTimeout and set default timeout on homebridge requests to 14 seconds
May 29, 2019 - Version 0.0.45
  • Name Change to Homebridge-Automation
July 27, 2019 - Version 0.0.50
  • Publish as a NPM package to resolve #17
Feb 24, 2020 - Version 0.0.56
  • Fix for device naming for Nest FAN and ECO Mode
Mar 18, 2020 - Version 0.0.59
  • Support for the new version of HAP-NodeJS
Oct 13, 2020 - Version 0.0.71
  • Realize that I have not updated the change log for a while, so this is a laundry list of changes since 0.0.59
  • Additional error logging
  • Fix for issue #47 and #48
  • Support camera devices - tks dxdc
  • Improved timeout support
  • Support for the latest version of homebridge
Oct 24, 2020 - Version 0.0.71
  • Added support for plugins that allow device name editing within the Home app.
Nov 1, 2020 - Version 0.0.73
  • Added support for Air Pressure and Power devices
  • Fixed issue #69 TV accessory events not firing since update of homebridge-broadlink-rm plugin
Nov 13, 2020 - Version 0.0.76
  • Update HB Control Node to output snapshot images from camera's. Payload output format is a buffer object containing image.
Feb 2, 2021 - Version 0.0.78
  • Change hb-control to display control message payload rather than 'Ok'
  • Tweak device parser to remove these duplicates
    • Camera RTPStream Management
    • Input Source with a name of 'dummy'
Mar 9, 2021 - Version 0.0.80
  • hbEvent: add option to send initial state
April 23, 2021 - Version 0.0.82
  • Support for homebridge instances with different PINS. Tks @dxdc
Dec 31, 2022 - Version 0.1.3
  • Removal of request dependency from hap-node-client
Jan 6, 2023 - Version 0.1.5
  • Remove support for ipv6
Jan 11, 2023 - Version 0.1.7
  • Fix for #110 and homebridge-alexa #564
Jan 15, 2023 - Version 0.1.8
  • Workaround for #111
Dec 15, 2024 - Version 0.2.0
  • Major code base refresh, and migration from hap-node-client to hap-client ( Potential fix for #120 )
  • With the change in connectivity to homebridge, please validate all your nodes are connected after the update. And pay particular attention to Camera nodes, as for some devices the name has changed.
  • Testing and Development was completed on Node-RED version: v4.0.2 and Node.js version: v20.18.1
April 15, 2025 - Version 0.3.0
Breaking Change
  • Problem when choosing between multiple accessories with the same name #142. This fix has a breaking change for the name structure for Fans, Input Sources from TV's, and Camera's. And these devices will need to be configured again.
Fixes
  • Add common supported types Window, Window Covering, Light Sensor #151, tks @HDeKnop
  • HB-Control Node Turns Off then On when this message is received #152
  • Added Debug logging configuration option that creates a file homebridge-automation-endpoints.json, which contains all the homebridge devices discovered. It can be used as part of troubleshooting device issues.
  • Fix for some camara devices not outputing events
Jan 15, 2026 - Version 0.3.3
Breaking Change
  • An early change broke the behaviour of the status node, and it emits all events, and not just on request. Original behaviour has been restored. If you require all events, use the event node.
Fixes
  • Fix for #195 - Status node sends messages on device state change without input trigger
Version 0.3.4
Breaking Change
  • Updated support for power bars and devices with multiple services (#216, #212, #221). As a side effect, the number of devices returned has increased and the names of devices with multiple services have changed. Please revisit your devices after installing. If, after updating, a node cannot connect to the appropriate device, the debug log will contain ERROR: Device registration failed. You will need to re-select the device in the drop down. In my setup, nodes with Camera Motion sensors and Ceiling Fans needed to be revisited.
Changes
  • Fix deploy reconnection, message queuing, and editor UX (thanks @dxdc) #215
New Features
  • Added logging of device naming/uniqueId collisions. Devices with duplicate names present only one option for selection. If a duplicate is detected, the debug log will show it as a Duplicate uniqueId. To resolve, change the device name in the Home App to be unique.
  • Added Ignored Instances configuration option on the hb-conf node. Accepts a comma-separated list of Homebridge instance MAC addresses to exclude from discovery (e.g. 34:42:4E:4A:38:00, 6E:69:51:34:54:00). Useful when you have Homebridge instances you do not want to integrate with Node-RED.
  • Added HAP-Client Debug configuration option on the hb-conf node. When enabled, it enables debug logging within the HAP-Client library, which outputs detailed HAP protocol information. Useful for troubleshooting Homebridge instance discovery issues.
Version 0.3.5
Changes
  • Support for custom characteristics including voltage, current, and power data of devices with the power meter function has been added to resolve #231
  • Added support for security system and cooler/heater devices #232
Backlog / Roadmap
    • Update Node Information with Homebridge Accessory Details ( hapEndpoint, deviceType, description )
    • Sort device drop down listing
    • Trim Node name to just accessory Name
    • Documentation - Fix README with latest options
    • Documentation/Naming - Normalize on Accessory, Service, Event and Characteristic
    • Hap-Node-Client is not reentrant, and multiple requests get lost. Needs queuing at an instance level.
    • Refactor interface with Hap-Node-Client, and split events into a dedicated evented socket connection and use the regular request module for everything else.
    • Create a service/characteristic based node approach mimicking homekit icons
    • Adjust msg.payload to match other homekit / NodeRED integrations
    • Further stability testing
    • With hb-event add a delay function of about 30ms to put back together device level events
Dropped items
    • Add timestamp to Node msg object
    • Do I need a node that emits events for all homebridge devices?
Installation Steps
1 - Install Node-RED and Homebridge
This is covered in alot of other places, so I won't cover it here.
2 - Prepare Homebridge for integration with Homebridge-Automation
Place your homebridge instances into "INSECURE MODE". This is same as my Homebridge Alexa plugin, and you just need to follow the Prepare homebridge for plugin instructions there.
3 - Install Homebridge-Automation into Node-Red
4 - Start Node-Red
5 - Initial setup and configuration inside Node-Red
  • 5.1 Select 'hb event' node and place onto flow.
  • 5.2 Double click on hb event node ( now called 'Choose accessory/event')
Choose
  • 5.3 Please select the pencil to the right of the PIN Field.
Pencil
  • 5.4 Please enter your PIN, and select Add.
Pin Entered
  • 5.5 Now select Done.
Done
  • 5.6 Now select Deploy
  • 5.7 Please wait about 30 seconds. ( Node-RED is busy discovering all your accessories.)
  • 5.8 Initial setup and config is complete.
6 - Configure 'hb event' to receive updates from your Accessories
  • 6.1 Double click on hb event node ( now called 'Choose accessory/service')
Populated
  • 6.2 The device drop down should now be populated with all your Homebridge accessories.
Populated
The accessory naming convention is:
Accessory Name and Accessory Service Type
Node-RED Homebridge-Automation Message Structure
hb event
This node generates a message every time an Accessory changes status, and generates a message containing the updated status of all the characteristics.
Output
Message is structured like this
msg = {
  payload: { "On":true, "Brightness":100 }
  Homebridge: Homebridge instance name,
  Manufacturer: Plugin Manufacturer,
  Type: Homebridge device type,
  _device: Unique device identifier,
  _confId: node.confId,
  _rawEvent: Raw event message
Message payload will vary depending on characteristics support by the device, this example is from a dimmable light.
Please note that multiple event messages may be received from a single device event, this is due to how homebridge controls devices and emits events.
hb resume
This node can be used to create a resume previous state flow. Where you change the state of an accessory, and have it resume the previous state afterwards. I'm using this, in conjunction with Alexa to give the ability to turn on and off the lights in a room, but not turn any lights that were already on. I'm also using it with the HomeKit "I'm home" automation, to turn a group of lights for a few minutes then turn off. But at the same time have any lights you already had on, stay on.
input
Based on the message input payload and state of the accessory the output changes.
For {"On":true}, the node just passes the message to output. For the first {"On":false}, the output is the state of the accessory from prior to the last turn on. For the second {"On":false}, the out is {"On":false}.
msg = {
output
msg = {
Message payload will vary depending on characteristics support by the device, this sample is from a dimmable light.
To find supported characteristics for a device, please send an invalid message payload to the node, and it will output the supported characteristics in the debug log.
hb status
This node allows you to poll a Homebridge accessory and collect the current status of all the characteristics.
input
Anything
output
msg = {
hb control
This node allows you to control all the characteristics of a Homebridge accessory. The message payload needs to be a JSON object containing the values of all the characteristics you want to change. If you send the node an invalid payload, it will output all the available characteristics of the accessory in the debug tab.
Input
The hb control node only looks at msg.payload value, and ignore's all others.
msg = {
Flows Shared from Community
I have started collecting flows for useful functions on the wiki.
https://github.com/NorthernMan54/node-red-contrib-homebridge-automation/wiki
Donations
Donate
Troubleshooting / DEBUG MODE
To start Node-RED in DEBUG mode, and output Homebridge-Automation debug logs start Node-RED like this.
DEBUG=-express*,-send*,-body-parser*,* node-red
Version: 0.3.5
Updated 6 months, 1 week ago
Rating: 5.0 4
1534 in the last week
  • hb-conf
  • hb-event
  • hb-resume
  • hb-status
  • hb-control
  • HomeBridge
