node-red-contrib-holiday 1.2.0
A Node-RED node that routes a message depending on whether the given date is a public holiday or a weekend, for 200+ countries.
npm install node-red-contrib-holiday
This is my first node red contribution. Pull requests are welcome if you have any improvements! :ok_hand:
This node uses the date-holidays npm package to look up which days are holidays.
You can easily select which types of holidays to include, and also add weekends or any days of the week to include. Leaving every holiday type unticked is the same as ticking them all — that's how the underlying library behaves.
msg.payload is the date to check — not the current date. Send it a timestamp (an inject node's timestamp works as-is).
Timezone defaults to the country's own, and decides both which day a holiday falls on and which day counts as the weekend. Set it explicitly if your Node-RED runs somewhere other than the country you're asking about.
This node has two outputs: the top output will be triggered when the input date is a match for holiday or weekend, and the bottom output will be triggered when it's not a match. The top node will also add these properties:
  • weekend is true if the day matches your preset weekend-days, false if not
  • holiday holds details from the underlying library about the holiday, including the name and the type (public, bank, observance etc)
  • holidays is the full list, for the odd date that matches more than one holiday
A payload that isn't a date, or an unknown country or timezone, raises an error you can catch with a catch node rather than quietly reporting "not a holiday".
Example usage will be to stop the flow if it is a non-work day, or delay actions on weekends.
example
Version: 1.2.0
Updated 3 months, 1 week ago
5 in the last week
  • holiday
  • holiday
  • holidays
  • weekend
  • public holiday
  • bank holiday
  • calendar
