node-red-contrib-hep 0.1.0
A Node-RED node to encode and decode hep buffers
npm install node-red-contrib-hep
Node-RED function that takes the msg.payload and encapsulates or decapsulates it to HEPv3.
Either use the Manage Palette option in the Node-RED Editor menu, or run the following command in your Node-RED user directory - typically ~/.node-red
    npm i node-red-contrib-hep
If the input is a buffer it tries to parse it as hep and creates a javascript object. If the input is a javascript object w/ HEP rcinfo and payload, it will create a HEPv3 buffer.
Example: payload
ACK sip:[email protected] SIP/2.0
Via: SIP/2.0/UDP 192.168.1.23:5060;rport;branch=z9hG4bK484759904
To: <sip:[email protected]>;tag=1d24a28a0bded6c40d31e6db8aab9ac6.4679
Call-ID: 1003554701
CSeq: 20 ACK
Content-Length: 0
Example: rcinfo
rcinfo = { type: 'HEP',
  version: 3,
  payload_type: 'SIP',
  captureId: '2001',
  capturePass: 'myHep',
  ip_family: 2,
  time_sec: 1433719443,
  time_usec: 979,
  protocol: 17,
  proto_type: 1,
  srcIp: '192.168.100.1',
  dstIp: '192.168.1.23',
  srcPort: 5060,
  dstPort: 5060
Version: 0.1.0
Updated 7 years, 2 months ago
1 in the last week
  • hep
  • node
  • hep
  • parser
  • serializer
  • encoder
  • decoder
  • packet
