node-red-contrib-heat-curve 1.0.0
Node-RED heating curve node - calculates flow temperature setpoint based on outdoor temperature
npm install node-red-contrib-heat-curve
Node-RED Heating Curve Node - calculates flow temperature setpoint based on outdoor temperature (Heizkurve).
  • Configurable heating curve with slope or design mode
  • Night setback (Nachtabsenkung)
  • Summer lockout (Sommerabschaltung)
  • Two outputs: Flow temp + Heating active boolean
  • Min/max flow temperature limits
  • Runtime overrides via message properties
Formula
flowTemp = roomTemp + slope × (roomTemp - outdoorTemp) + shift
With setback: flowTemp = flowTemp - setbackDelta
Outputs
  • Output 1: Flow temperature setpoint (°C) or null if summer lockout
  • Output 2: Heating active boolean (true = heating, false = summer lockout)
Example
slope=1.0, roomTemp=20, shift=0:
Outdoor -10°C → Flow 50°C
Outdoor   0°C → Flow 40°C
Outdoor  10°C → Flow 30°C
With setback (delta=10K):
Outdoor -10°C → Flow 40°C (50-10)
Summer lockout (threshold=18°C):
Outdoor 20°C → Output 1: null, Output 2: false
Property Description Default Range
Mode Slope or Design slope -
Slope Curve steepness 1.0 0.2–3.0
Design Outdoor Design outdoor temp -15 -
Design Flow Design flow temp 55 -
Room Temp Room setpoint 20 -
Shift Parallel shift (Niveau) 0 -15 to +15
Min Flow Minimum flow temp 20 -
Max Flow Maximum flow temp 75 -
Setback Delta Night setback reduction 10 0–30 K
Summer Lockout Lockout threshold 18 -
Decimals Decimal places 1 0–2
Input
  • msg.payload - Outdoor temperature in °C
  • msg.setback - true to activate night setback
Runtime Override
All configuration values can be overridden via msg properties. Setback state is retained until explicitly changed.
msg.setback Activate night setback (sticky)
msg.setbackDelta Override setback delta
msg.summerLockout Override summer lockout threshold
msg.slope Override slope
msg.designOutdoor Override design outdoor temp
msg.designFlow Override design flow temp
msg.roomTemp Override room setpoint
msg.shift Override shift
msg.minFlow Override min flow temp
msg.maxFlow Override max flow temp
Output
Output 1:
  "payload": 50.0,
  "heatCurve": {
    "outdoorTemp": -10,
    "flowTemp": 50.0,
    "slope": 1.0,
    "roomTemp": 20,
    "shift": 0,
    "minFlow": 20,
    "maxFlow": 75,
    "clamped": false,
    "clampedAt": null,
    "setback": false,
    "setbackDelta": 10,
    "flowTempBeforeSetback": 50.0,
    "summerLockout": 18,
    "heatingActive": true
Output 2:
  "payload": true
Node Status
  • -10°C → 50.0°C - Normal heating
  • -10°C → 40.0°C (setback) - Night setback active
  • 20°C → locked out - Summer lockout
  • -20°C → 75.0°C (clamped max) - Clamped to limit
Use Cases
Application Description
HVAC Heating system control
Building Automation Weather-compensated heating
Heat Pump Flow temperature optimization
Night Mode Reduced heating at night
Author
sr.rpo
MIT
Version: 1.0.0
Updated 8 months ago
135 in the last week
  • heat-curve
  • heat-curve
  • heating
  • hvac
  • heizkurve
  • flow-temperature
  • building-automation
