node-red-contrib-heap-guardian 0.2.2
Memory pressure monitor and guarded GC trigger nodes for Node-RED.
npm install node-red-contrib-heap-guardian
Memory pressure monitor, leak profiler, dashboard renderer, and guarded GC nodes for Node-RED.
This package does not replace V8 garbage collection. It observes memory pressure and helps investigate Node-RED memory growth through a trend -> alert -> suspect -> snapshot -> dashboard/prometheus workflow.
Repository:
https://github.com/Doompy/node-red-contrib-heap-guardian
Compatibility
  • Node-RED >=2.0.0
  • Node.js >=12.17.0
Node.js 12 and 14 are end-of-life, so Node.js 18 or later is still recommended for production. The lower runtime floor is kept so older Node-RED 2.x installations can install the package.
Feature availability is capability-based:
  • runtime-profiler requires Node-RED runtime messaging hooks. If hooks are unavailable, it reports runtime-hooks-unavailable instead of breaking startup.
  • Manual GC requires Node-RED to be started with --expose-gc.
  • Heap snapshots require v8.writeHeapSnapshot; if unavailable, snapshot nodes return a structured skipped result.
heap-monitor
Emits a memory snapshot to msg.payload.
The snapshot includes:
  • process.memoryUsage() values
  • V8 heap statistics
  • Optional V8 heap space statistics
  • Heap pressure ratios
gc-trigger
Runs globalThis.gc() only when it is available and the configured guard conditions pass.
$env:NODE_OPTIONS="--expose-gc --max-old-space-size=1024"
node-red
Without --expose-gc, the node returns a structured skipped result instead of failing the flow.
heap-snapshot
Writes a V8 heap snapshot to disk when guard conditions pass.
The Docker example writes snapshots to:
/data/heap-snapshots
Heap snapshot creation can pause Node-RED and may need substantial temporary memory. In production, use a high threshold and a long cooldown.
When a snapshot is written, Heap Guardian stores metadata in Node-RED global context under heapGuardianSnapshots. Metrics JSON reports include the latest, previous, baseline, and size/memory deltas.
payload-profiler
Estimates the size of msg.payload or another message property.
By default it passes the message through unchanged and adds:
msg.heapGuardian.payloadProfile
It also records an aggregate sample in global context, keyed by flow id, profiler node id, and message property. For object-like payloads it can also record the largest immediate child keys, such as payload.items or payload.cache.
context-profiler
Estimates flow/global context key sizes and emits the largest keys.
This is useful for catching patterns such as:
flow.set("items", growingArray)
global.set("cache", growingObject)
The profiler excludes its own heapGuardianProfiler aggregation key by default.
profiler-report
Outputs aggregate records collected by payload-profiler, context-profiler, and runtime-profiler.
The report also includes:
  • analysis.topGrowers: records whose latest sample grew the most
  • analysis.topTrends: records with the largest recent history growth
  • analysis.topContextGrowers: flow/global context records growing fastest
  • analysis.topContextTrends: alias-compatible context trend output for dashboards
  • analysis.topPayloadKeys: payload child properties carrying or growing the most data
  • analysis.topExpanders: runtime nodes whose send payload is larger than their receive payload
  • analysis.suspects: scored records and runtime expansions most likely to explain retained or amplified data
  • analysis.alerts: warning/critical growth and expansion alerts with evidence
  • dashboard: dashboard-ready status, cards, and alert/suspect/context trend tables
analysis.topExpanders suppresses expansion ratios when the receive baseline is too small, so tiny inbound payloads do not produce misleading ratios. In that case the report still shows deltaBytes and a ratioStatus. Suspect and alert entries include summary, severity, and evidence fields for quick triage. Alert entries also include a stable id for deduplication. Growth and runtime expansion thresholds can be overridden from node settings or HTTP query parameters when the defaults do not match your environment.
Each profiler record keeps a small in-memory history ring buffer. The default limit is 10 samples. History entries contain:
  "timestamp": "2026-05-04T00:00:00.000Z",
  "bytes": 1048576,
  "deltaBytes": 262144
Sort options include:
  • last observed size
  • max observed size
  • total observed bytes
  • sample count
HTTP flows can filter report output with query parameters:
/heap-guardian/profile/report?kind=runtime-payload&minDeltaBytes=1048576
/heap-guardian/profile/report?property=payload.items
/heap-guardian/metrics?nodeType=function&limit=5
The profiler-report node can also apply the same filters from its editor settings or from msg.profilerFilter.
runtime-profiler
Registers Node-RED runtime hooks and automatically samples message property sizes as messages move through flows.
It records samples by:
  • flow name/id
  • node name/type/id
  • direction, such as send or receive
  • property, such as payload or payload.data
  • largest immediate child properties, such as payload.items
Use a low sample rate in busy production systems. The leak lab example uses 100% sampling only so the behavior is easy to see locally.
Adaptive sampling is available as an opt-in mode. When enabled, runtime-profiler can temporarily raise its sample rate during warning/critical alerts or high heap pressure. It is disabled by default, so existing flows keep their configured fixed sample rate.
metrics-report
Outputs current memory and profiler state as JSON or Prometheus text.
Place it behind an HTTP In node to expose endpoints such as:
/heap-guardian/metrics/prometheus
JSON output includes:
  • memory: current process and V8 memory state
  • profiler: profiler records and analysis
  • dashboard: status, cards, and dashboard tables
  • snapshots: latest, previous, baseline, comparison, and optional experimental object diff
Metrics JSON also includes profiler overhead estimates and async snapshot diff queue status when those features are enabled.
Prometheus output includes memory gauges, heap pressure ratios, profiler record metrics, and low-cardinality analysis summary metrics:
heap_guardian_profiler_alerts{severity="warning"}
heap_guardian_profiler_alerts{severity="critical"}
heap_guardian_profiler_suspects
heap_guardian_profiler_trends
The older high-cardinality profiler record metric remains enabled by default for compatibility. Disable it on busy systems with the includeProfilerRecordMetrics node option or query parameter:
/heap-guardian/metrics/prometheus?includeProfilerRecordMetrics=false
Use maxPrometheusRecords to cap how many profiler records are emitted when record metrics are enabled.
heap-dashboard
Renders a profiler-report or metrics-report JSON payload into an HTML string.
This node does not depend on Node-RED Dashboard. Connect it to an HTTP Response node, Dashboard template node, or ui-template node.
The generated HTML includes client-side search, severity filtering, and table sorting. Auto-refresh is optional and disabled by default.
Typical HTTP flow:
HTTP In -> metrics-report -> heap-dashboard -> HTTP Response
auto-gc-guard
Runs guarded GC only when an incoming report shows qualifying leak alerts and current heap pressure is above the configured threshold.
It is disabled by default and never runs on a background timer. It only evaluates when a message enters the node.
Default guard conditions:
  • enabled: false
  • requiredSeverity: critical
  • heap threshold: 85%
  • cooldown: 300 seconds
  • max runs per hour: 3
Manual GC still requires Node-RED to be started with --expose-gc. Without it, the node writes a structured skipped result to msg.heapGuardian.autoGc.
auto-snapshot-guard
Writes a heap snapshot only when an incoming report contains qualifying alerts and current heap pressure is above the configured threshold.
  • enabled: false
  • max snapshots per hour: 3
  • async diff after snapshot: false
The result is written to msg.heapGuardian.autoSnapshot. Optional async diff can be queued after a snapshot, but it is also disabled by default.
Experimental Snapshot Diff
metrics-report can compare the latest and previous V8 heap snapshot by constructor/type. This is opt-in because parsing heap snapshots can be expensive.
Enable with:
/heap-guardian/metrics?snapshotDiffEnabled=true
Defaults:
  • snapshotDiffEnabled: false
  • maxSnapshotDiffBytes: 134217728
  • snapshotDiffTimeoutMs: 30000
The diff returns topAdded, topGrowing, and topRemoved by constructor/type using countDelta and selfSizeDelta. Retainer paths and full dominator retained-size analysis are intentionally out of scope for this release.
For safer HTTP endpoints, use async diff instead of blocking the metrics request:
/heap-guardian/metrics?snapshotDiffAsyncEnabled=true
Async diff stores job status and latest results in Node-RED global context and exposes them under snapshots.diffStatus, snapshots.diffQueue, and snapshots.latestDiffResult.
Persistent History
Recent profiler history is kept in memory by default. JSONL persistent history is opt-in through environment variables:
$env:HEAP_GUARDIAN_HISTORY_FILE="C:\dev\heap-guardian-history.jsonl"
$env:HEAP_GUARDIAN_HISTORY_MAX_BYTES="52428800"
When the file reaches the max size, it is rotated to .1 and a new file is started. External databases are not used.
Upgrade Notes
When upgrading from 0.1.x to 0.2.0, reinstall the package and restart Node-RED so the editor loads the new node definitions.
For a local Node-RED user directory:
cd C:\Users\<you>\.node-red
npm install C:\dev\node-red-heap-guardian
For Docker development, remember that a persistent /data volume can keep an older installed module. Use a clean volume when testing a local package build:
docker compose down -v
docker compose up --build
Existing metrics-report nodes from 0.1.x continue to run with default values for the new 0.2.0 fields. If the editor still shows stale validation warnings after reinstalling, refresh the browser and restart Node-RED to clear cached node definitions.
Local Development
Runtime compatibility targets Node.js 12.17 or later, but repository verification and smoke scripts are run with Node.js 18 or later.
Install this project into a local Node-RED user directory:
Restart Node-RED after changing node files.
Run checks:
cd C:\dev\node-red-heap-guardian
npm run verify
Run the Docker smoke test:
npm run smoke:docker
The smoke test builds the image, installs the current package tarball into the running Node-RED /data directory, deploys the leak lab, and verifies profiler analysis endpoints.
Heap Leak Lab
The repo includes a synthetic leak flow for local testing:
examples/heap-leak-lab-flow.json
Deploy it to a running local Node-RED instance:
npm run deploy:leak-lab
Then call the test endpoints:
Invoke-RestMethod http://localhost:1880/heap-guardian/status
Invoke-RestMethod 'http://localhost:1880/heap-guardian/payload?count=256&bytes=16384'
Invoke-RestMethod 'http://localhost:1880/heap-guardian/leak?count=128&bytes=16384'
Invoke-RestMethod http://localhost:1880/heap-guardian/profile/context
Invoke-RestMethod http://localhost:1880/heap-guardian/profile/report
Invoke-RestMethod http://localhost:1880/heap-guardian/metrics
Invoke-RestMethod http://localhost:1880/heap-guardian/metrics/prometheus
Invoke-WebRequest http://localhost:1880/heap-guardian/dashboard
Invoke-RestMethod http://localhost:1880/heap-guardian/gc
Invoke-RestMethod http://localhost:1880/heap-guardian/snapshot
Invoke-RestMethod http://localhost:1880/heap-guardian/clear
/heap-guardian/payload generates a large transient payload and runs it through payload-profiler.
/heap-guardian/leak retains generated number arrays in Node-RED global context under heapGuardianLeak. This is intentionally wasteful and should only be used in a local test environment.
/heap-guardian/profile/context shows which context keys are retaining memory. Call /heap-guardian/leak and /heap-guardian/profile/context repeatedly to make analysis.topContextTrends and analysis.alerts visible.
The leak lab also includes a runtime-profiler node that automatically records large payloads sent and received by regular flow nodes. It excludes Heap Guardian's own nodes by default so the report focuses on application flow behavior. Call /heap-guardian/profile/report after multiple /heap-guardian/payload or /heap-guardian/leak requests to inspect analysis.topGrowers, analysis.topTrends, analysis.topPayloadKeys, analysis.topExpanders, analysis.suspects, and analysis.alerts.
/heap-guardian/dashboard returns a simple HTML dashboard generated from the metrics JSON.
/heap-guardian/snapshot writes a forced heap snapshot to /data/heap-snapshots in the Docker container and updates snapshot metadata for /heap-guardian/metrics.
/heap-guardian/metrics returns JSON. /heap-guardian/metrics/prometheus returns Prometheus text exposition format.
Docker
Build and run a Node-RED image with this node preinstalled:
Open Node-RED at:
The included docker-compose.yml sets:
NODE_OPTIONS: "--expose-gc --max-old-space-size=1024"
--expose-gc is required for the gc-trigger node to call globalThis.gc(). --max-old-space-size sets the V8 old-space heap limit in MiB.
The Docker image installs this package into Node-RED's /data user directory during the image build. The compose file also mounts a named volume at /data so flows and installed modules persist.
If you rebuild the image after changing this package but keep an existing named volume, Docker may keep the older installed module from the volume. For local development, reset the volume when you want a clean install:
For a production setup, prefer one of these patterns:
  • Build a versioned image and start it with a fresh or migrated /data volume.
  • Publish this package to npm and install that exact version inside your Node-RED project/package image.
  • Keep /data as a persistent volume, but run a controlled npm install node-red-contrib-heap-guardian@<version> migration when upgrading the node.
Production Notes
  • Do not expose the leak lab endpoints on a public or shared production Node-RED instance.
  • Protect any HTTP endpoints built from metrics-report, heap-snapshot, gc-trigger, or profiler-report with your normal Node-RED authentication and network controls.
  • Use a low runtime-profiler sample rate on busy systems.
  • Use heap snapshots sparingly because snapshot creation can pause Node-RED and temporarily increase memory pressure.
  • Treat --expose-gc as an optional diagnostic switch, not a fix for retained references.
  • Keep auto-gc-guard disabled until you have alert thresholds and heap pressure behavior that match your environment.
  • Keep auto-snapshot-guard and adaptive sampling disabled until you have tested their thresholds locally.
  • Disable high-cardinality Prometheus profiler record metrics if the label set is too large for your monitoring system.
Version: 0.2.2
Updated 6 months, 1 week ago
Rating: 5.0 2
597 in the last week
  • heap-monitor
  • gc-trigger
  • payload-profiler
  • context-profiler
  • profiler-report
  • runtime-profiler
  • heap-snapshot
  • metrics-report
  • heap-dashboard
  • auto-gc-guard
  • auto-snapshot-guard
  • node-red-contrib
  • memory
  • heap
  • gc
  • v8
