node-red-contrib-hdlbus 1.1.6
Node-Red implementation of HDL BusPro (SmartBus) protocol http://hdlautomation.com
npm install node-red-contrib-hdlbus
Node-Red implementation of HDL BusPro (SmartBus) protocol http://hdlautomation.com - forked from node-red-contrib-buspro, based on smart-bus.
The motivation for creating this node set was to fill a perceived gap in functionality. This package provides:
  • state storage of devices - all level updates are stored in a JS object
  • input/output nodes for device channels
  • input/output nodes for universal switches
  • a get node for device channels (based on stored values)
  • a button color node to change the LED color of the new capacitive touch buttons
  • a panel brightness node to facilitate dimming panels eg. at night
  • input/output nodes enabling the creation of a virtual HVAC device
  • raw nodes to allow you to craft messages to send/receive anything on the HDL network
This is by no means perfect - happy to hear any suggestions.
If you're looking for a event timer - check out eztimer.
BusPro-Controller
The node that holds connection to IP Gateway of BusPro (Smart-Bus) network (or broadcast address if using broadcast).
Config
defaults: {
            host: {value:"",required:true},   // HDL SmartBus gateway IP
            port: {value:6000,required:true,validate:RED.validators.number()},    // and port, default: 6000
            subnetid: {value: 1, required: true, validate: RED.validators.number()}, // Connector address in HDL network (Subnet ID)
            deviceid: {value: 99, required: true, validate: RED.validators.number()} // Connector address in HDL network (Device ID)
hdl-channel-in
Trigger flows based on pre-determined channel/level messages.
Output Payload
{ "level": 0 }
hdl-channel-out
Send channel level request.
Input Payload (Optional - used to override/specify any values)
    "address": "1.50",
    "channel": 1,
    "level" 100
hdl-channel-get
Returns the current level of a given channel. This is obtained from the level store maintained by watching events (rather than requiring a request/response to get the current level).
    "address": "1.50",
    "channel": 1,
Output Payload
    "address": "1.50",
    "channel": 1,
    "level" 100
hdl-uv-in
Trigger a flow based on a pre-determined uv switch change.
Output Payload
{ "state": false }
hdl-uv-out
Send UV switch request
    "address": "1.50",
    "switch": 1,
    "state" true
hdl-btn-color
Send request to update button color. This commands supports updating both the on and off colors independantly. This does not survive a device reboot.
  1. White
  2. Red
  3. Green
  4. Blue
  5. Orange
    "colorOff": 1
    "colorOn": 4
hdl-panel-brightness
Send request to update panel brightness (1-255). Note that low brightness values can impact the colors that can be produced.
    "address": "1.50",
    "brightness": 1,
hdl-virtual-hvac-in
Listens for HVAC request messages targetted at the specified address (eg. if you're emulating a HVAC device at 1.51, use 1.51 in the address field) and outputs the data as a JSON payload
Output Payload
    "acstatus": 1, //Status: 1 on, 0 off
    "acno": 1, //AC No, set in DLP
    "setupmode": 1, //Mode: 0 Cooling, 1 Heating, 2 Fan, 3 Auto, 4 Dry
    "setupspeed": 0, //Fan Speed: 0 Auto, 1 High, 2 Medium, 3 Low.
    "temperature": {
        "type": 0, //Type: 0 celsius, 1 farenheit
        "now": 21, //DLP Temprature
        "cooling": 21, //Cooling Temprature
        "heating": 21, //Heating Temprature
        "auto": 21, //Auto Temprature
        "dry": 21 //Dry Temprature
    "modeandfan": 48, //Mode and Fan always 48
    "currentmode": 21, //Current Mode Temprature
    "sweep": 0 //Sweep
hdl-virtual-hvac-out
Accepts a JSON payload (must be complete) and transmits to the broadcast (255.255) address with a source of the specified address (eg. if you're emulating a HVAC device at 1.51, use 1.51 in the address field).
Input Payload
    "temperature": {
    "sweep": 0 //Sweep
hdl-raw-in
Receive (any) commands from HDL (Smart-Bus) network
Output Message
msg:{
    "sender": "1.2" //ID of Sender Device
    "target": "255.255" //ID of Target Device
    "code": 50    //Integer with command operation code
    "payload": {}   //Object with decoded data or raw buffer if data can not be parsed automatically
hdl-raw-out
Send (any) commands to the HDL (Smart-Bus) network
Input Message
msg:{
    "target": "1.52" //ID of Target Device
    "code": 49    //Integer with command operation code
    "payload": { //Object with data or raw buffer
            "channel": 2,
            "level": 100
Change Log
1.1.4
  • Added input/output nodes for creating virtual HVAC device.
Version: 1.1.6
Updated 7 years, 4 months ago
Rating: 3.7 3
31 in the last week
  • hdl-controller
  • hdl-raw-in
  • hdl-raw-out
  • hdl-channel-in
  • hdl-channel-out
  • hdl-channel-get
  • hdl-uv-in
  • hdl-uv-out
  • hdl-btn-color
  • hdl-panel-brightness
  • hdl-dali-groups
  • hdl-virtual-hvac-in
  • hdl-virtual-hvac-out
  • hdl
  • hdlbus
  • smart-bus
