node-red-contrib-hcl-iterate-loop 0.0.2
This Node-RED node allows you to build a loop
npm install node-red-contrib-hcl-iterate-loop
Node-RED node to build loops and interact with others nodes in a flow. Basically working like a for loop.
Config iterate-loop
Below are the inputs properties required to make it possible.
  • Variable name, that can be associated to a context variable(msg, flow, global).
  • Value to start the loop, can be a number or a variable from a context(msg, flow, global).
  • Condition to finish the loop, choosing from an operator (==, <, <=, >, >=) and a value to compare with (number, msg, flow, global).
  • Increment/Decrement value (number, msg, flow, global). Note: for decrement is enough with enter negative values and for increment positive values.
The loop will continue as long as the condition it is TRUE, throwing an output to the output label continue in each iteration. When the condition changes to FALSE the loop will terminate an the output will be send to the output label exit
Basic example
With an example can be more straightforward to understand how this node works, the flow is available in the example folder of this repo.
iterate-loop resting
node0.png - node in resting mode
iterate-loop looping
node1.png - looping status
iterate-loop terminated
node2.png - terminated loop status
iterate-loop output
node-output.png - output from debug messages
iterate-loop properties
node-output.png - configuration properties of the node
Apache 2.0.
Version: 0.0.2
Updated 6 years, 3 months ago
4 in the last week
  • iterate-loop
  • loop
  • iterate
  • cycle
