node-red-contrib-haystack 0.1.2
Node-RED nodes for Project Haystack authentication and HTTP operations.
npm install node-red-contrib-haystack
Project Haystack node-red-contrib-haystack
Node-RED nodes for working with Project Haystack servers.
This package lets Node-RED authenticate with Haystack-compatible servers and call common Haystack HTTP API operations such as read, hisRead, eval, and pointWrite.
Supported server platforms include Haxall, FIN, SkySpark, and other Project Haystack-compatible systems.
Install from the Node-RED editor:
  1. Open Manage palette
  2. Go to Install
  3. Search for node-red-contrib-haystack
  4. Click Install
Or install from the command line in your Node-RED user directory, usually ~/.node-red:
Restart Node-RED after installation if required.
This package provides the following nodes:
Node Description
haystack-server Configuration node for server URL, project path, credentials, and token caching.
haystack-request Generic Haystack HTTP operation node. Use this for common or custom Haystack ops.
haystack-read Convenience node for the read operation.
haystack-hisread Convenience node for the hisRead operation.
haystack-eval Convenience node for the eval operation.
haystack-point-write Convenience node for the pointWrite operation.
Quick start
  1. Add one of the Haystack nodes, for example haystack-read or haystack-eval.
  2. Open the node configuration.
  3. Create a new haystack-server config node from the server field.
  4. Configure the connection settings.
  5. Deploy the flow.
Example configuration:
Base URL:    http://haystackServer:8080
Project Path: /api/myProjectName
The first request authenticates automatically. The authentication token is cached and reused by the runtime.
Example flow
An example flow is included in the repository:
examples/demo-flow.json
Example flow preview:
Example flow
After importing the flow, replace the placeholder refs with refs from your own Haystack server:
@POINT_REF
@EQUIP_REF
@WRITABLE_POINT_REF
Credentials are not included in the example flow. Configure them in the haystack-server config node after import.
haystack-server
The haystack-server node stores the shared connection settings used by the other Haystack nodes.
Field Description
Base URL Server root URL or hostname, for example http://haystackServer:8080 or https://haystack.example.com.
Project Path Haystack HTTP API path, usually /api/{projectName}.
Username Username used for Haystack authentication.
Password Password used for Haystack authentication.
Tip: for Haxall, the default project is commonly named sys.
Most nodes can be configured in the editor or controlled dynamically using msg.haystack.
The preferred message format is:
  "haystack": {
    "op": "eval",
    "expr": "readAll(point).limit(5)"
Older flat message fields are still accepted in some places for compatibility, but new flows should use msg.haystack.
Node details
haystack-request
Generic node for calling Haystack HTTP API operations.
Supports common and custom Haystack ops using msg.haystack.op.
Common message fields:
msg.haystack.op
msg.haystack.format
msg.haystack.outputMode
msg.headers
msg.payload
msg.rawBody
Returns:
msg.payload
msg.statusCode
msg.headers
haystack-eval
haystack-read
Supports reads by filter or record id.
haystack-hisread
Supports single-point history reads.
Supported actions:
write
manualAuto
emergencyAuto
Supported result modes:
array
ack
Formats
The nodes support these Project Haystack wire formats:
Format Description
Zinc Default format for generated request bodies.
JSON Can be returned as a parsed JavaScript object.
Trio Returned as a UTF-8 string.
Compatibility
This package is designed for platforms implementing the Project Haystack HTTP API and related Haystack protocols.
Compatible platforms include:
  • Haxall
  • FIN Framework
  • SkySpark
  • Niagara with the nHaystack driver
  • other Project Haystack-compatible platforms
The nodes support Zinc, JSON, and Trio Haystack wire formats.
References
MIT
Version: 0.1.2
Updated 6 months, 2 weeks ago
251 in the last week
  • haystack-server
  • haystack-request
  • haystack-read
  • haystack-hisread
  • haystack-eval
  • haystack-point-write
  • project-haystack
  • haystack
  • haxall
  • finstack
  • skyspark
  • hvac
  • bms
  • building-controls
  • building-automation
