node-red-contrib-hash-helper 0.0.3
Node-RED node for generating and verifying SHA hashes
npm install node-red-contrib-hash-helper
node-red-contrib-hash-helper :package:
This is a subflow node for generating and verifying SHA digested hashes from user defined payload.
Install :zap:
Generator API :gear:
  • :information_source: POST localhost:1880/generate
The data payload can be either a string or an object, you must define the function to use (SHA/HMAC) and the version of the algorithm (1/224/256/384/512/3)
GeneratorAPI
Generating Hash :inbox_tray: :arrow_right:
  • Setting the payload of the Generate Hash injector:
SHA1
Hash Result :receipt: :back:
  • Hash response payload:
SHA2
Generating HMAC :inbox_tray: :arrow_right:
:warning: In the case of HMAC, the key parameter must also be set!
HMAC1
HMAC Result :receipt: :back:
  • HMAC response payload:
HMAC2
Verifier API :toolbox:
  • :information_source: POST localhost:1880/verify
The data payload can be either a string or an object, you must define the function to use (SHA/HMAC), the version of the algorithm (1/224/256/384/512/3) and the hash to verify.
VerifierAPI
Verifying Hash :inbox_tray: :arrow_right:
  • Setting the payload of the Verify Hash injector:
SHA3
Hash Verification Result :receipt: :back:
SHA4
Verifying HMAC :inbox_tray: :arrow_right:
HMAC3
HMAC Verification Result :receipt: :back:
HMAC4
Version: 0.0.3
Updated 4 years ago
3 in the last week
  • node-red-nodegen
  • hash
  • sha
  • hmac
