node-red-contrib-hana-sql 1.0.6
Node-RED node to run SQL statements against a SAP HANA database
npm install node-red-contrib-hana-sql
A Node-RED node to read and write to a SAP HANA database.
Either use the Node-RED Menu - Manage Palette - Install, or run the following command in your Node-RED user directory - typically ~/.node-red
npm i node-red-contrib-hana-sql
Allows basic access to a SAP HANA database.
This node uses the query operation against the configured database. This does allow both INSERTS and DELETES.
By its very nature it allows SQL injection... so be careful out there...
The msg.topic must hold the query for the database, and the result is returned in msg.payload.
Typically the returned payload will be an array of the result rows.
If nothing is found for the key then null is returned.
The reconnect retry timeout in milliseconds can be changed by adding a line to settings.js
hanaReconnectTime: 30000,
The connection pool size can also be changed in settings.js
hanaPoolSize: 10,
An SSL connection can be enabled on the configuration node by switching on Encrypt (and optionally Validate Certificate).
Preparing Queries
msg.payload=[24, 'example-user'];
msg.topic="INSERT INTO users (`userid`, `username`) VALUES (?, ?);"
with named parameters:
msg.payload={}
msg.payload.userToChange=42;
msg.payload.newUsername="example-user";
msg.topic="INSERT INTO users (`userid`, `username`) VALUES (:userToChange, :newUsername);"
Documentation
Documentation of the SAP HANA client
Version: 1.0.6
Updated 3 months ago
  • HanaDatabase
  • hana
  • sap
  • sap-hana
  • hana
  • sql
