node-red-contrib-hal2 4.1.0
A set of nodes to help with basic home automation logic, now with MCP server support
npm install node-red-contrib-hal2
node-red-contrib-hal2 npm version
A set of nodes to help with basic home automation logic, with an optional MCP server so an AI assistant can read device state and control the house.
Upgrading to 4.0? hal2 now serves one MCP endpoint, the location's own catalogue on the Event handler's /mcp, and nothing else:
  • hal2MCPServer is removed. An embedded server only passed its tools on to the Event handler, so its tool nodes now point at the Event handler directly. A standalone server was an MCP server of its own, which is what node-red-contrib-mcp-server (3.0 or later) does; with that package installed, a standalone server and its nodes become its MCP Server, MCP In, MCP Out and MCP Call, keeping their ids and wires.
  • The admin tools are removed. get_flow and deploy_flow, and Allow admin tools on hal2Api, are gone; Node-RED is administered over MCP with mcp-server's MCP Admin node.
  • hal2Api calls the Event handler's catalogue only.
  • MCP In and MCP Out are now called tool call and tool result in the palette — the MCP specification's own terms — so they are not mistaken for mcp-server's nodes when both packages are installed. The types are still hal2MCPIn and hal2MCPOut. A tool call is a read or a write tool, held to the gate of that class; write is the default.
  • Arguments are checked against each tool's schema before it runs, for the built-in tools and for your own (switch Validate off on a tool whose schema cannot describe what it takes).
  • The Access claim defaults to sub rather than groups; an Event handler that set it keeps its value.
  • The deprecated hal2Group node is removed, and with it the Event handler's folding of such nodes at runtime. Groups live on the Event handler's Groups tab and membership on each Thing's items, as they have since 3.x; the conversion moves any group nodes there, keeping their ids, so Action and Event references still resolve.
Flows from 3.x still start: hal2MCPServer and hal2Group are kept as stubs that do nothing and say so. The editor offers to convert them when it loads them — one click, saved straight away. Each standalone server then becomes a resource of its own, <Server URL>/mcp/<path>, so the reverse proxy has to pass that path and /.well-known/oauth-protected-resource/mcp/<path>, the identity provider needs the resource, and its clients sign in again.
Upgrading to 3.2? thing_id and thing_name are now id and name, in parameters and responses alike. Items keep item_id and item_name. This is not only the MCP tools — the JSON API node calls the same tools, so your own HTTP callers need updating too. A client working from an older answer will use the old names and match nothing, so start a fresh conversation rather than debugging the miss. Also new: rooms, and a name matching several things is refused rather than applied to all of them.
Upgrading to 3.1? set_light no longer switches an undeclared switch item. A switch says only that something can be turned on and off — the load could be a lamp or a coffee machine — so a lamp behind a relay now needs device_class: light on its item, set under Items in the Thing config. Until it has one, set_light answers nothing_to_command naming what the items are, rather than reporting success and changing nothing. Items whose ha_type is already light, dimmer, color or color temperature are unaffected, as are control_device, control_group and every group you have built. See device class.
Upgrading from 2.x? 3.0.0 changed how the MCP server authenticates: it no longer takes part in OAuth at all, and an access gate now reads the access token and nothing else. If you run the MCP server, read the breaking-change note before deploying — the gates go quiet and refuse everyone if the claim they match on is missing from the token.
What is it?
node-red-contrib-hal2 is a set of Node-RED nodes useful for creating home automation flows. The basic component is the Thing node, a virtual representation of a (usually) physical IoT device. This can then be used to trigger events, route traffic based on rules and more.
Example Items
  1. Store a device state in a Thing node
  2. Fire an event when the value changes using an Event node
  3. One or more rules will compare the value and that of other Items in a Gate node
  4. Output the value to another flow with a Value node
  5. Send device commands to multiple Things using an Action node
  6. Log changes using the Log node
Example automation flows
node-red-contrib-hal2 uses the Node-RED built-in context store to save device state. If you'd like for state to survive a Node-RED restart you'll need to save context data to the file system (default is memory-only). You can choose to save all Node-RED context data to disk or to create a separate context store just for your IoT devices. I would recommend a separate context store for this use. node-red-contrib-hal2 lets you select which context store to use per thing type. Please take a look at the Node-RED documentation for instructions on how to configure the context stores.
Screenshot 2023-03-19 11.16.03
Take a look at the example flows and Thing definitions in the https://github.com/flic/node-red-contrib-hal2/tree/main/examples folder for more information.
Example logging
Groups
Control and observe several Things at once with Groups. A group's identity — name, HAType, value function and rate limit — lives in a registry on the Event handler (Groups tab), while membership is set per Item on each Thing (the Groups section of the Thing editor: pick an Item, pick a group). A group can then be used as a target in an Action node, broadcasting a command to every member paced by the rate limit. Each group in the registry has an info button that lists its current members.
A group's own value
A group whose members carry state has a value of its own, which Value, Gate, Event and Bayes nodes can read exactly like an Item's — and each of them chooses how. The same members answer different questions: any true asks "is a lamp on?", all true asks "did the command to turn them all on work?", count true asks "how many are on?". Two Event nodes can therefore watch the same group for two different things, which one shared value could never do.
What a group reports when nobody asks for anything in particular is derived from its HAType — a temperature group averages, a light or switch group answers any true. There is nothing to configure; a HAType with no natural summary (Other, the modes, colours) simply has no default, and the reading nodes each pick a function.
Function Result
latest the most recently updated member's value, whatever its type
min / max the lowest / highest value
average / median / sum the mean, the middle value, everything added up
range highest minus lowest — the spread across the group
any true / all true at least one / every member is true
any false / all false at least one member is false / none is true
count true / count false how many members are true / false — compare it in a Gate
percent true the share that are true, 0–100
Four rules decide what goes into the calculation:
  • Only members with a state. A command-only Item has nothing to contribute; a group with none at all cannot be read.
  • No offline members. A device that has dropped off the network is left out rather than voting with the value it had before it went quiet — so any true goes false when the last reachable lamp disappears, instead of reporting a light that may well be dark.
  • Only values of the right kind. The numeric functions skip anything that is not a number (a boolean member never counts as 1), and the boolean functions are strict about true / false — hal2 normalises ON/1 in the ThingType's ingress function, so by the time a state reaches a group it is a real boolean or it is not one at all.
  • Nothing eligible means no value. A group with no live member reporting reads as undefined, not 0 or false, so a silent group can never be mistaken for a real "off" in a Gate.
A group behaves like an Item in every other respect: it emits on each member update carrying state and laststate, so an Event node's only on change filter works the same as it does for a Thing, and msg.member says which member moved it. A group's value is derived, so it is never written to the history database and a Value node can only read it — use an Action node to command a group.
A group has a HAType that sets the command contract for its members, and a member has to be able to honour it: Switch and Light are interchangeable (both are boolean On/Off), but a Dimmer item does not join an On/Off group and a switch or light does not join a Dimmer group, since neither can honour the other's value. Where an Item carries a declared device class, that is what the group's contract is matched against rather than its ha_type — a switch driving a socket is not a light however identical the two look from the protocol side. The Thing editor only offers compatible groups for each Item, and the Event handler only offers HATypes its existing members can all honour. For genuinely mixed groups there is an Other type that accepts any Item.
A group with no stateful members stays exactly what it was: a command target, invisible to the reading nodes.
What a member can do
An Item reports a state, accepts commands, or both, and a group commonly exists for one of the two. Nothing used to say which an Item was at the point where its groups are chosen, so a Zigbee2MQTT Color Light's On — which reports and takes no commands — could join a group built to command and make up part of the member count and none of the reach. Nothing was wrong and nothing complained: the group really did have one more member than it could command, and control_group reported truthfully how many it reached.
Two things now say so. In the Thing editor, an Item that does not do both is marked · state only or · command only beside its name. Doing both is the ordinary case and stays silent, so the row that needs a second look is the one that has something written on it. The Event handler's group info button lists each member's capability in its own column, which is how to audit a group that is already built.
A group can also refuse a kind of member outright. Accepts on the group — [x] State [x] Command, both ticked by default — says which kinds may join, and unticking one stops the Thing editor offering that group to Items of the other kind. An Item that does both qualifies under either tick on its own, since it can serve as the group's reading or as its target. This is an admission rule for the editor and nothing more: what a group reads and what it commands stays derived from the members it actually has, the runtime never consults the flags, and a membership that no longer qualifies is kept and marked, not deleted — the group's summary counts them, and the Item's row says which contract it fails. Both flags ticked is exactly the old behaviour, so every group that predates the field is untouched.
Groups over MCP
Groups are exposed to assistants as their own pair of tools rather than as parameters on the device ones, because a group is not a device: it has no items, and reading it is not the inverse of writing it. get_groups returns every group with its value and how that value was computed; control_group sends one command to every member that can accept one, paced by the group's rate limit. get_all_states carries the same group list alongside devices, so orientation takes one call.
The asymmetry is the thing to hold on to, and the tools say it in as many words: reading a group uses its state-capable members, commanding it uses its command-capable ones, and either set can be empty. A sensor group reads and cannot be commanded; a scene group is the reverse. Commanding never writes the value — the value follows from what the members report back.
The function is not fixed. get_groups takes a function argument that computes a different one from the same members for that call only — the same freedom the flow nodes have. The group's derived default is what get_all_states reports and what a call without a function returns; the reply names configured_function whenever the two differ, so an ad-hoc reading is never mistaken for the group's own.
A function that does not apply is refused rather than answered: asking a temperature group whether all its members are true comes back as an error naming what the members hold and listing the functions that fit. It does not come back as false, which is a claim about the group rather than about the question. Partial coverage is a different matter and is answered: on a mixed group average uses the dimmers and ignores the on/off members, so the reply carries used beside live and a mean over 10 of 39 members can be read as what it is.
A group is readable as soon as it has members that carry state. Command groups usually are: switchable devices report back.
Every function is tracked, not just the default. The engine keeps a record per function the group's HAType can serve, so last_change and last_update are that function's own — a Gate can ask "has all true been steady for ten minutes?" and get a real answer. Deriving them from the members instead would be wrong for min, max and any true, where a member can change without moving the value at all: on a nine-sensor group the derived answer was 26 minutes off.
Where one member owns the value — latest, min, max — the reply names it as source, so "the coldest room is the laundry" is one read. A mean or a count belongs to nobody and carries no source rather than an arbitrary one. last_changed_by names the member that last moved the value, which is a different question and only the same one for latest.
Give a group Tags and Notes on the Groups tab and both reach the assistant. This is worth doing: the name is usually all it has to go on, and "All lights" does not say whether the outdoor lights are in it. A note does, and get_groups takes a tag filter so the assistant can ask for exactly the set it means.
Groups replaced the old standalone hal2Group node, which 4.0.0 removed. The editor converts any that are left when it loads the flows (or run node tools/migrate-groups.js <flows.json> on a flows file); the conversion keeps group ids, so existing Action/Event references keep resolving untouched.
AI & external control
Beyond local automation, hal2 can expose your devices to AI assistants and external systems. The Event handler can run a built-in MCP server, you can define your own AI tools as flows, and the hal2Api node offers a plain JSON gateway. All three share one tool catalog, so there is a single source of truth.
MCP server
Breaking change in 3.0.0 — the server reads the token, and nothing else. hal2 no longer takes part in OAuth at all: the dynamic client registration shim, the authorization-server metadata routes and the Client ID/Client secret fields are gone, along with the /userinfo call that used to fetch group membership on every request. What remains is verifying the access token and reading its claims.
Migration. Register each MCP client at your identity provider — or point it at a Client ID Metadata Document, if the provider resolves those — instead of letting it self-register here; a client that self-registered before the upgrade should be removed and re-added. Then make sure the claim the access gates match on (Access claim, groups before 4.0.0) is in the access token and not only in the ID token or userinfo. If your provider cannot put it there — PocketID currently cannot — leave Read tools and Write tools empty. Required scopes still limit which clients get in, but they cannot say which users: that is left to whatever user restriction the provider applies per client, which covers every API the client reaches rather than this server alone. There is no per-user gate for hal2 without the claim. A gate whose claim never appears refuses everyone, and says so in the log once per client.
The hal2EventHandler config node can run an embedded MCP (Model Context Protocol) server, letting an AI assistant such as Claude read device state and control your home in natural language. Enable it on the MCP tab of the Event handler. The server is OAuth 2.0 protected and works with any standard OIDC identity provider (its real endpoints are auto-discovered — see Authentication & reverse proxy), carries a per-location identifier (e.g. "Home" / "Cabin") so an assistant connected to several homes can tell them apart, and supports a debug token for setups where OAuth cannot be set up — it bypasses authentication on every MCP route, grants no claim values unless configured, and is named in the log at every start while set. Experimental.
It ships with a catalog of built-in tools:
  • Read — get_all_states, get_state, get_history, get_scenes, get_presence, get_alerts, get_groups, analyze_patterns
  • Write — set_light, control_device, control_fan, control_cover, control_spa, control_climate, activate_scene, control_group Those two classes are also the unit of access control: a token can be allowed to read the house without being allowed to change it.
Tools are exposed only when matching hardware is configured at that location — a server with no covers won't advertise control_cover. Things and Items can carry free-text notes and tags, and devices report derived categories (light, fan, cover, climate, spa, scene), all of which help the assistant pick the right device. Full parameters and examples are in docs/API.md.
Access control
Tools are gated on the claims in the caller's verified access token, so one MCP endpoint can serve several people at different privilege levels. A gate is a claim name plus a value list: the values are comma-separated and matched any-of — an array claim must contain at least one of them, a scalar claim must equal one. An empty list is no constraint, which is the default everywhere, so an existing setup keeps behaving exactly as before.
On the Event handler's MCP tab, one Access claim (default sub, the user's id) carries the lists, checked with AND:
Gate Covers Default
Read tools get_all_states, get_state, get_history, get_scenes, get_presence, get_alerts, get_groups, analyze_patterns empty — any authenticated caller
Write tools set_light, control_device, control_fan, control_cover, control_spa, control_climate, activate_scene, control_group empty — same as read
The read list is the floor: a caller who fails it reaches nothing at all. Writes are checked on top of it, so Read tools = family, Write tools = ops gives the whole household visibility while only ops can switch anything. A tool that is in neither set — a future addition, or the undocumented control_light alias of set_light — is treated as a write, so an unclassified tool fails closed rather than slipping through.
With the default claim sub a list names users by their id at the identity provider. Set the claim to groups (or any claim the token carries) to name groups instead.
The client axis: required scopes
The lists above answer what may this user do. Read scope and Write scope answer a different question — what is this client authorized to do on the user's behalf — and the two are checked with AND.
The distinction matters because they are not interchangeable. A group says who is at the keyboard; a scope says how much of that person's authority they delegated to the software holding the token. Collapse them into one field and only one gets consulted: a client granted a read-only scope, driven by someone who may write, would write. The client's grant has to bound the user's rights, not be ignored — that is what delegation means.
Required scopes are added to scopes_supported automatically, so there is nothing to repeat in the scopes field and no way to demand a scope that clients are never told to request; they are also named in the WWW-Authenticate challenge on a 401, which spec-following clients treat as authoritative.
The scope claim is read the way OAuth defines it (RFC 6749 §3.3): a space-delimited string, or an array if your provider sends one. The claim name is not configurable because it is standardised (RFC 9068); scp is read as a fallback for Microsoft Entra and Okta. The fields themselves are comma-separated any-of lists like the ones above. Empty means no constraint, so an install that never fills them in is unaffected; a configured scope the token does not carry is refused, including when the token has no scope claim at all.
Providers that model APIs as resources — Pocket ID, Auth0 — are where this earns its keep: the IdP grants a client access to the MCP server's resource with a specific set of scopes, and this is where the server enforces what it was handed.
Your own tool calls are held to the same gates. Each one is a read or a write tool (Kind, write by default), and clears the lists and scopes of its class. Its Tool access list narrows it further, checked on top of them.
Callers who fail a gate still connect — initialize succeeds — but the tools they cannot use are absent from tools/list, so an assistant is never offered a tool it will then be refused. A direct call to a hidden tool comes back as an MCP tool result with isError: true and a human-readable reason, so the model is told why rather than getting a generic "tool execution failed".
The gates apply to the MCP surface only, where claims are cryptographically verified. The hal2Api node reads msg.claims off the message, which any flow can set, so gating it would be decoration rather than a boundary.
Nested claims are addressed with a dotted path, for providers that don't put roles at the top level of the token: realm_access.roles reads Keycloak's realm roles, and any depth works. A key that exists literally always wins, so PocketID's flat groups is unaffected. Only strings and arrays of strings match — pointing the claim at a container object grants nothing rather than matching by accident.
Hostname filtering
Off by default. When Only serve requests for this hostname is enabled on the Event handler, its MCP routes only answer requests whose Host header matches the hostname in the MCP server URL. This lets several Event handlers share the same paths (e.g. /mcp) on one Node-RED instance, each answering only its own virtual host — useful when one backend fronts several homes on different hostnames. A filtered Event handler wins its hostname over an unfiltered MCP server on the same paths, whichever registered first — including an MCP Server of node-red-contrib-mcp-server, which shares the registry. Leave it off for a single server, or when a reverse proxy rewrites the Host header.
The MCP server advertises itself as a protected resource and points clients at your identity provider. It does not run its own login, and since 3.0.0 it no longer pretends to be an authorization server either.
Routes to expose through your reverse proxy. With the default (empty) HTTP path prefix, the Event handler registers these on the public MCP server URL — all must be reachable from the MCP client:
Method & path Purpose
POST /mcp The JSON-RPC MCP endpoint (bearer-token protected)
GET /.well-known/oauth-protected-resource Resource metadata (RFC 9728) — points the client at the auth server
GET /.well-known/oauth-protected-resource/mcp Same metadata, path-inserted form some clients probe
This server is a resource server, and nothing else. It runs no login, holds no client credentials and performs no OAuth flow. It publishes RFC 9728 protected-resource metadata naming your identity provider, and clients go there directly — with a Client ID Metadata Document or a pre-registered client ID. Dynamic client registration is deprecated by MCP 2026-07-28 and, as of 3.0.0, is no longer offered here.
A request is authenticated by the access token alone. The signature is checked against the provider's JWKS, the issuer is pinned to the discovered provider, expiry is enforced, and the audience must name this server — the MCP endpoint's URL, which is what MCP requires clients to ask for (RFC 8707) and what a provider puts in aud for an API.
There is no second call. Nothing is fetched from /userinfo: that endpoint serves a client asking about its own user (OIDC Core §5.3), not a resource server asking about a token, and a provider may refuse it once the token is bound to this server. Everything the access gates read must therefore be in the token — see RFC 9068 §2.2.3.1, which is where an authorization server is told to put groups, roles and entitlements. A provider that keeps them in the ID token or userinfo alone will leave the claim gate with nothing to match, and the log will say so, once per client.
Setting an HTTP path prefix shifts every route under it (/prefix/mcp, /prefix/.well-known/…), so update the proxy to match.
Allowlist these paths — don't blanket-proxy everything to Node-RED. hal2's MCP routes live on Node-RED's shared HTTP server, alongside the flow editor, admin API and any other http in endpoints. A catch-all proxy would put all of those on the public hostname; hal2 forwards anything it doesn't own to Node-RED, so you can't know what else would be exposed. Route only the specific paths below.
Example with Caddy via caddy-docker-proxy labels (default prefix):
labels:
  caddy_1: mcp.example.com
  caddy_1.reverse_proxy_0: /mcp "{{upstreams 1880}}"
  caddy_1.reverse_proxy_1: /.well-known/oauth-protected-resource "{{upstreams 1880}}"
  caddy_1.reverse_proxy_2: /.well-known/oauth-protected-resource/mcp "{{upstreams 1880}}"
To serve several MCP servers on different hostnames from one backend, give each its own caddy_N site block and enable hostname filtering.
What hal2 expects of the identity provider:
  • An OIDC provider with discovery — hal2 reads ‹issuer›/.well-known/openid-configuration, and needs exactly two things from it: jwks_uri, to verify signatures, and issuer, to pin them. (It also notes client_id_metadata_document_supported, so the log can name which clients arrive by metadata document.) The authorization and token endpoints are the client's business, not hal2's. If discovery is unavailable it falls back to PocketID's path layout, so no extra config is needed for either.
  • It must issue JWT access tokens signed with a key published on its JWKS (hal2 verifies tokens locally). Providers that issue opaque access tokens are not supported (no introspection path yet).
  • A public client with PKCE (S256), grant types authorization_code + refresh_token, and the MCP client's redirect URI(s) whitelisted (for Claude.ai: https://claude.ai/api/mcp/auth_callback) — or CIMD support, which supplies all of that from the client's own metadata document. Clients, redirect URIs and secrets are entirely the provider's business; hal2 has no fields for any of them and never sees a redirect.
  • The access claim in the access token, if you use the claim gate — the token is all hal2 reads. See RFC 9068 §2.2.3.1. Not every provider can: PocketID currently cannot (#1389), and without the claim there is no per-user gate — required scopes restrict clients, not users.
Tested with the combination Caddy (reverse proxy) + PocketID (identity provider) + Claude.ai and Hermes (MCP clients). Any spec-compliant OIDC provider issuing JWT access tokens, behind any reverse proxy that forwards the paths above, should work the same way. The claim gates are the exception with PocketID, which does not yet put the claim in the access token.
Rooms
Which room a device is in was carried by a naming convention — "Vardagsrum Taklampa" — that nothing enforced and nothing could read. Rooms are a registry on the Event handler (its own tab); a Thing picks one, and get_all_states then reports room as a field and accepts it as an exact filter. Having no room is a complete answer, not a gap: a scene is nowhere, and so is a person.
The room is a separate parameter everywhere it is addressed, and composed only where it is displayed. set_light(name: "Taklampa", room: "Kontor") — not a composed string that has to be parsed back, which would only be the naming convention again, generated instead of typed. In the editor, where a human has to pick one Thing out of a flat list, the canvas label and every Thing dropdown read [Kontor] Taklampa; the brackets say the string was assembled from two fields rather than typed by someone.
A name that matches several things is refused, not fanned out. set_light(name: "Taklampa") used to command every ceiling lamp in the house — five devices from one substring match. It now answers ambiguous_name listing the candidates with their rooms, so adding room picks one. That refusal is what makes a short name safe, and it applies to get_state, get_history and every control_* tool. A name spanning both — "Tvättstuga Golvspot", or the bracketed form the editor shows — resolves on its own, so nobody has to take the displayed name apart before using it. That is a fallback tried only after the bare name finds nothing, so it can never turn a refusal into a guess.
A Thing's name has to be unique within its room, not across the house — two ceiling lamps may both be Golvspot as long as they are in different rooms, which is the rename rooms exist to make possible. Two Things with no room still collide: there the name is all there is.
The room reaches flows too, not only the tools. The thing block a Thing puts on the bus — what a Value or Event node passes on, and what a group's emission names as the member that moved it — carries room alongside name and id. It is the room's name, not the registry id it is stored as, and the key is absent when the Thing has no room. Without it a flow downstream sees two things called Golvspot and has nothing to tell them apart, which is the problem rooms exist to solve.
get_presence reports current_room — where a person is now, which is not the same thing as the room a device was installed in, and no longer shares a key with it.
Device class — what an item drives
ha_type says how to speak to an item: switch, dimmer, cover. An assistant reads it as what the item is, and for most devices the two coincide — a bulb is a light. They come apart at a relay. A Matter Metered Plug driving the coffee machine and one driving the ceiling lamp are the same Thing type with the same switch item, so the type cannot answer the question; only the Thing can.
Device class is where the Thing answers it, per item, under Items in the Thing config — which lists every item of the type, always, with its group memberships collapsed beneath it. Nothing has to be added before the list tells you something: the question it answers is "what does this item present as", and a list you must add a row to first cannot answer it. One control per item, so an item cannot be declared twice.
The control appears only on a switch item, because that is the only ha_type that leaves the question open — a light, dimmer, cover or fan item already says what it is.
class what it buys
light set_light switches it, and it answers a query for lights
fan control_fan drives it — a switch is a fan with two settings instead of four, so speed 0 is off and anything above it is on
outlet a socket whose load changes: a tree in December, a fan in July. Its own class because "turn off all the outlets" needs the set to be findable
appliance a fixed device that is none of the above — the coffee machine says so rather than staying silent
A class is worth offering only where something can act on it once declared, which is why climate, spa, cover and scene are absent: their tools dispatch on setpoint, mode, position and scene item types, none of which a relay has, so declaring one would advertise a capability nothing could honour. A radiator on a switch is an appliance, and control_device commands it.
outlet and appliance are categories with no ha_type of their own — nothing about a relay says which it is — so a declared one appears in categories and answers get_all_states(ha_type: …) like any other. Tool exposure follows what a tool can actually write, not the mere presence of a class, so a declaration never advertises a tool that would then do nothing. The vocabulary is the device categories (light, fan, cover, climate, spa, scene) plus appliance for "explicitly none of these" — a plug on the coffee machine says so, rather than staying silent, and the difference between unclassified and classified as not a light is one an assistant can act on.
Nothing needs declaring where the ha_type already settles it. Each row states, read-only beside the control, what the item counts as when the device is categorised — counts as light for a light or a dimmer — so the Thing type never has to be opened to find out, and a row that states nothing is exactly the gap a declaration fills. It says counts as rather than drives, because that is all the rule claims: a dimmer is not itself a lamp, it is part of what makes the device one. There is deliberately no Thing-type default either; a default there would be a hidden layer you cannot judge from the Thing.
The class is added to the ha_type, never replacing it: ha_type still drives value semantics, so a dimmer keeps its brightness. What changes is discovery — get_all_states reports the derived categories, the ha_type: "light" filter matches a declared light behind a switch, and set_light is offered at a location whose only lamps sit behind relays.
A declared class also decides which groups an item may join: a switch driving a socket looks identical to one driving a lamp from the protocol side, so before this it sat in "all lights" and was cut whenever the lights went out. Once declared, the class is what a group's contract is matched against, and an existing membership it contradicts is marked in the row rather than removed. The group engine itself still commands whatever is stored — a group is a curated list, and the editor is where the contradiction is caught.
A group's type is its command contract, and device_class is what let it become one. A light group takes a boolean and holds On/Off items; a dimmer group takes 0–100 and holds brightness items. A dimmable lamp belongs to both — through its On item and its brightness item respectively. Two older allowances are gone with this: an untyped item is no longer a wildcard that could join any typed group, and a dimmer can no longer join an On/Off group. Both existed only because there was no way to say what an item was for. An existing membership that no longer fits is kept and marked in the row rather than dropped, so tightening the rule cannot delete data quietly.
set_light only switches what is a light. An ha_type of light says so on its own; a switch needs device_class: light, because a switch says only that something can be turned on and off and the load could be a coffee machine. An undeclared switch is therefore not written — before device_class every switch was treated as a light, since there was no way to tell them apart. And a Thing that matched but took no command now answers nothing_to_command, listing what its items are, rather than reporting success and changing nothing.
Custom MCP tools (tool call / tool result)
You can add tools of your own to the location's catalogue as Node-RED flows: a tool call node (hal2MCPIn) registers a tool on an Event handler and fires a message when the assistant calls it, and a tool result node (hal2MCPOut) returns the answer. Responses can be text or image/media content, so a tool can return e.g. a camera snapshot. The tool is served on the Event handler's /mcp next to the built-in ones, and its Tool name must not be one of theirs.
  • Kind — a read or a write tool, held to the gate of that class. Write is the default, so a tool nobody classified gets the stricter gate.
  • Validate — on by default: arguments are checked against Parameters before the flow runs (types, required, enum, bounds, lengths, pattern, items, additionalProperties: false), and a call that does not match is answered with the reason instead of reaching the flow. Keywords outside that set are named in the log once.
See examples/mcp-tool.json for one tool of each kind. For tools on an MCP server of their own — a resource with its own URL, audience and gates — use node-red-contrib-mcp-server instead.
JSON API (hal2Api)
The hal2Api node turns the same tool catalog into a simple JSON request/response gateway, so external components can query device state and control devices without speaking MCP. Wire it behind an http in, MQTT, or any node that produces a JSON message:
// in:  msg.payload
{ "tool": "get_state", "args": { "name": "kitchen" } }
// out: msg.payload
{ "ok": true, "result": { "id": "…", "items": [ … ] } }
It serves the Event handler's catalogue — the built-in tools plus any tool calls registered on it. (For an MCP server of node-red-contrib-mcp-server, use its MCP Call node.)
Send { "list": true } instead of a tool name to get that catalogue — { name, description, inputSchema } per tool, the shape tools/list returns. For the built-in tools docs/API.md (auto-generated, npm run docs:api) is the fuller reference; for your own hal2MCPIn tools the listing is usually the only index there is.
Access control does not apply on this path. The claim and scope gates run on the MCP server's HTTP route, where the token behind them was verified. A flow node is already inside the trust boundary — whoever can edit flows can edit the tool — so a tool restricted to certain callers over MCP is still callable here, and the listing shows it. Don't use hal2Api to re-expose a gated tool to an outside caller; that gate is yours to reproduce. Arguments are not checked against the schema here either: a flow is trusted to send what it means.
See examples/json-api.json for a ready-made HTTP endpoint flow.
History & pattern analysis
Items can opt in to history logging: when enabled on the Event handler (and per Item), value changes are stored in a local SQLite database with a configurable retention period. History requires the optional better-sqlite3 package — install it with npm install better-sqlite3 in your Node-RED user directory. Without it, history simply stays off and nothing breaks.
History powers two tools:
  • get_history — fetch logged values for an Item over a flexible time window: a rolling hours count, an explicit from/to range, or a point-in-time at lookup ("what was it at 08:00?"), with offset/limit paging.
  • analyze_patterns — scans the history to surface recurring routines, e.g. "Living Room Light turns on around 07:30, 85% consistent", so you can spot automations worth creating.
Bayes node
hal2Bayes estimates something you cannot measure directly — typically "is this person home?" — by weighing up several unreliable sensors instead of trusting any single one. A phone presence sensor that already reports "home" from the street corner is not enough on its own; combined with the front door opening and closing and movement in the hallway, it becomes convincing. The node is an anonymous estimator: it knows nothing about people, it just fuses evidence. Use one node per hypothesis (one per person) and wire its output onward like any other message — e.g. into a Scene-type sensor representing the person. See examples/bayes-presence.json for exactly that case, with inject nodes standing in for the sensors.
Comparing against another source
in range / outside range match while a reading sits between two bounds, or while it does not. Available in hal2Event, hal2Gate and hal2Bayes. Inclusive at both ends, so a reading exactly on a bound is in the range, and the order is not significant — 20 to 24 and 24 to 20 name the same band. Both bounds are typed beside the operator, which is also why they are two operators rather than one with an inside/outside switch: the pair already occupies the space a switch would have wanted, and the operator itself says what is being asked of it.
A bound left empty makes both operators match nothing. That takes a little care, because Number('') is 0 rather than NaN — read naively, an empty upper bound would turn "in range 20 to __" into the band 0–20 and match things nobody asked for. rangeBounds() in lib/rules.js is the one place that reads a pair of bounds, and it treats blank as NaN so a half-filled rule stays quiet.
Paired with hal2Event's trigger true/false output, in range expresses a comfort band directly: true on the way in, false on the way out, whichever side you leave by.
Every comparison in hal2Gate, hal2Event and hal2Bayes normally weighs a source against a constant — a number, a string, or a variable. Pick the state value type instead and the right-hand side is another live reading: another Thing's Item, or a Group with a function of its own.
This is worth more than the convenience. The alternative was storing one side in a flow variable and comparing against that, which samples the two sides at different moments: something changes, the variable has not caught up, and the comparison is silently wrong until it corrects itself. With state both sides are read in the same pass, so the window does not exist. "Is everyone who is home asleep?" becomes one rule — people home count true == phones charging count true — with nothing stored in between.
The right-hand side is described the same way everywhere: a source, and an item or group function. It is offered wherever comparing two values makes sense, so not for is true/is false, regex, or the Gate's last_* operators, which compare against a duration. A source that cannot be read — a deleted Thing, a group with no live member — makes the rule not match rather than comparing against nothing.
Rules
Each rule collapses to a single line stating what it says and what it does about it — the same phrasing bayes-label.js gives the snapshot on output 2, so a rule reads the same on screen as it does in the debug panel — and opens when clicked. A dozen controls per rule is unreadable as a list; one sentence per rule is not.
Everything is a rule, built from steps. Each step names a source and a condition, then says when that condition has to hold. A source is normally a thing item, but it can also be a flow, global or env variable — for facts that live elsewhere in the flow, such as "the calendar says we are away" or "guest mode is on" — or a time window.
  • now — a condition, true at that instant (and…)
  • now or soon — the same, but it waits for the condition until the window runs out; for sensors that report late (and…)
  • for a while — a condition that must have been continuously true for its own duration before it counts. This is what separates a trip to the bathroom from getting up for the day: the reading is identical at the moment it happens, and only time tells them apart. The clock restarts whenever the condition drops, so a string of short absences never adds up to a long one, and it survives a restart because the edge is persisted with the rest of the state. It has a window as well, and the window bounds when the hold is reached — so the condition has to go true a whole hold-length before the window runs out, and the step's read-back line does that subtraction (and…)
  • on change — an event: the condition must actually turn true, being already true does not count (then…)
  • on a full cycle — a cycle: true and back to false within its limit, e.g. a door opening and closing (then…)
A rule whose steps are all conditions is not a sequence but an AND: its weight applies for as long as every one of them holds at the same time. "While it is 09:00–10:00 and the terrace is above 100 lux" is one weight with two conditions. A rule that opens with a condition but waits for an event later cannot work — nothing completes that first step — and the editor says so on the rule; in the snapshot it reads as never-fires.
Timing sits on a second line under a step, only where it applies: within N s of the previous step is how long that step has to happen, and stays on for at most N s is how long a cycle may stay true — a door held open longer than that is not a pass-through, so the rule does not advance. In an AND there is no previous step to be soon after, so no window is shown.
A time source is a window of the day rather than a sensor: start and end in 24-hour format plus the weekdays it applies on. It may cross midnight (22:00–06:00), start is inclusive and end exclusive, and a window whose start equals its end is never active. The weekday is the day it is right now — with 22:00–06:00 on Mon–Fri, Tuesday 02:00 counts but Saturday 02:00 does not, even though that is Friday night. The value is simply "inside the window or not", so the condition reads inside / outside and one window covers both "during the night" and "outside working hours". Times follow the server's local clock, DST included.
flow, global, env and time can only be conditions — now or now or soon. Only a thing is subscribed to, so these are read when the node evaluates rather than pushed when they change; an edge qualifier on one could only be sampled on the tick and would miss anything faster. The same polling means such a rule — including a time boundary — takes effect within one tick (30 s by default), not on the second. And flow/global survive a restart only when the context store is file-backed; the default is memory.
A rule that is a single now step is continuous (While…): it pushes the estimate while its condition holds and stops the moment it does not. Any other rule is momentary (When… then…): the steps must happen in order, each event within its time window, and completing the last step gives a one-off push that then fades. An event that happened while the previous step was still in progress also counts, so motion while the door stood open is accepted when it closes.
Put the event first and the conditions after. Trigger on what actually happens at a point in time — usually the door — and use a condition step to ask what was true at that moment:
When the front door is true, on a full cycle — and iPhone Fredrik is true, now → makes it true, decisive
Written this way the rule does not care whether the phone appeared thirty seconds or thirty minutes earlier, and it never fires for somebody else's arrival, because their phone is not here — the identity check falls out of the condition, with no special logic. If that sensor is slow to report, now or soon makes the step wait rather than fail. Only a step that needs the change itself — leaving — uses on change:
When the front door on a full cycle, then iPhone Fredrik is false, on change, within 5 min → makes it false, certain
Strengths and the share scale
Each rule pushes toward true or false with a word strength — slight (LR 1.5), moderate (3), strong (10), decisive (30), certain (400). The editor shows every rule as a share of the way from the prior to the threshold the node can actually cross, and shares add exactly: 74 % + 35 % = 109 % turns the output on. This is also how shared sensors are disambiguated without any special logic: give the door/motion arrival rule a share too small to cross the line alone, so it only matters together with the node's own strong indicator — someone else arriving contributes 35 % to this node and nothing happens.
A prior above the on-threshold is a supported configuration, and a useful one. The node then rests on and rules push it off, which is how you say "assume the house is quiet until something says otherwise" — no rule has to argue the resting case, and silence is the answer rather than something to be reconstructed. Shares are then measured toward the off-threshold, since that is the only line the estimate can cross, and the editor's summary says so. The constraint to keep in mind is that the prior must be reachable in one hop by your strongest veto: at prior 0.93 with an off-threshold of 0.35, one decisive rule is 106 % of the way and just enough, while 0.95 would need certain.
A certain rule overrides history: firing it clears opposing evidence, and a stored certain statement is cleared by any later contradicting rule.
Weights that follow the reading
The strength scaled… makes a rule's weight depend on the measured value rather than being constant. Give two points — value 20 or less → weight 150 %, value 60 or more → weight 0 % — and the weight is interpolated between them, clamped outside. A rule's weight is its share of the way to on, the same percentage the bars show: 100 % is exactly enough to flip the output when nothing opposes it. Soil moisture is the natural case: watering in direct sun is normally a bad idea, but critically dry soil should override it, which only works if the dryness rule grows heavier as the reading falls. This is the step from naive Bayes with binary features to logistic regression over a continuous one.
Shares may exceed 100 % and may be negative; the sign lives in the shares, so the makes it dropdown is hidden for a scaled rule and one rule can push both ways across its range. Mind the arithmetic: 100 % reaches the threshold exactly from the prior, so any opposing evidence blocks it — overriding a moderate 35 % objection needs roughly 150 %. Single-step rules only, since with several steps there is no non-arbitrary answer to which value scales the weight.
Two caveats when using the node this way. Irrigation is a decision, not a hidden state — there is no fact about whether watering "is needed" independent of preference; the machinery still fits, but p becomes a score rather than a probability. And several moisture sensors in one bed are not independent evidence — naive Bayes over-counts them and pins the estimate at the clamp, so aggregate them (min or mean) into a global and use one rule.
Fading and the latch
Momentary pushes fade — quick (5 min half-life), normal (20 min), slow (1 h), never (the push stands until something contradicts it) or custom… for an explicit half-life; continuous rules simply stop when their condition does. Strength buys very little time here: each doubling of ln(LR) adds only one half-life, so if you want a push to last, change the fade rather than the strength.
Refiring decides what happens when the same momentary rule completes again while its previous push is still alive. refreshes (the default) restates the rule: one push, its clock reset, at whatever weight the rule is worth now. stacks adds a second push to the first.
Stacking is the correct Bayesian reading only when the two firings are genuinely independent observations — two separate arrivals, say. It is the wrong reading when one continuing fact is simply being reported repeatedly, which is the usual case for a sensor that re-triggers while something keeps happening. A motion rule left to stack ran a live node to the clamp on seventeen firings in twenty-three minutes, each one describing the same person still moving about. Claim independence deliberately; do not let it be the default. Continuous rules have no setting here — they hold one weight for as long as their conditions hold and never accumulate.
By default the output falls back to off as evidence disappears. The lock changes that: only rules that make it false can turn it off — silence, decay or a sensor dropping out will not (status shows held). Use it when the state cannot end unnoticed: nobody leaves the house without the door opening, so a phone rebooting indoors must not flip the estimate. An optional hour limit turns it off anyway after that long without supporting evidence. With the lock on, fading no longer makes the output fall back by itself — but it still decides whether a push is strong enough to turn the output on, and how long a "makes it false" rule stays able to turn it off: a false rule that fires while the estimate is still high can fade away before the estimate drops, and is then wasted.
Advanced mode exposes the raw numbers (LR, half-life seconds, prior, thresholds, clamp) on the same rules — there is one data model, the modes only differ in what is shown. The estimate is persisted in node context and keeps fading by wall clock across restarts.
Set Topic to put a msg.topic on both outputs — output 1 gets it as written, output 2 gets it with /snapshot appended. Leave it blank and no topic is set at all, as in the Event node.
Output 1 carries the binary result (payload, probability, changed). By default it only emits when the result actually flips — a rule firing again while the node is already on sends nothing — but Emit output 1 can be set to every evaluation when a downstream flow wants the state re-asserted continuously. msg.topic reset / evidence ({ lr, halfLife? }) are available as escape hatches.
Explaining the estimate
Output 2 emits a snapshot built for tuning: it says not just what the estimate is but which rules produced it.
Both outputs answer to the same Emit setting. On only on a change — the default — each stays quiet until it has something new to say: output 1 when the true/false result flips, output 2 when the snapshot differs from the one it last sent. A sensor re-reporting the value it already had leaves the snapshot identical and sends nothing, which is where most of the traffic used to go. Evidence that is decaying does change the snapshot and does keep emitting on every tick, because the estimate really is moving. Sending the node any message it does not otherwise understand always answers with a snapshot, changed or not.
{ "p": 0.86, "logOdds": 1.86, "share": 108.4, "binary": true, "held": false,
  "rules": [
    { "id": "r1", "label": "While Hallway Sensor · Motion is true",
      "status": "contributing", "share": 73.8, "logOdds": 2.303, "value": true },
    { "id": "r2", "label": "When Front Door · Contact is true on a full cycle and Hallway Sensor · Motion is true",
      "status": "waiting", "share": 0, "logOdds": 0, "step": 2, "steps": 2, "deadline": 47 },
    { "id": "r3", "label": "While Office Sensor · Temperature > 25 and Office Window · Contact is false",
      "status": "condition-false", "share": 0, "logOdds": 0, "value": 26.1,
      "failedStep": 2, "failedValue": true }
Every configured rule is listed, every time — the question while tuning is usually why a rule is not firing, and a list of the ones that are cannot answer it. status says which case a rule is in:
status Meaning
contributing a level rule whose condition holds; its weight is in the estimate now
fading a rule that fired earlier — age and halfLife (seconds) say how far it has decayed
waiting a sequence partway through: step of steps, with deadline seconds left
armed a sequence at its first step, waiting to be triggered
condition-false evaluated and did not match — failedStep is which condition broke it and failedValue what that step read
no-value the failing step had nothing to read, or the reading is unusable for a scaled weight
injected ad-hoc evidence from msg.topic = "evidence", which has no rule behind it
never-fires the rule opens with a condition but waits for an event later, so nothing can start it
value is always the first step's reading, because that is also what a scaled weight follows. On a rule with several conditions the step that failed is a different one, so failedStep names it and failedValue carries its reading — and no-value rather than condition-false when that step had nothing to read at all.
share is the contribution as a percentage of the way from the prior to the on-threshold — the same unit the rule bars and the summary use in the editor, so what you tuned is what you read back. Shares add, so the contributing ones sum to the top-level share, and anything at or above 100 % reaches the threshold on its own. label is derived from the rule's steps, phrased as the editor phrases them; logOdds is the same contribution in the estimator's own units.
The node's status line carries the same share: on 108% (0.86) — the share first, the probability after it. Against a threshold you chose, the probability alone does not say whether a node is nearly there or nowhere near; the share does, in the unit the rules were tuned in.
Other recent additions
  • hal2Bayes — probabilistic binary-state estimation (see Bayes node).
  • hal2Emit — state changes to an external subscriber. Sends a fixed envelope per matching Thing, Item or Group update, with msg.topic from a template such as hal2/<site>/event/<room>/<thing>/<item>, for an mqtt out or websocket out after it. Filter rows select by Thing, ThingType, HA type or Group, on update or on change. See examples/emit-mqtt.json.
  • hal2Event — a level output (trigger true/false). The Event node has always reported the rising edge: it fires when the trigger rule starts holding and says nothing when it stops, so a flow that wanted to know whether a condition currently holds needed a second node with the rule inverted — a second place to keep in agreement with the first.
    The new output type reports the rule as a level instead: true when it starts holding, false when it stops, and nothing in between however many updates arrive. A threshold whose reading wanders without crossing it stays silent, where an every-evaluation output would narrate each reading.
    Two settings behave differently in this mode, and the editor hides or replaces them rather than leaving them to surprise you. Rate limit does not apply: it drops messages inside its window, and a dropped false leaves the receiver believing true for as long as nothing else moves — not a degraded signal but a wrong one.
    Delay applies per edge, with Delay on true and Delay on false, both on by default so that a ticked Delay event always does something. Turn off the second for an on-delay: the rule must hold before true is sent, while false goes out at once. Turn off the first instead for the opposite — quick to react, slow to let go, which is what a signal that flickers off usually wants. A queued edge is dropped whenever the answer moves away from it again, so the node never announces a state that has already stopped being true; Reset delay is implied and hidden.
    With the always operator there is no level — the rule cannot stop holding — so the node keeps its ordinary firing discipline and simply carries true, exactly as the boolean output type does. It never sends false, and the editor says so where you choose it.
  • Groups redesigned — group identity now lives on the Event handler and membership per Item on each Thing, with HAType-aware compatibility (see Groups). Replaces the old hal2Group node, removed in 4.0.0.
  • Multi-filter on Things and Items — combine several match conditions on any message field (exact string, regex, MQTT wildcard, starts/ends/contains) with AND/OR logic, replacing the old single-topic filter.
  • Centralised ingress/egress functions — define message-transform functions once on the Event handler and reuse them across thing types instead of copying them per type.
  • Notes & tags on Things and Items, plus automatically derived device categories — handy for organising devices and for disambiguation by the MCP and JSON API tools.
  • Metadata — a per-Thing, machine-managed key/value bag for facts an integration discovers about a device (see below).
  • Metadata mappings — declare on the Thing type which topics carry device facts, for sources that can't publish to _meta themselves (see Metadata mappings).
  • Function store — persistent scratch space for a Thing's ingress/egress functions, so logic that needed a function node and context.get/set can live in the Thing type (see The function store).
Metadata
Every Thing carries a metadata bag: a set of read-only key/value facts about the device — for example a model name, serial number or IP address. Unlike notes and tags (which you write by hand), metadata is machine-managed: an integration fills it in, and hal2 stores whatever arrives without interpreting it. This keeps hal2 technology-neutral — it knows nothing about Matter, Thread, Zigbee or IP; it just holds the facts a source provides.
Metadata is updated over a reserved topic on the Thing's own prefix, so any upstream node can set it:
  • ‹prefix›/_meta/‹key› with a value → set/update that key.
  • ‹prefix›/_meta/‹key› with an empty/null payload → remove that key (and any nested branch under it).
  • ‹prefix›/_meta with an object (or a JSON string, which hal2 parses) → merge: each key is set, and a key whose value is empty/null is removed. One message can update several keys at once.
  • ‹prefix›/_meta with an empty/null payload → clear all metadata.
Nested objects are flattened into dot-keys — { network: { wifi: { rssi: -60 } } } is stored as network.wifi.rssi = -60 (arrays and primitives are kept whole as leaf values). Because every leaf is its own key, partial updates merge precisely (resending network.wifi.ssid leaves network.wifi.rssi untouched), a nested null removes just that leaf, and an empty value on a parent removes its whole branch.
Values are persisted in the Thing's context exactly like state, so they survive a restart. The current metadata is shown in the Thing's edit dialog (values are read-only, but you can delete a single key or Clear all — note an active source may re-publish a deleted key), and is exposed to the MCP / JSON API as a `metad
Version: 4.1.0
Updated 5 days ago
Rating: 4.6 9
13 in the last week
  • hal2ThingType
  • hal2EventHandler
  • hal2Thing
  • hal2Value
  • hal2Event
  • hal2Gate
  • hal2Action
  • hal2Log
  • hal2MCPIn
  • hal2MCPOut
  • hal2Api
  • hal2Bayes
  • hal2Emit
  • home-automation
  • iot
