node-red-contrib-ha-avg-by-group 2.0.0
Node-RED node for averaging Home Assistant temperature sensors by group. Real HA server selector, robust HA state discovery, and searchable entity autocomplete.
npm install node-red-contrib-ha-avg-by-group
A Node-RED node that computes group-based temperature averages from Home Assistant sensors.
It skips rows when the associated contact sensor is on or when the row is unchecked.
Outputs are dynamic: the node creates one output per used group, and each output emits only msg.payload (the numeric average).
If a group has no valid rows, no message is sent on that port; if no groups have results, no messages are sent at all.
  • Dynamic outputs: one output per used group (1–20). Port labels show Group N.
  • Home Assistant server selector: pick the HA config node from a dropdown.
  • Entity autocomplete (editor): search sensor.* and binary_sensor.* with friendly names.
  • Row-level rules:
    • Unchecked row → ignored.
    • Contact sensor state on → row ignored.
    • Missing fields in a checked row → ignored (and highlighted red in editor).
  • Robust HA state discovery in runtime:
    • Optional override path (e.g. homeassistant.homeAssistant.states).
    • Uses the selected server name (camelCased) inside global.homeassistant.
    • Falls back to the first namespace with .states (prefers homeAssistant).
  • Decimal comma support for sensor values (e.g. "22,4").
Requirements
  • Node-RED
  • node-red-contrib-home-assistant-websocket
  • In the HA server config node, enable Expose to global context
    (the node reads HA states from global.homeassistant.*.states).
  1. Create a folder:
    ~/.node-red/node_modules/node-red-contrib-ha-avg-by-group/
  2. Place these files inside:
    • package.json
    • nodes/ha-avg-by-group.html
    • nodes/ha-avg-by-group.js
  3. Restart Node-RED.
  4. Find the node under Function → HA avg temps.
Select the HA server (config node). Autocomplete and runtime state discovery use this selection.
HA state path (override) (optional)
Explicit path inside global.homeassistant. Examples:
  • homeassistant.homeAssistant.states
  • homeassistant.myHomeInstance.states
Leave empty to auto-detect.
Rows (editable list)
Each row has:
  1. Use (checkbox) — whether the row is considered.
  2. Temperature sensor — a sensor.* entity.
  3. Contact sensor — a binary_sensor.* entity.
  4. Group — number 1–20.
The editor shows red borders for missing fields in checked rows.
Use the + button to add rows; rows are sortable and removable.
How outputs work
  • The node gathers the distinct groups used in your rows and stores that order.
  • On Deploy, it sets the number of outputs to match the used groups.
  • At runtime, it builds an output array where:
    • Index i corresponds to group groupOrder[i] (shown as port label Group N).
    • If a group has a valid average, that port sends { payload: <average> }.
    • If a group has no valid rows, that port sends nothing.
  • If no groups have results, no message is sent at all.
Rounding: averages are rounded to 2 decimal places.
Autocomplete (editor)
  • Start typing sensor. or binary_sensor. (or part of the friendly name).
  • The editor calls GET /ha-avg-by-group/entities?serverId=<config-id> and lists entities as
    entity_id — Friendly Name.
  • Note: you must have deployed at least one instance of this node in the flow once, so the endpoint can access global context.
Examples
Example A – Single group, both rows valid
  • Row 1: sensor.temp1 = 20, binary_sensor.door1 = off, Group 1
  • Row 2: sensor.temp2 = 22, binary_sensor.door2 = off, Group 1
Output (port “Group 1”):
{ "payload": 21 }
Example B – Single group, one row ignored
  • Row 2: sensor.temp2 = 22, binary_sensor.door2 = on, Group 1
{ "payload": 20 }
Example C – Single group, all rows ignored
(e.g., both contacts on, or both rows unchecked)
Output: no message.
Example D – Two groups
  • Group 1 rows average to 22
  • Group 2 rows average to 21
Outputs:
  • Port “Group 1” → { "payload": 22 }
  • Port “Group 2” → { "payload": 21 }
Troubleshooting
“No HA states” status on the node
  • Ensure Expose to global context is enabled on your HA server config.
  • Make sure you selected the correct Home Assistant server in the node.
  • If your global path is custom, set HA state path (override).
    Example: homeassistant.myHomeInstance.states
  • The node’s status will print the keys it can see under global.homeassistant (e.g., homeAssistant, myHomeInstance) to help you pick the right path.
Autocomplete shows no entities
  • Deploy at least once (so the admin endpoint can read the global context).
  • Verify the correct server is selected.
  • Verify HA states exist under global.homeassistant.*.states.
Outputs don’t match my groups
  • The number and order of outputs are determined at save/deploy time from the used groups.
  • If you change groups in rows, open the node and Deploy to update outputs.
Notes & Behavior
  • A row with missing fields (when checked) is ignored.
  • A row is ignored if its contact sensor state is on.
  • Averages use the sensor state value directly; "22,4" is supported (decimal comma).
  • The node emits only msg.payload; no other msg.* properties are set.
MIT
Acknowledgements
Built to work alongside node-red-contrib-home-assistant-websocket. Thanks to the community for the HA global context pattern (global.homeassistant.*.states).
Version: 2.0.0
Updated 1 year, 2 months ago
121 in the last week
  • ha-avg-by-group
  • home-assistant
  • temperature
  • average
  • groups
  • autocomplete
