node-red-contrib-growatt-2 1.1.3
Access to the Growatt API. Using the PCLHome/growatt library.
npm install node-red-contrib-growatt-2
With this node you can download data from the Growatt© Shine Webserver. It is only a wrapper around the existing library of PLCHome. Thanks for that!
Installation of Node-RED nodes
You can install the growatt node through the Node-RED library. Search for 'node-red-contrib-growatt-2'.
After creating a 'Growatt' node, create at least one config node for the credentials you use to login with your ShinePhone app or on https://server.growatt.com. The config node can bed reused on several 'Growatt' nodes.
As soon as a message arrives at the input of the node, the Growatt API call will be performed. The API result will be sent as a new message via the output.
Known issues
This node does not support the parameters historyLastStartDate, historyLastEndDate and historyStart at the moment, which are available in the underlying library.
Contact / Issues
If you have issues with the Node-RED implementation: https://github.com/RichardPointon/node-red-contrib-growatt
If you have issues with the underlaying growatt API library: https://github.com/PLCHome/growatt
Upgrading
If you are upgrading from version 1.1.2 then you will need to remove the old version node-red-contrib-growatt
npm remove node-red-contrib-growatt
and restart Node Red.
Version History
Version 1.1.3:
  • Forked and update dependency to 0.7.7. Refactoring for better error handling
Version 1.1.2:
  • Update growatt dependency to 0.7.4 (fixes login error)
Version 1.1.0:
  • Update growatt dependency to 0.4.1
Version 1.0.0:
  • Initial release
This project is licensed under the MIT License.
Originally created by: Thorsten Heilmann
Maintained by: Richard Pointon
Maintained Fork Notice
This repository is a maintained fork of node-red-contrib-growatt by Thorsten Heilmann.
The original project is no longer actively maintained.
This fork continues development with fixes and enhancements to ensure compatibility with current Node-RED versions and Growatt inverter APIs.
Version: 1.1.3
Updated 1 year ago
  • growatt
  • growatt-config
  • growatt
