node-red-contrib-growatt 1.1.2
Access to the Growatt API. Using the PCLHome/growatt library.
npm install node-red-contrib-growatt
With this node you can download data from the Growatt© Shine Webserver. It is only a wrapper around the existing library of PLCHome. Thanks for that!
DEPRECATED INFO
As I do not longer use the Growatt Shine Server for my installation at home, I can´t support this node anymore. You can use it as it is, but please don´t create support issues. If you what to maintain this node in the future, please contact me.
Installation of Node-RED nodes
You can install the growatt node through the Node-RED library. Search for 'node-red-contrib-growatt'.
After creating a 'Growatt' node, create at least one config node for the credentials you use to login at your ShinePhone app or on https://server.growatt.com. The config node you can reuse on several 'Growatt' nodes.
As soon as a message arrives at the input of the node, the API call will be performed. The API result will be send as a new message through the output.
Known issues
This node does not support the parameters historyLastStartDate, historyLastEndDate and historyStart at the moment, which is already available on the underlaying library.
Contact / Issues
If you have issues with the Node-RED implementation: https://github.com/Looking4Cache/node-red-contrib-growatt
If you have issues with the underlaying growatt API library: https://github.com/PLCHome/growatt
Version History
Version 1.1.2:
  • Update growatt dependency to 0.7.4 (fixes login error)
Version 1.1.1:
  • Deprecated Info
Version 1.1.0:
  • Update growatt dependency to 0.4.1
Version 1.0.0:
  • Initial release
Version: 1.1.2
Updated 2 years, 6 months ago
Rating: 2.0 2
18 in the last week
  • growatt
  • growatt-config
  • growatt
