node-red-contrib-grove-capacitive-moisture-sensor 1.0.0
A Node-RED grove capacitive moisture sensor node connected to a Grove Base HAT for Raspberry Pi.
npm install node-red-contrib-grove-capacitive-moisture-sensor
This is a Node-RED node to get readings from the Grove Capacitive Moisture Sensor(https://wiki.seeedstudio.com/Grove-Capacitive_Moisture_Sensor-Corrosion-Resistant/) connected to the Grove Base Hat for Raspberry Pi (https://wiki.seeedstudio.com/Grove_Base_Hat_for_Raspberry_Pi/).
To get it working you have to install it in Node-RED at least ;-)
After this realize the new node "grove-capacitive-moisture-sensor" in the group "grove". Drop it on your flow and add a trigger to its input and connect a debug node afterwards. Happily watch the actualy measured values of the sensor in a nice way.
The rest is up to you!
The included javascript handles the communication between Node-RED and the python script and hands over the msg.payload.
January 2021
Version: 1.0.0
Updated 4 years, 9 months ago
3 in the last week
  • grove-capacitive-moisture-sensor
  • Grove
  • Grove Base HAT
  • Capacitive Moisture Sensor
