node-red-contrib-grohe-sense 0.34.1
Grohe sense nodes via ondus API.
npm install node-red-contrib-grohe-sense
Grohe Sense nodes for node-red
Platform License NPM Known Vulnerabilities Downloads Total Downloads Package Quality Open Issues Closed Issues ...
This package contains nodes for controlling grohe sense devices via the following API: https://idp2-apigw.cloud.grohe.com
Dependencies
This package depends on the following libraries
  • superagent
  • he
  • url
Disclaimer
This package is not developed nor officially supported by the company Grohe. It is for demonstrating how to communicate to the devices using node-red. Use on your own risk!
The code was ported from C# and Java and TypeScript which can be found here: https://github.com/J0EK3R/Grohe.Ondus.Api https://github.com/FlorianSW/grohe-ondus-api-java https://github.com/faune/homebridge-grohe-sense
Thanks for your donation
If you want to support this free project. Any help is welcome. You can donate by clicking one of the following links:
Buy Me A Coffee
Credits
  • FlorianSW for developing the initial version in JAVA
  • J0EK3R for porting the original JAVA implementation to C#
  • faune for doing the great work in TypeScript. This made me port my code from axios to superagent.
Changelog
Changes can be followed here
Project layout
grohe/
  99-grohe.html        Editor UI and inline help for both nodes
  99-grohe.js          Node-RED entry point (just wires the two nodes up)
  icons/
  lib/
    ondusApi.js        Low-level Ondus REST client and notification helpers
    converters.js      Pure helpers: status / measurement / withdrawal conversion
  nodes/
    grohe-location-node.js   Configuration node (login + dashboard cache)
    grohe-sense-node.js      The grohe sense / plus / guard node
test/                  Unit tests (mocha)
examples/              Sample flows
grohe location (configuration node)
Holds the Ondus credentials and identifies the location to operate on.
Property Type Description
Location string Name of the location as it appears in the Grohe Ondus app.
Username string Email of the Grohe Ondus account.
Password string Password of the Grohe Ondus account (stored encrypted by Node-RED).
On startup the node logs in, retrieves the dashboard, and caches the rooms and appliances of the configured location. The access token is automatically refreshed every 30 minutes.
If the internet is unavailable at startup (or the connection is later lost — including a failed token refresh), the node keeps retrying the login with exponential backoff (5s up to 60s) and recovers automatically once connectivity returns. Connection attempts, successes, and failures are written to the Node-RED log to aid debugging. While disconnected, the dependent grohe sense nodes show disconnected. (see #20)
grohe sense
The node is able to get the status of a Grohe Sense, Grohe Sense Plus or Grohe Sense Guard appliance. It is also used to send commands to a Sense Guard.
Note on names: the Room and Name (appliance) must match the values shown in the Grohe Ondus app exactly, including spaces and capitalization. If they don't match, the node logs the available room / appliance names to help you correct them. If commands such as open/close valve time out while reading still works, the configured name is likely resolving to a stale appliance that is no longer fully registered — rename it in the app and re-select it here. (see #25)
Inputs
Any incoming message triggers a poll. The optional fields on msg.payload control what happens:
Field Type Required Notes
payload.command object no Only honoured for Sense Guard (type 103). An object of command fields (see Sending commands). Only whitelisted, correctly-typed fields are sent. Example: { valve_open: true }.
payload.commandb64 string no Optional base64 command blob, passed through only when present.
payload.data.from Date | number no Start of the historical range (Date object or milliseconds).
payload.data.to Date | number no End of the historical range.
payload.data.groupBy string no Aggregation granularity: hour, day, week, month, or year (the API expects lower case; input is accepted in any case and lower-cased; hour is the finest). An invalid value is rejected and falls back to day.
msg.debug boolean no If true, the raw API responses are emitted as a debug warning.
Polling & rate limits
The Grohe Ondus cloud is rate limited: more than ~1000 requests within 24 h to a single endpoint (e.g. /dashboard) get that endpoint blocked for 24 h, which then surfaces as Caught exception: Forbidden (HTTP 403). Each trigger of this node makes several requests (info, status, details, notifications, and — for Sense Guard — command), so an inject node firing too often will exhaust the budget quickly. (see #24)
There is no push/notification mechanism — to react to notifications (e.g. a leak alarm or a closed valve) you have to poll. Pick the polling interval with the device's own update cadence and the rate limit in mind:
  • A Sense Guard uploads its measurements every ~15 minutes, so polling more often than that yields no new data. Polling every 15 minutes (≈96 requests/endpoint/day) is a safe default.
  • A Sense uploads only once a day, so polling it a few times a day is plenty.
  • Alarms and valve interactions are communicated to the cloud immediately by the device, but since this integration only polls, the shortest interval at which you could still catch them without risking the limit is roughly once every 1–2 minutes per appliance — and only if that is the only thing triggering the node. If you want fast alarm reaction, dedicate a node to it and keep all other polling slow.
  • Avoid wiring several inject/poll paths to the same appliance; each one multiplies the request count against the same endpoints.
Sending commands
Sense Guard only (type 103). Put the command fields on msg.payload.command; the node validates them, drops unknown keys, and builds the correct request body — { appliance_id, type, command } (plus commandb64 if you supplied one). You only need to set the field(s) you want to change: the API validates the command object as a whole and requires the complete field set, so the node first reads the current command and merges your changes onto it before sending the full object.
msg.payload = { command: { valve_open: true } };                                   // open the main valve
msg.payload = { command: { valve_open: false, buzzer_on: true, buzzer_sound_profile: 2 } };
msg.payload = { command: { measure_now: true } };                                  // take a reading now
Field Type Notes
valve_open bool Open / close the main valve (Sense Guard).
measure_now bool Take a reading now (Sense Guard).
pressure_measurement_running bool Sense Guard.
buzzer_on bool Sense / Sense Guard.
buzzer_sound_profile int Sense / Sense Guard.
get_current_measurement bool Shared.
reason_for_change int Shared, optional metadata.
A wrong value type (e.g. valve_open: "yes") is rejected with a node.error and nothing is sent. The underlying REST call:
POST …/appliances/{applianceId}/command
{ "appliance_id": "…", "type": 103, "command": { "valve_open": true } }
See the example flow senseguardcommand.
Notifications
Notifications are read per account (not per appliance); each notification carries its appliance_id, room_id/room_name, and location_id/location_name so you can filter client-side. These operations are not gated on device type. Each is a dedicated request — the result is placed back on msg.payload and the node sends a single message.
msg.payload = { notifications: true };                          // all, merged across pages -> msg.payload.notifications (array)
msg.payload = { notifications: true, applianceId: "aaaa-…" };   // all, filtered to one appliance
msg.payload = { notifications: { pageSize: 50 } };              // one page object (pass continuationToken to page on)
msg.payload = { markRead: "<notificationId>" };                 // mark one read (PUT)
msg.payload = { markRead: ["id1","id2"] };                      // mark several read (PATCH)
msg.payload = { markAllRead: true };                            // mark every unread notification read
msg.payload = { deleteNotification: "<notificationId>" };       // delete one
msg.payload = { deleteNotifications: ["id1","id2"] };           // delete several
A ProfileNotification has: notification_id, is_read, notification_type, category, title, description, web_url, timestamp, appliance_id, appliance_name, room_id, room_name, location_id, location_name.
The underlying REST calls:
GET    …/profile/notifications?pageSize=50&continuationToken=<token>
GET    …/profile/notifications/{id}
PUT    …/profile/notifications/{id}     { …, "is_read": true }
PATCH  …/profile/notifications          [ { "notification_id":"…", "is_read":true } ]
DELETE …/profile/notifications/{id}
DELETE …/profile/notifications          [ "id1","id2" ]
The legacy per-appliance notification routes are no longer provided by the API; the node now serves them from this account-wide endpoint (filtered by appliance_id), so the notifications field of a normal poll keeps working. See the example flow notifications.
Outputs
msg.payload is replaced with an object containing the following fields:
Field Type Notes
info object Static appliance information (serial, type, firmware, configuration).
status object Current status flattened as { type: value } (battery, wifi quality, connection state, ...).
details object Detailed configuration of the appliance.
measurement object Most recent reading (temperature, humidity, battery, or for Sense Guard flowrate/pressure/temperature_guard, plus timestamp) taken from details.data_latest — only present when the appliance reports it.
withdrawal object Sense Guard only: the latest water withdrawal (starttime, stoptime, waterconsumption, maxflowrate) from details.data_latest.
consumption object Sense Guard only: consumption summary (daily_consumption, daily_cost, average_daily_consumption, average_monthly_consumption) from details.data_latest.
notifications array Active notifications, each annotated with a human-readable category and message.
command object Only for Sense Guard: the current command state (e.g. valve_open).
measurements array Per-period historical readings from the aggregated response — only when payload.data was specified (defaults to []). See Historical data below.
withdrawals array Per-event historical water draws from the aggregated response — only when payload.data was specified (defaults to []). See Historical data below.
data object Raw aggregated historical data (the full inner content) — only when payload.data was specified. Kept for backward compatibility.
statistics object Pre-computed min/max temperature, humidity, pressure, flow rate, and today/total water consumption derived from data.
Historical data (measurements & withdrawals)
When the input carries a payload.data range, the node calls the aggregated-data endpoint and surfaces its two arrays directly on the output:
GET …/appliances/{applianceId}/data/aggregated?from=2026-06-01&to=2026-06-28&groupBy=hour
  • groupBy buckets the data by hour, day, week, month, or year. The API expects these in lower case; the node accepts any casing on input and lower-cases it before the call. hour is the finest granularity — there is no minute-level option. An unrecognized value is rejected (logged) and falls back to day.
  • msg.payload.measurements — per-period readings. Fields (snake_case, as sent by the API): date, timestamp, flowrate, pressure, temperature, temperature_guard, humidity, battery. Absent fields are simply omitted by the appliance.
  • msg.payload.withdrawals — per-event water draws, in one of two shapes (detect by the keys present):
    • per-event draw: { starttime, stoptime, waterconsumption, maxflowrate }
    • per-period cost summary: { date, waterconsumption, water_cost, energy_cost, hotwater_share }
  • msg.payload.data still contains the full raw aggregated response for backward compatibility.
Both arrays default to [] when the appliance returns none. See the example flow senseguardaggregateddata.
Status indicator
The node icon reflects the runtime state: connecting, connected, updating, ok, N notifications, disconnected, <name> not found, or failed. When the configuration node loses its connection the sense node shows disconnected and automatically returns to connected once the connection is re-established.
Examples
Sense
To get the status simply send any msg.payload to the input.
See the example flow sense in the examples folder.
Sense Guard
To open the valve send:
msg.payload = {
    command : {
        valve_open: true,
See the example flow sense guard in the examples folder.
Getting Historical Data
To read out the internal measurement history you need to specify the start and end date as follows:
let end = new Date();
let start = new Date();
start.setDate(end.getDate() - 2); // last 2 days.
msg.payload = {
    data : {
        to : end,
        groupBy : 'hour' // or 'day', 'week', ...
Dates can be passed in milliseconds format, too:
let now = Date.now();
msg.payload = {
    data : {
        to : now,
        groupBy : 'hour'
See the example flow sense guard last values in the examples folder.
See the example flow sense guard history in the examples folder.
See the example flow sense last values in the examples folder.
See the example flow sense history in the examples folder.
Development
npm install        # install dev dependencies
npm test           # run unit tests
npm run lint       # run eslint
Tests run automatically on every push and pull request via GitHub Actions (see .github/workflows/ci.yml).
Author: Karl-Heinz Wind
The MIT License (MIT) Copyright (c) 2022 by Karl-Heinz Wind
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
Version: 0.34.1
Updated 4 months, 2 weeks ago
Rating: 5.0 2
486 in the last week
  • grohe location
  • grohe sense
  • grohe
  • ondus
  • sense
