node-red-contrib-grocy 0.2.1
Node-RED nodes to interact with the Grocy API
npm install node-red-contrib-grocy
A set of Node-RED nodes to interact with the Grocy API. These nodes allow easy integration with Grocy, a self-hosted groceries and household management solution.
You can install these nodes using the Node-RED Palette Manager or by running:
Prerequisites
  • Node-RED (version 2.0.0 or later)
  • Grocy instance with API access
  • Grocy API key
Grocy API
A general-purpose node to interact with the full Grocy API. Provides access to all API endpoints.
Grocy Stock
Focused on stock management, allowing you to:
  • Get current stock levels
  • Add products to stock
  • Consume products
  • Transfer products between locations
  • Inventory products
  • Get product details
Grocy Shopping List
Manage shopping lists in Grocy:
  • View, create, update, and delete shopping lists
  • Add or remove items from shopping lists
  • Add missing, overdue, or expired products to shopping lists
  • Clear shopping lists
Grocy Chores & Tasks
Manage chores and tasks in Grocy:
  • List all chores and tasks
  • Mark chores as executed
  • Complete or undo tasks
  • Create, update, and delete tasks
Grocy Batteries
Track batteries in Grocy:
  • List all batteries
  • Get battery details
  • Log battery charges
  • Create, update, and delete batteries
  1. Add a Grocy Configuration node and configure:
  2. Add a Grocy node to your flow and connect it to the configuration node
Example Flow
Here's a simple flow to get the current stock:
        "id": "123456",
        "type": "grocy-stock",
        "name": "Get Current Stock",
        "server": "config-node-id",
        "operation": "getStock",
                "debug-node-id"
        "id": "config-node-id",
        "type": "grocy-config",
        "name": "My Grocy",
        "apiUrl": "https://your-grocy-instance.com"
        "id": "debug-node-id",
        "type": "debug",
        "name": "Debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "x": 540,
        "y": 200,
MIT
Version: 0.2.1
Updated 1 year, 7 months ago
11 in the last week
  • grocy-config
  • grocy-api
  • grocy-stock
  • grocy-shopping-list
  • grocy-chores
  • grocy-batteries
  • grocy
  • api
  • stock
  • shopping-list
  • chores
  • tasks
  • batteries
